09-23-2016, 10:03 AM | #1 |
4180
Rep 3,077
Drives: 991.2 Porsche GT3, BMW E46 M3
Garage List 1987 BMW 325is [10.00]
2004 BMW X3 [6.50] 2018 Porsche 911 GT3 [10.00] 1974 BMW 2002tii [10.00] 2004 BMW M3 [10.00] |
Will be tackling installing a set of springs in the next weeks.
Couple questions, any help will be appreciated: 1. I haven't seen any DIY for installing suspensions on the M2 specifically, searched but couldn't find, if anyone has one please point me to it. If there isn't one, is this a good one to follow seeing this car shares suspension components with the M3/M4 without having the EDC: http://f80.bimmerpost.com/forums/sho....php?t=1071406 2. Anyone know the torque specs on the different bolts I will need to tighten after I install the suspension?
Follow me on IG
Garage: 2018 991.2 GT3|2013 135i|2004 M3|2004 X3|1987 325is|1987 325i|1974 2002tii |
09-25-2016, 08:22 PM | #2 |
4180
Rep 3,077
Anybody???
Follow me on IG
09-26-2016, 10:20 PM | #3 |
BimmerPost Supporting Vendor
3843
Rep 54,362
Drives: F80 M3
The installation process should be very similar to the M235i and F2x F3x chassis as there is no real strut tower bar to remove.
09-27-2016, 06:45 AM | #4 | |
4180
Rep 3,077
Dissasembling should be pretty straight forward seeing some of the other walk thru threads. I am more concerned with torque specs when assembling all back together. Was told that the M Performance Installation instructions lists the torque specs. But haven't found them online.
Follow me on IG
09-27-2016, 08:28 AM | #5 |
96
Rep 185
Torque specs are nominally 75% of the yield strength of the fastener. A quick google on Metric bolt torque specs will get you what you need like this table, though I usually only torque critical things during engine assembly. Use the 4.6 class/dry numbers in column 6:
https://www.fastenal.com/content/fed...0Fasteners.pdf |
BAN_M2C4180.00 |
