M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > F10 M5 DIY Guides
      09-28-2016, 06:03 PM   #1
Kritz
Kritz's Avatar
Drives: 2020 X3MC
Mirror Tap for Escort MAX 360
Greetings, for those who want to find a good DIY for installing a radar on your M5 this link was perfect -
http://www.2addicts.com/forums/showthread.php?t=998321
Everything was right on, except for the Blendmount part for my M5 -
Blendmount Beltronics / Escort Radar Detector Mount (Escort MAX) for BMW. Mount. (model: BMX-2017)
MirrorTap MTX Series Radar Detector Power Cord With 2 Amp In-Line Fuse, Military Grade Taps, RJ11,15" Long
Hope this helps for anyone interested.
2020 X3MC - current
2016 Porsche Cayenne SE-Hybrid
2016 X5 Imperial Blue
2013 M5 Azurite Black
      09-30-2016, 08:04 AM   #2
Kritz
Kritz's Avatar
Drives: 2020 X3MC
Mirror tap size
Greetings,
I used the 0.060" mirror tap size, but you can also use the 0.075". You have to push it all the way down, carefully. Try not to bend the connectors as you push down. Hope this helps.
2020 X3MC - current
      10-02-2016, 11:01 AM   #3
apexlocator
Drives: 2014 M5
Nice! I have the same setup for my V1.
      11-06-2016, 07:11 AM   #4
r6321426
Drives: 2016 BMW M5
Thank you for the post! I also did the same thing. However, does anyone have any idea how to hard wire both dash cam and radar detector from mirror?
      11-06-2016, 05:38 PM   #5
v3n0m
57
Drives: 2013 MCB M5
I did it with a v1 and dash cam. Get a customized cord from:
Safe-N-Sound1.com
One tap, two ends with fuses.
      11-13-2016, 08:51 PM   #6
r6321426
Drives: 2016 BMW M5
Safe-N-Sound1.com
Thank you for the information. I just got a customized cord from Safe-N too. It is really good.
      12-07-2016, 04:24 PM   #7
SpiderM5
SpiderM5's Avatar
Drives: F10 M5
2014 BMW M5  [0.00]
just fyi - i just did this and used the blendmount MirrorTap MTX. i was concerned about length because i didn't want it too long or short, but it turns out there is tons of space behind the mirror housing. i ordered the 15" cable and easily tucked the slack into the housing.
i found the housing to be easily removed by pushing up/into the housing to snap it apart.
the blendmount wire is nice and tidy. it comes with multiple spade sizes but my largest one was too short (solder joint in wrong place). Blendmount is sending me a replacement set, but the second to largest size works for now. it is a bit loose and a couple of cable ties should help.
i recommend the blendmount set but it is a bit pricey and adds an additional failure point (tips are swappable and where they push together isn't the tightest connection).
      12-25-2016, 10:27 AM   #8
M5Beast_NYC
158
Drives: 15 M5
So this connection will work for the dash cam as well? Just wanna confirm. Thx
      12-29-2016, 09:02 PM   #9
SpiderM5
SpiderM5's Avatar
Drives: F10 M5
2014 BMW M5  [0.00]
i just completed my install of the Max 360 and Waylens using the MirrorTap - http://f10.m5post.com/forums/showthread.php?t=1337675
      02-01-2017, 11:14 AM   #10
r6321426
Drives: 2016 BMW M5
Does anyone have any idea if MirrorTap to our M5 will avoid car warranty?
I am going to have upcoming maintenance within a month. Should I remove it before going to dealer? I have a TELESERVICE (replaced old one) for this maintenance.
Thank you.
Search this Thread:
Advanced Search
