09-13-2016, 08:21 AM | #1 |
19
Rep 124
BMW Tuner
Hey everyone,
I have a 2013 BMW 335i xDrive. It has a boost leak and I'm trying to find a good tuner near me. Does anyone know of someone near Dayton, OH. It's quite an annoying leak. Thanks, Ryan |
09-13-2016, 11:08 AM | #2 |
BimmerPost Supporting Vendor
24199
Rep 190,807
Why are you looking for a tuner? Shouldnt you go to the mechanic to fix the leak?
How do you know that you have a leak?
09-13-2016, 11:22 AM | #3 | |
1610
Rep 3,947
If you have 25psi of boost but you're losing 5 psi due to a boost leak, you just up it to 30psi and that way you still have 25psi even with the boost leak. |
09-13-2016, 11:42 AM | #4 |
118
Rep 1,668
couldnt you just change the blow out valve and do the same thing?
Enjoying an E89 Z4, F30 320i and Fiat Abarth //
E85 Z4 (sold), E82 128i (sold), Fiat Pop 500 (sold) |
09-13-2016, 11:44 AM | #5 |
464
Rep 716
09-13-2016, 01:01 PM | #6 | |
19
Rep 124
The charge pipes broke so I put ER charge pipes on. Randomly I can feel the power build but the all of a sudden it just stops and has no response at all. I get a drivetrain malfunction on my NBT and it won't let me go over 50mph+. Turn the car off and back on and it works fine again. Happens about once a week or so. I need someone who is familiar with the car and the bolt ons to tell me why I'm having this issue. |
09-13-2016, 01:03 PM | #7 | |
24199
Rep 190,807
09-13-2016, 01:12 PM | #8 |
19
Rep 124
09-13-2016, 01:13 PM | #9 |
24199
Rep 190,807
Start by logging and posting your datalog on BMS forum
09-13-2016, 02:29 PM | #10 |
19
Rep 124
09-20-2016, 06:06 PM | #11 |
19
Rep 124
Okay so I'm going to start logging today but I did a quick test before hand.
This issue I'm having is usually in high gear (6th). So to test it I turned the jb4 off. I floored it in 6th and no issues. Tried some other gears no issues. Turned the tuner to Map 1 (I usually run it in Map 5) Did the same as above. Floored it in 6th and instantly got the issue. What will logging in 3rd gear do for me, since this usually happens around 6th and randomly in other gears? Which is why I wanted to find a tuner to test all connections and pressure, etc... |
09-20-2016, 06:10 PM | #12 | |
24199
Rep 190,807
Then log gear 6
09-20-2016, 08:01 PM | #14 |
1268
Rep 2,957
Firmware up to date? Correct board? Wires plugged into correctly?
2015 335i Msport/6 JB4/EWG/E30/VRSF DP/ER CP/ VRSF Race Exhaust/ Injen Intake/Verde Axis 19x8.5/9.5 245/35/275/30 Conti Extreme CS/ H&R Sports / Motorsport Hardware Stud Conversion
09-20-2016, 08:12 PM | #15 | |
90
Rep 205
sprayed coffee all over the keyboard.. |
Polo088161610.00 |
