M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > High flow air filter - BMC or K&N?
      09-28-2016, 08:00 PM   #1
JKen_0115
JKen_0115's Avatar
Drives: 2017_M2
Hi Guys, do have the experience for changing the BMC of K&N air filter that get more quicker or just sound a bit better? Or suggest to change the entire air intake, APE?
      09-28-2016, 11:33 PM   #2
BMW_M2_BE
Drives: Bmw M2
I have the BMC intake filter for replacing the original one. I don't really notice the difference. I still haven't hit 2000km so still driving with caution. Hopefully when I go above 4-5 thousand revs there will be a difference noticeable.
      09-29-2016, 12:18 AM   #3
rouxeny
Living the aloha
rouxeny's Avatar
Drives: 2017 LBB M2
Pretty sure the vast majority of drop in air filters make no noticeable gains. Probably no consistently measurable ones either.....
Appreciate 2
ried791.50
omasou2088.00
      09-29-2016, 12:53 AM   #4
Robin_NL
S0THPAW
Robin_NL's Avatar
8717
Drives: HS M2 Competition
I'm a n00b at airfilters: Do they really help?
Cheers
Robin
      09-29-2016, 01:42 AM   #5
ORIGIN M.
3160
Drives: ///M
Yes
Check out this bad boy
http://www.bmwblog.com/2016/07/07/bm...arousel-195854
Cheers
Robin
      09-29-2016, 02:27 AM   #6
ried
ried's Avatar
Drives: F31, F80
Cheers
Robin
A filter itself won't do anything. What's been referenced above is a cold air intake, and whether or not they have an effect is up for debate. When used in conjunction with a tune that accounts for the increased airflow and adjusts the fuel map accordingly, you can see performance gains - especially when coupled with a performance exhaust that helps move the increased volume of air away from the engine.
Be very skeptical about any claims of performance gains without a tune, however, much less with a simple air filter.
      09-29-2016, 03:32 AM   #7
Glounk
Glounk's Avatar
Qatar
115
Drives: M2 6mt MG
The only real thing you get is more abrasive dust in the engine !!!!
omasou2088.00
      09-29-2016, 04:52 AM   #8
J.M
J.M's Avatar
Netherlands
263
Drives: '17 M2 DCT BSM
2017 BMW M2  [0.00]
Just got myself a K&N, will install it soon.
      09-29-2016, 04:53 AM   #9
NachoM
67
Drives: M2 Alpine White
I don't think its an issue for the majority of us.
Ive been consistently using BMC or K&N filters on all my cars for years and never had any issue with them. But I don't live in a very dusty area...
All tests from all manufacturers of these kind of filters show how well or bad they clean air from particles, which is something we simply don't know in paper filters. And it seems they do well...
Of course you need to keep them clean, but I prefer to clean them every 10K kms, rather on having a paper filter for 30/60K kms as the car manufacturers say.
The way I see it is they will not get visible benefits, but they are not doing anything wrong to your car, and no need to tune it, so if there is any benefit, even I don't notice, then I am fine. Same approach with oils...We all get crazy with getting the BEST oil, better than OEM...and we don't really know if there is a benefit there.
Nacho Martinez
Alpine White M2
      09-29-2016, 05:36 AM   #10
Glounk
Glounk's Avatar
Qatar
115
Drives: M2 6mt MG
-Yes, in a dusty area like mine i keep changing the OEM filters every 20k, for peace of mind.
- For the high perf filters, what i can't understand is how more air you get in without getting more dust( silice dust is like diamond dust ) i guess the new generation oil we are using are doing the job to cover what dust is doing inside the engines !!!
      09-29-2016, 05:38 AM   #11
NachoM
67
Do you know what is the filter properties of the OEM filter??...I don't
I know at least what a BMC filter. And I can clean it as many times I want...
Nacho Martinez
Alpine White M2
      09-29-2016, 09:51 AM   #12
Glounk
Glounk's Avatar
Qatar
115
Drives: M2 6mt MG
I don't, you're right!!!!
      09-29-2016, 09:54 AM   #13
shemeld_135
shemeld_135's Avatar
Drives: 2020 SO - M2C
2020 BMW M2C  [0.00]
2016 BMW M2  [10.00]
only think I noticed about the k&n filter I have is I can hear the turbo spool bit louder.
NachoM67.00
      09-29-2016, 10:58 AM   #14
nachob
Drives: 2004 330i ZHP, 2022 Cayman T
Cheers
Robin
They give you tiny boost at the expense of engine life. Not worth it. Replace paper element a little more often if you live in dusty area but look at the tests. They let more contaminants in and that is even when new much worse if you don't clean and re-oil properly. They are run in race cars because of short engine life. They are run in off road cars because they can cope with moisture better than paper but there is a reason they don't put them on street cars. The minuscule gains are not worth it.
      09-29-2016, 11:50 AM   #15
omasou
omasou's Avatar
Drives: BMWs
2023 BMW S1000RR  [0.50]
2022 BMW F900XR  [3.00]
2022 BMW X6 40i  [0.50]
2020 BMW M2C  [9.50]
High airflow == less filtering
Only gain is increase in sound which is directly proportional to butt dyno performance improvements and a decrease in back pain related to a slimmer wallet
If you search hard enough you may find Jim's original article which was very detailed but I would still take it with a grain of salt b/c he used it to justify the foam filter, which BTW still uses oil. Also notice the date we have beating this topic to death for a long, long, time...
http://www.club3g.com/forum/3g-eclip...ly-better.html
      09-29-2016, 12:01 PM   #16
NachoM
67
Could you elaborate about the less filtering??
Id like to have some clear facts on what a paper filter really "filter", and what a K&N or BMC kind of filters...we know they filter.
Maybe I am missing something, and there is some real measures out there on what each kind of filters really perform.
How also do you explain that some brands already have a BMC filter (f.e.) as OEM part?? Don't you think if they would offer less filtering (meaning I guess they would allow bad particles to get into the chambers...)...they would not be supplied as an OEM part??
Nacho Martinez
Alpine White M2
      09-29-2016, 12:07 PM   #17
omasou
omasou's Avatar
Drives: BMWs
2020 BMW M2C  [9.50]
It's the same concept as your home furnace filter. The "cheap" ones that let all the deadly spores through have less surface area and "bigger" holes which BTW let the air flow better and is less stressful to the motor. As the filter gets dirty the "filtering" improves until the point where the filter is clogged.
The post above talks about some of this and remember race team need sponsors. The also take apart their engines and magnaflux them after each race, well at least PTG did or said they did.
See if you can find Jim's original post about filters.
BTW JC is a good guy and in no way am I trying to disparage him.
      09-29-2016, 12:16 PM   #18
NachoM
67
The post above talks about some of this and remember race team need sponsors. The also take apart their engines and magnafluxed (sp?) them after each race, well at least PTG did or said they did.
Thanks for the link...read it, also the K&N reply...
Again...K&N or BMC (or similar) report how they filter. tests they do...and how they do. You can believe it or not.
I have never seen any official statement of any paper OEM filter making clear their properties, or restuls in ISO tests.
Why then do I need to believe an PEM paper filter is better or more protective??
Yo don't know...
In any case none of my cars ever had an issue or had to clean the MAF sensors, after hundreds of thousands of kms...and Ive been on these kind of high flow oiled filters for many years. They work for me, in the area I live.
Nacho Martinez
Alpine White M2
      09-29-2016, 12:18 PM   #19
omasou
omasou's Avatar
Drives: BMWs
2020 BMW M2C  [9.50]
Yo don't know...
That's the point...all the "test" have marketing behind them. If BMW thought our cars need a foam filter, K&N, etc. they would design the engine with one. That and they realize people will not clean and oil the filter.
ried791.50
      09-29-2016, 12:24 PM   #20
NachoM
67
Because they save money???....
OK...I leave this hear my friend. Maybe you don't need as well a "better" oil, a "better" braking lines, or pads, or fluids...as its all marketing and we are all stupid...
Maybe its all marketing behind an M2...and it is only one more marketing story than a real thing...
Nacho Martinez
Alpine White M2
      09-29-2016, 12:27 PM   #21
omasou
omasou's Avatar
Drives: BMWs
2020 BMW M2C  [9.50]
I only said all the test that I have read are to prove why the person conducting the test has a better mouse trap and that I have not found to date an independent test quantifying a ROI on switching out the paper filter.
If you really want to loose your mind about filtering read this guy's web site for a few days, http://billpentz.com/woodworking/cyc...DustProperties
NachoM67.00
      11-15-2016, 10:49 PM   #22
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
2023 BMW G80 M3  [0.00]
2020 BMW X4MC  [0.00]
16' BMW X4 M40i  [10.00]
06 Cadillac STS  [0.00]
BMC is top quality way better than K&N
AFE Pro Dry is also a good option.
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce
IG: @bmwF9XG80
m2
