M2 Technical Topics > Cosmetic Modifications > Rear LED Tail Lights, Sylvania and Philips: FAIL
      09-22-2016, 10:42 PM   #1
omasou
omasou's Avatar
Drives: BMWs
2023 BMW S1000RR  [0.50]
2022 BMW F900XR  [3.00]
2022 BMW X6 40i  [0.50]
2020 BMW M2C  [9.50]
So I thought I would check out LED tail lights.
I purchased set of Sylvania ZEVO LED 1156R and a set of Phillips 1156 stops. Both LEDs are red both manufactures make red, white and Phillips also make Amber.
The bulbs in the rear tail lights except for the small halogen are all white (not red) P21W, 7506 incandescents.
To remove the rear tail light you need a nut driver handle with a 10mm socket.
1. Remove the upper and lower 10mm bolts under the covers
2. Gently pull the lens straight out. The outer edge of the lens where the friction fit stud is takes a bit of pull.
3. Place the lens on a soft cloth or carpet and push down on the gray back and gently pop the plastic tabs.
4. Select the bulbs to replace
5. Reassemble
Picture 1: The Sylvania ZEVO 1156R and Phillips 1156 red LED bulbs, purchased at Walmart and PepBoys, respectively.
Picture 2: D/S tail light
Picture 3: D/S tail light bulb housing removed from lens
Picture 4: 2 Phillips 1156 light installed in the stop light and 1 clear stock 7506 bulb
Picture 5: Same as 4 w/o 7506
Picture 6: D/S tail light plug. To remove pull up on gray tab and pull connector straight up. The connector is keyed (inside) so it can only go on one way.
Picture 7: D/S tail light body area, upper left show hole for friction fit stud and upper right and lower right show 10mm posts.
As you can see the LED are not as bright as the incandescent. So back in with the stock bulbs and LEDs to be returned.
You may want to try the $80 LED other are using but myself. I'm done playing with this.
      09-23-2016, 12:37 AM   #2
T4455
12
Drives: m3
1) Amazing car!
2) I was in the same situation as you but I tried a lot more LEDs
3) Check out this post as it helped me find LEDs I'm very happy with: http://www.2addicts.com/forums/showthread.php?t=1024715
      09-23-2016, 03:43 AM   #3
AlpsRider
AlpsRider's Avatar
2865
Drives: M2 Competition, LBB, 6MT
I tried many LED lights and found these bulbs available from Amazon Prime work great on my M235i. They are much brighter than the stock incandescent bulbs have a warranty and only cost $23. per pair. There have been no errors or hyperflash. https://www.amazon.com/gp/product/B0..._st_dp_summary
      09-23-2016, 06:50 AM   #4
pup73
pup73's Avatar
517
Drives: 2016 BMW M2
I bought these LEDs. Great price. The white reverse lights were great looking. Bright as hell. Made the stock bulbs look yellow. Didn't really notice much of a difference with the red bulbs. I did notice the LED light show on startup, which didn't bother me. But then I realized the car was checking the lights so I was getting the periodic random flashing. That bothered me. So I made an appointment for next week to have the light check coded out.
But last night, I started to get the hyperflash with my left rear turn signal, and an error popped up on my dash. So that was it. I returned to all OEM bulbs. Except the front turn signals. They've been fine (knock on wood). They too do a periodic flash, but that only happens during daylight (since that's when they are not on), and it doesn't bother me.
My question- when they code out the "light check", would that also get rid of the hyperflash? Or is that another issue entirely?
-c
2016 BMW M2/LBB/6MT/Exec Pkg
2009 Acura MDX-stock
2008 Acura RDX-stock
2005 Honda S2000-mostly stock
1994 Nissan 300ZX Twin Turbo-barely stock
      08-30-2017, 01:04 PM   #5
AndrewC1989
AndrewC1989's Avatar
Drives: 2015 328d xDrive
-c
You can do the coding yourself with the bimmercode iphone app and yes when you code out the warm checks you will not get hyperflashing or errors
http://f87.bimmerpost.com/forums/sho....php?t=1405935
AngryBaby344.50
      08-30-2017, 01:26 PM   #6
McPurrs
The deuce gets loose
290
Drives: '17 M2 BSM 6MT
I know I have seen bulb type in the BimmerCode app.. I bet that you have to code the lights to be LED and that might fix the brightness issue.
      08-30-2017, 02:26 PM   #7
omasou
omasou's Avatar
Drives: BMWs
2020 BMW M2C  [9.50]
I believe these particular bulbs are designed to provide the same resistance and brightness as the incandescent bulbs. Remember they are sold in Walmart and PepBoys so no reason to code.
If your not after a brighter and therefore hotter bulb I don't get why people care that the bulb is LED or not other than longevity. When the stock bulb goes in 10 years I'll use these LED bulbs to replace them but no way am I wasting time and $100+ to switch to LED bulbs.
      08-31-2017, 09:38 AM   #8
McPurrs
290
They are all designed to do what you said. BMW puts the option in the coding for some reason. Perhaps its the resistance that changes, or something else. IT is worth a try..
      10-23-2017, 04:37 PM   #9
AndrewC1989
The other reason is because of the way the light illuminates. Regular bulbs fade in and out and LED's are quickly turned on and then off. It looks much more modern and cleaner. It also matches the speed of the blinkers on your mirrors. It's absolutely worth upgrading.
Appreciate 2
m2
