09-21-2016, 05:15 PM | #1 |
22
Rep 116
APEC Brake Disks, any experience?
Anyone used Apec front brake disks for grooved / dimpled replacement for F30 370 x 30 Sport disks p/n 34106797603
370X30 DSK3106 2L , only £127 pair , with 2 year warranty, 24k miles, looks cheap? Do they warp or corrode? |
09-22-2016, 12:11 PM | #5 |
Fool
1857
Rep 3,542
They're going to be crap. They're drilled and grooved so will be noisier, worse at braking (less surface area) and more prone to cracking. It's all very well having a 2 year warranty, but it's the last thing you want to fail, and it's a PITA having to swap them prematurely because they're cracked.
09-22-2016, 12:58 PM | #6 |
22
Rep 116
we all know the pros and cons of drilled disks, but they look so sexy....I don't really want to be a test pilot, so let me know if anyone has tried Apec?
09-22-2016, 02:07 PM | #7 |
10998
Rep 32,881
I think they've f'd up the description, they're £120 each from this ebay seller!
http://www.ebay.co.uk/itm/Brake-Disc...-/112007679247 |
arm010.00 |
09-23-2016, 11:32 AM | #8 | |
22
Rep 116
eBay item number: 391390930105, this auction is for a pair. 2 Year or 24K Miles Guarantee Brake Disc BMW 328 F30, F35, F80 Front Brake Disc DSK3106 2 ltr 01/201101/1900 (Pair) Model Description BMW 3 (F30, F35, F80) 328 i Engine Code N26 B20 A KW / PS / Cyl / Valves 180 / 245 / 4 / 4 Body Type / Fuel Type / Drive Type Saloon / Petrol Engine / Rear Wheel Drive Part Info 1: Diameter: 370, Centring Dia: 79, Thickness: 30, Min. Thickness: 28, Height: 73, No. of Bores: 5 Part Info 2: Disk Type: Vented |
09-26-2016, 05:45 AM | #10 |
22
Rep 116
Visually, they look fine, and you would expect a 30mm thick disk to be robust, but material quality, machining tolerance, surface treatment etc… are all unknowns. Read some positive feedback from a Focus ST owner, and some negative from another, but personally I would only use the disks with proven pad. So we need a test pilot?
09-26-2016, 04:36 PM | #11 |
22
Rep 116
[QUOTE=teaston;20618228]So I asked the UK seller for pics, here's what he sent, looks like they don't have the aluminium hub, but apart from that look like the m performance ones:
You're right about the Alloy hub. My plain disks have and alloy centre. No sure I would like to lose the cooling advantage of that? |
