Please Help!
09-18-2016, 12:35 PM | #1 |
7
Rep 81
Please Help!
hello,
i need serious help my car been acting up so weirdly and i dont know whats going on, first started by dying on me on the high way, i was driving normally going 40 mph cuz of traffic and all of the sudden awd and 4x4 and dcs malfunction came up then few mintues after the navigation screen went off the i got the air bag light then the car wouldn't take gas then it died and i ended up with a dead battery the car wouldnt start, i had my friend jump start me after an hour of waiting then it started and i had no lights or warnings on the dash i drove home fine, the second day on my way to work it did the same exact thing and it died i had to tow it because now every time i put it on drive it start with 3rd gear and doesnt shift at all it only stay on 3rd, the car started over heating and i get the awd 4x4 dcs on the dash as well as trans malfunction i pulled the codes from carly for bmw and heres what i pulled... please someone tell me whats going on and why is it doing that, i havent been able to go to work for the past 2 days because i have no car. PS: the battery in the trunk is heating up alot and when car is on it smokes a little and it have smell to it as well, the battery is fine and my alternator is fine too but when the car sits for couple of hours it dies. i would really appreciate any help or info on whats going on CODES: Base: E90 Build-Year: 2007 Faults: 33 ECUs: 22 Filter: just found Model: 3 (E90) Automatic engine recognition (MotorID=86, Parameter=13) Battery: 8.8V Normal communication Normal connection normal B 1 Date: 2016-09-18 09:45:29 Carly Adapter Version: 21 Device: >LGE< >t8lte_tmo_us< >LG-V496< Motor Control: Engine / Motor Power-management power failure Code: 002DEB Exhaust flap control Code: 002F6C steering wheel angle Code: 00CDA1 Message (control EAF) Code: 00CD95 electric coolant pump, shut down Code: 002E82 DME, internal error: RAM checksum Code: 002AB4 Intelligent battery sensor, communication Code: 002E8E Generator, communication: Bus error Code: 002E98 DME relay short circuit Code: 002ACB ABS / DSC / Brake: Dynamische Stabilitaets Kontrolle / DSC :Clutch is in the open position - rear wheel drive - Transfer Ec / distributor gear fault / Transmission ECU Failure / Transfer case Code: 005F3A Valve calibration data missing Code: 005DD0 Instrument cluster missing km data PT-CAN Code: 00D359 :CAN fault / CAN message Code: 00D36D :Brake disc wipers Code: 005ED2 :Steering angle sensor Code: 005EBA Airbag: Airbag speed signal is missing Code: 0093FB Over voltage Code: 0093D1 Airbag B-pillar left/ B-Saeule links ECU not present/no response from ECU Airbag B-pillar right/ B-Saeule rechts ECU not present/no response from ECU Transmission Control: Transmission / Getriebe GS 19 ECU not present/no response from ECU Transmission / Getriebesteuerung Supply voltage Code: 0053FC KL30g supply voltage Code: 0053FD VGSG wheel Notlaufregelung activated. No DXC desired torque setting Code: 0055C3 Gear switch / Gangschalter ECU not present/no response from ECU Instrument cluster: Instrument cluster / Kombiinstrument supply voltage failure Code: 00931D Central info display / Zentrales Display SV-block checksum incorrect Code: 00A46B Light/Rain Control: High-beam / Fernlichtassistent ECU not present/no response from ECU Heating / AC: Air conditioning / Klimaanlage 12V output peripherals Code: 009C6C Immobilizer System: CAS Signal detection error rate Code: 00A0B5 Interlock PLOCK error Code: 00A0B6 Park distance control: Park Distance Control / PDC ECU not present/no response from ECU Cruise Control: Active cruise control / Aktive Geschwindigkeitsregelung ECU not present/no response from ECU Sunroof / Roof: Sunroof / Schiebedach ECU not present/no response from ECU Roof / Dach ECU not present/no response from ECU Audio/Navi/Communication: Phone / Telefon ECU OK, no Fault Code Tuner Antenna / Antenne ECU OK, no Fault Code Hybrid Radio USA ECU not present/no response from ECU Digital Satellite-Tuner USA ECU not present/no response from ECU Navigation ECU not present/no response from ECU CD-Changer / Wechsler ECU not present/no response from ECU Audio-System Watchdog Timeout Code: 00A199 Video ECU not present/no response from ECU DAB ECU not present/no response from ECU Seats: Seats / Sitze ECU OK, no Fault Code Seats / Sitze ECU not present/no response from ECU Systems: Junction Box Passenger / Beifahrer K CAN failure Code: 00C910 Fuel pump / Kraftstoffpumpe ECU OK, no Fault Code Tire pressure control / Reifendruck Kontrolle Controller error Code: 00604D Passive Go System ECU not present/no response from ECU Car Communication Computer CCC ECU OK, no Fault Code MASK ECU OK, no Fault Code Car Communication ECU OK, no Fault Code Anti-theft alarm system: Interior protection / Innenraumschutz ECU not present/no response from ECU Theft alarm / Diebstahl Warnanlage ECU not present/no response from ECU Chassis: Air suspension / Luftfederung ECU not present/no response from ECU Body: Automatisches Front Steering ECU not present/no response from ECU Trailer / Anhaenger ECU not present/no response from ECU Fussraummodul /FRM Energy saving mode is active Code: 009CB5 SMC right Code: 009CC0 SMC left Code: 009CBF :cornering light right Code: 00A8A9 Dynamic manager / Dynamik-Manager ECU not present/no response from ECU Other: Hifi Amplifier / Verstaerker ECU OK, no Fault Code ECU 55 sorry, unknown fault Code: 00A9AC Central Control / Zentrale Bedieneinheit ECU OK, no Fault Code |
09-18-2016, 12:38 PM | #2 |
bOrN To DiE
413
Rep 1,738
I bet its your battery. Looks like time to replace it. Battery in these cars act like virus and throw bunch of unnecessary codes. Start with that and good luck..
09-18-2016, 09:30 PM | #3 |
392
Rep 2,367
Drives: 2011 335i
It has to be your battery these cars do some strange things when the battery is going out.
09-18-2016, 11:39 PM | #5 | |
392
Rep 2,367
Drives: 2011 335i
09-19-2016, 03:59 PM | #7 | |
392
Rep 2,367
Drives: 2011 335i
09-19-2016, 04:39 PM | #8 |
65
Rep 231
You'll tend to get a lot of BS codes if your voltage is too high or too low. Could just be the voltage regulator.
http://blog.bavauto.com/3796/bmw-sys...63-e64-others/ |
