KW V1 Popping/Clunking on 335xi
09-08-2016, 03:59 PM | #1 |
111
Rep 186
Hey guys, recently installed my KW V1 on my 2008 335xi. I have a few questions for those of you running these coilovers.
1. Do you experience a popping/clunking noise during low speed turns ? I specifically hear it when I'm backing out of my driveway in the morning. It only happens during slow speeds (under 10mph). What did you have to do to fix it? 2. What's the best method to adjust the rear coilovers? I've done a search and saw people were using a 3inch C-Clamp, however when I tried this I was't too successfully as there wasn't enough room between the top and bottom perch for the C-Clamp to hold on to. Here's a picture of my car with the KW V1's installed. Rear is dropped to the lowest setting, and front could go about half inch lower: Thanks in advance guys! UPDATE: So i finally figured it out, it looks like the main cause was the top bolt of the coilover was over torqued and caused the popping/clunking issue when turning the wheel. I made a video to show how it should look. Last edited by TypeDre; 10-04-2016 at 04:25 PM.. |
09-08-2016, 06:59 PM | #2 |
7
Rep 47
check your subframe bushings? can also be the coilers hitting the sway bar end links as well. i know mines were hitting mine and i had to readjust them. I'm on st coilovers. you might just need longer end links if you dropped the car a lot
09-09-2016, 10:41 AM | #3 |
Rep 18
If it happens when turning the wheel all the way it could be the end links. If not its more than likely you didn't preload the springs correctly?
09-09-2016, 05:49 PM | #4 | |
111
Rep 186
I also looked underneath the car and found that the sway bar end link was indeed hitting the strut since I was at the lowest setting of the coilovers. I raised it about an inch and now it clears and the popping went away. My question is what options do I have to go lower and be able to clear the sway bar end link?? Last edited by TypeDre; 09-09-2016 at 05:52 PM.. Reason: Edit |
09-09-2016, 10:07 PM | #6 |
Rep 18
I just double checked and you dont have to preload since you dont have the threaded shock body for height adjustment. To get lower I think you change the stoppers. But Id be careful with the xi system you might throw it out of whack.
09-09-2016, 11:53 PM | #7 |
7
Rep 47
im on st coilovers so i had the same problem since they are the same design. you could probably get some adjustable endlinks put in and maybe they would sit out far enough to not hit the collar. the uuc ones looks like they would maybe work but not many people like them since theres no boot on it. My uuc swaybars also came with these brackets so those helped me fix the issure you are having. on my e46xi, i was told if i lowered more than 1.5 inches it would wear my axles out quick. im not sure if that applies to the e90s though
09-12-2016, 09:57 AM | #9 |
285
Rep 615
Drives: '11 E92 335xi 6MT
Adjustable sway bar end links will fix this. There are lots of different options for the rwd cars but our xi's are a bit weird because they have the same rod ends as the E9x non-M cars but the same length as the M3.
HPA makes some that are the right length for xi and have sealed rod ends. http://www.hpashop.com/HP-Autosport-...ks-e82-e9x.htm I have Ground Control ones and they have exposed rod ends that occasionally develop noise and need to be greased. http://www.ground-control-store.com/.../II=856/CA=231 They don't list an xi-specific application but they make everything to order so you tell them they need the same rod ends as E9x non-M but 13.5" length like E9x M3 and you get xi-specific links. Honestly I chose the Ground Control ones because I didn't realize that the HPA ones had the sealed rod ends. The HPA ones probably require less maintenance but really it's not a big deal to occasionally hit the heim joints with a little bit of spray lube. I use WD-40 Specialist water resistant silicone. |
09-13-2016, 12:56 PM | #10 | |
111
Rep 186
Thanks for the help guys!
Thanks guys! |
09-13-2016, 01:01 PM | #11 | |
111
Rep 186
09-14-2016, 10:11 AM | #12 |
3441
Rep 79,211
You shouldn't go on the lowest setting possible on the KW V1 Coilovers. They have a specific spec range you should stay within per the manual.
I'd be interested to see if the aftermarket end links help with this but keep in mind the shocks will also be out or range. According to KW it will also void your warranty. I'm battling the same debacle on the rear height adjustment. I've already taken the rears out twice to get the height I want, sadly I'm still not happy with where it sits but don't feel like taking everything out. Let me know if you come up with an easy way to adjust without the top collar spinning. |
09-14-2016, 10:50 AM | #13 |
39
Rep 810
I never have problems with the rears i always spray the rears with w-2 clean all the dirt witch is why it gets stuck re-apply w-2 adjust the height and clean again never used a clamp or anything else
09-14-2016, 10:55 AM | #14 | |
3441
Rep 79,211
I had this problem when they were brand new and I barely have any miles on them, they are clean as a whistle. I wish the vehicle come with a dowel pin that kept that upper perch in place. |
09-14-2016, 08:30 PM | #15 | ||
39
Rep 810
09-20-2016, 11:27 AM | #17 |
111
Rep 186
Hey guys, just installed the UUC sway bar end links and might have ran into a problem. The UUC end link seems to be hitting the strut body when turning the wheel so I put the stock ones back on. Anyone have any experience with these end links and are they supposed to look like this? I need some help on how these are supposed to be fitted cause it's hitting the strut. Thanks in advance!
09-21-2016, 01:09 PM | #18 |
45
Rep 213
not sure what settings you are running on your kw's. But my strut does not rub my end link at all. Not even once(would've chipped the yellow or purple). I'm on 19's with no tire tucked.
09-21-2016, 01:47 PM | #19 | |
3441
Rep 79,211
09-25-2016, 08:17 PM | #20 |
294
Rep 1,834
Drives: 08 E90 335xi TiAg
10-05-2016, 01:19 AM | #21 |
111
Rep 186
Updated my first post. I finally figured out what was causing the noise. Over tightening the top bolt/nut caused the top hat to be stuck and unable to freely turn. Uploaded a video for you guys tooo lol
10-11-2016, 04:03 PM | #22 | |
3441
Rep 79,211
I believe the top nut should only be about 30-35lbs. Lots of people not only over-torque them but use an impact gun, which are NO-NO's. There is actually a tool to properly tighten them. or Last edited by Jeff@TopGearSolutions; 10-11-2016 at 04:13 PM.. |
