[FS] Facom Metric 37 Piece, 1/4", Ratchet, Socket and Bit Set
09-14-2016, 09:31 AM | #1 |
40
Rep 163
As title.
I'm an engineer and have a bit of a tool fetish . Having a clear out as I now have too many including duplicate sets both at home and work. If you know your tools, you'll know Facom are one of the finest professional toolmakers available - their precision tools are of the highest quality. This set has had mild use at home only, for just a handful of tasks. Many of the pieces are unused, as can be seen from the pictures. The set is their most comprehensive 1/4" drive set, and comes complete with: - 72 Tooth Ratchet - 10 x Hex Sockets - 5.5, 6, 7, 8, 9, 10, 11, 12, 13 & 14mm - 55mm & 100mm Extension Bars - Screwdriver Handle - Universal Joint - 1/4" Bit Adaptor - Tamperproof Torx Bits - T10, 15, 20, 25, 27, 30 & T40 - Pozi Bits - PZ1, 2 & 3 - Phillips Bits - Ph1, 2 & 3 - Slotted Bits - 4.5, 6 & 8mm - Hexagon Bits - 3, 4, 5, 6 & 7mm The set is perfect for all kinds of automotive and domestic joints, everything you need in a compact case. The universal joint has proved invaluable many times in reaching awkward nuts and bolts at difficult angles on the car. The ratchet is incredible strong for its size, I've been using them for years and put some serious torque through them undoing difficult bolts - I've never had one fail or give up on me - the quality is astonishing. These range from the cheapest on eBay @ £109.95 up to £200+. I am asking just £70 delivered for this.
E92 M3 DCT 1 of 25 Santorini Blue Competition Pack |
