ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Suspension and Braking Chat
  TireRack
      04-01-2008, 05:08 PM   #1
misterawa
John 14:6
misterawa's Avatar
Drives: Z4
Cool New shocks?
Hey guys,
My Z4 has been lowered on Eibach's for the last 2 years, with the original Sach shocks. In my opinion, the ride quality has diminished, and I'm noticing a harsher, more sensitive ride. Should I upgrade to Koni sport shocks? Any suggestions.
I just got an Eibach camber kit installed this past weekend, so this will be a perfect time to maybe invest in new shocks.
      04-01-2008, 06:35 PM   #2
BimmerZealot
61
Drives: 2019 BMW X3 xDrive30i
Pick up a set of adjustable Koni yellows Ernie. I know quite a few people running Konis that love them.
      04-02-2008, 12:11 AM   #3
misterawa
John 14:6
misterawa's Avatar
Drives: Z4
I'm really leaning towards getting them. Do you think getting the Koni's would be close to a stock ride?
      04-02-2008, 01:25 AM   #4
1st_Knight
'Entwicklung 85 - Zukunft4'
1st_Knight's Avatar
Drives: 04 Z4 SMG DINAN S1
Ernie, I'm with Paul on this one...go with the Konis .....As I mentioned to you last Friday, the DINAN setup has Konis...here is an excerpt from there website.....
"The Stage 1 Suspension System has been designed to address the foundation for performance handling. The system consists of a set of performance tuned springs and carefully matched Koni adjustable front strut assemblies and rear shocks. The system provides superior handling through increased grip and reduction of body roll, while maintaining a nicely dampened ride. The modestly lower ride height gives the cars a tastefully enhanced performance look as well as improving suspension geometry. The Koni struts feature externally adjustable rebound dampening via a knob located at the top of the strut. The shocks are also rebound adjustable, requiring removal for adjustment...."
Others my feel otherwise, but in the end it will be your choice....
      04-02-2008, 02:18 AM   #5
BimmerZealot
61
Since the Konis are adjustable you can have them at whatever ride comfort you want. So you can have it softer then stock, right at stock, or "feel every crack" stiff.
      04-02-2008, 09:31 AM   #6
Reach
gone baby gone
382
Drives: 2016 F80
An adjustable shock alone isn't going to give you THAT much flexibility. The "range" of adjustability will be determined by the spring rate of the springs you put on. (such as, from mushy to soft, or from stiffer than stock to too stiff.) Also remember that adjustable shocks usually only dampen the bound, not the rebound, so spring stiffness will play greatly into how hard the rebound is.
A mismatched shock and spring set can give a very mushy ride, such as where the car does not have enough time to normalize before you hit the next bump on a bad road, and you'll get a real rough travel. Just food for thought.
      04-02-2008, 12:54 PM   #7
misterawa
John 14:6
misterawa's Avatar
Drives: Z4
Thanks guys for the advice. I'm going online to search for a reasonable price for the konis. Any suggestions on where to order them? I know 1st knight does his research before purchasing a product.
      04-03-2008, 02:58 PM   #8
GP20
95
Drives: Z4M, F80 M3, 991.2 GTS
Spring rates make some difference, but also not that big of a difference if you're talking about a small increment of 50lbs or 100lbs. On the other hand, the Koni's for the regular Z4, from full soft to full stiff, trust me there's a huge difference in ride quality.
It's the other way around buddy. Single adjustable struts/shocks usually only let you adjust thre rebound settings. Also, spring stiffness plays a bigger factor in compression than rebound.
2019 Porsche 911 4 GTS
2016 BMW M3
2008 BMW Z4M coupe
      04-03-2008, 02:59 PM   #9
GP20
95
Shox.com.
2016 BMW M3
2008 BMW Z4M coupe
      04-03-2008, 03:02 PM   #10
GP20
95
Just FIY, the Dinan Koni struts/shocks and the Koni Strut/shocks sold by Tire-rack, shox.com, etc, are not the same thing.
Same shock bodies. Totally different internal valvings.
2016 BMW M3
2008 BMW Z4M coupe
      04-03-2008, 04:49 PM   #11
misterawa
John 14:6
misterawa's Avatar
Drives: Z4
Thanks guys for all the advice . I finally ordered the konis...got it for $646 with shipping included. I can't wait till their installed so I can upload some pics!
      04-23-2009, 06:17 PM   #12
nlink720
20
Drives: 2004 BMW Z4 Roadster
Did you get them installed yet?
FS: Leather Recaro Pole Position Seats & Hardware
      04-23-2009, 10:45 PM   #13
OH FO SHO
OH FO SHO's Avatar
15
Drives: z4
he got them installed a year ago
'03 3.0i z4: tiag ext., red int., SMG, sport, premium
HAMANN exhaust l HAMANN front lip l 19" Miro type 366 (HAMANN edition race replicas) l RPI air scoop l KW v2 coilovers
-*MY PICTURE THREAD*-
zpost
