09-10-2016, 03:32 PM | #1 |
Rep 4
BMW engine destroyed by water- common?
I had a question for everyone. I have a 2014 328i and during heavy rains I turned around near the water's edge of a flooded road, but didn't actually go in the water. Next thing I knew the car shuddered and died. Water got sucked up into the engine, totaling it, and costing insurance around 5k for a new engine from Germany. My questions are: is this common for a 3-series? Are they that sensitive to driving in/near standing water, or was I just unlucky? Where is the air intake for the engine? Thanks for the advice!
09-10-2016, 03:58 PM | #2 |
8245
Rep 16,088
The air intake is off to one side behind the kidney grille, so the only way you'd suck water into it is if you were either at least a foot deep into water or you got hit by a wave high enough to go through the kidney grille.
09-10-2016, 04:32 PM | #3 | |
284
Rep 703
2018 M3 ZCP "Edition Velocity"
2018 X3 30i (wife’s) 2017 340i w/ MPPSK & Many M Performance Parts (sold) 2016 328i (sold) |
fatalkarma46.00 |
09-10-2016, 05:55 PM | #5 | |
Curmudgeon and Pedant
690
Rep 3,489
09-10-2016, 07:43 PM | #6 |
21
Rep 48
The air box on most cars is designed to deal with small splashes. As air and any water goes in the kidney grill intake, it would enter the large volume air box and separate, with the water dropping down and out the drain hole, whilst the air is sucked up through the roof of the box, through the air filter and onto the engine. You would have to seriously drown it to get water through the box. Quite how it happen'd is beyond me if you didn't go in the water.
09-10-2016, 09:00 PM | #7 |
155
Rep 272
The max depth allowed is 30cm for MY2013 and 25cm for 2014+ according to the manual. In particular on the passengers side where the intake is. So making a left U turn in standing water would put you at more risk than a right turn/reversing out.
09-10-2016, 09:34 PM | #8 |
644
Rep 2,294
Not common at all, in fact, this is the first instance I have heard of and I have been driving BMWs for years.
Are you SURE you didn't go into the water.....??????
2018 340i xDrive M Perf Edtn Sunset Orange
Previous BMWs - 19 others since 1971. |
fatalkarma46.00 |
09-11-2016, 03:07 AM | #9 | |
46
Rep 164
Drives: 2024 G87
[/SIGPIC][/SIGPIC]2016 f32 Alpine White On Porno Red
M Sport, 6MT, Dinan Stage 4, Dinan CF Cold Air Intake, Dinan Intercooler, Dinan Big Turbos, Remus Sport Catbacks, and lots of Carbon Fiber Eye Candy |
09-11-2016, 09:11 AM | #11 |
1837
Rep 6,990
Drives: 15 F80 M3, 22 G01 X3 30i
Probably more likely a "short block" (cylinder block and pistons/crankshaft, etc.) as the upper end wouldn't be subject to as much damage. I had a Chrysler LHS that got into deep water (above the front right tire) when my son was trying to get home during a very heavy rainstorm and was unfamiliar with the area we had just moved into. The engine hydrolocked and put a rod through the crankcase. Insurance paid for a rebuilt short block and the heads (it was a V6) and all the other parts were salvaged from the damaged original engine.
To answer the OP's question - no, this is not common and could only have occurred if the water reached the intake, filled it, and was drawn into the throttle body. The drain holes are only able to handle condensation or small amounts of water (such as from road spray).
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
09-11-2016, 11:25 AM | #12 |
I want to drive a Zamboni
1131
Rep 5,557
Drives: 13 E93 M3 18 F80 M3 16 K71
I don't recall we got flooded in CA unless you traveled to other States.
18 F80 Imola Red 6MT
16 K71 F800GT Montego Blue 13 E93 M3 Melbourne Red 2000 E46,2006 E90,09 E82,13 E93 328i,14 F30 335i,18 F80 M3 My next vehicle would be a Zamboni |
09-11-2016, 11:38 AM | #13 | |
772
Rep 1,502
Can't say that many people really believed the part about driving really slowly or the part about hardly any water or even the part about other cars flying through. But who knows what really happened. Anyway, I've accidentally bombed through a several inches of water in my E46 to where water splashed up as high as the windows and you feel the car suddenly slowing like you just hit the brakes. Reading these posts makes me realize how lucky I was not to get water in the intake. |
09-11-2016, 01:36 PM | #14 |
265
Rep 807
It's common for any engine to have a catastrophic failure when it sucks up water. Water cannot be compressed like fuel/oil so the pressure has no where to go but through the side of the block or destroying the connecting rods.
09-11-2016, 08:07 PM | #15 |
432
Rep 814
09-11-2016, 08:32 PM | #16 |
40
Rep 197
Wow...I'll be much more careful...just went through 4-6 inches minimal at some speed this weekend...have taken Bugs and TRegs through higher. Was only concerned the Bug might start floating off adrift.
09-11-2016, 09:40 PM | #17 |
44
Rep 143
Parked overnight in a driveway that had a noticeable inclination (with front of car higher than back.) This was not San Francisco steep but enough of a gradient that it took a little extra effort to open the door and for this old guy to get out. There was a very heavy and prolonged rainfall overnight. Run-off from the garage eave was hitting the ground a few inches in front of the car.
Upon first start next morning the engine stumbled and stalled. Took two or three attempts to get it going, with the engine then running roughly for a minute or two. Service advisor, a thoughtful type, later speculated that rain bounced off the pavement and settled in air intake, but he was clearly puzzled. There were no codes and no subsequent problems. This was a 2014 328 xdrive with around 5000 miles when it happened. |
09-12-2016, 01:23 AM | #18 |
Rep 9
A completely different car perhaps but I hydro locked a vw passat a few years ago.
It was completely my fault, drove through a ford that was too deep, while driving through it didn't seem that deep and I made it out the other side only for the engine to stall. £5k insurance claim and an entire new engine and turbo. Not a happy experience at all. Despite the intake being quite high up I think the way the front diverts water wasn't helpful. |
09-17-2016, 06:51 PM | #21 |
Rep 4
A big Thank You to everyone for the replies! It is especially helpful to know this is not common. And as folks guessed, the flooding happened while driving in another state (FL).
09-18-2016, 09:14 AM | #22 | |
271
Rep 740
Another side note. The filter box is not necessarily where the inlet is. It could be much lower. |
Tags |
engine, totalled, water |
