09-06-2016, 09:12 AM | #1 |
118
Rep 1,668
Drivetrain Malfunction @ 85K
Hi folks, Saturday my wife was driving the F30 and was stopped at a red light waiting to turn into a parking lot when the vehicle engine died. A second later the message Drivetrain Malfunction displayed on the dash. She tried several times to restart the vehicle but was unsuccessful. She said she tried to put the vehicle in park but the shifter would not respond to any of her commands. Someone luckily saw her and helped push it into the parking lot. Obviously this tells me that the vehicle was stuck in gear or in neutral at the time.
I got there about 20 minutes later and tried to crank it. No luck. Car as in Park, foot on the pedal pressed the button and held but it just spun over. I tried this a couple times thinking maybe it would catch but nope. I opened the hood to look for any obvious damage (expecting to see maybe a piston sticking out of the engine somewhere because it sounded like it didn't have any compression. Surprised, I didn't see anything obviously wrong. Not that i didn't believe her when she said nothing weird happened before the incident. I tried cranking it one more time. This time it cranked right up and purred like a kitten. Scared to turn it off i decided to drive it 10 minutes away to the dealer. I didn't have a red indicator and it said to drive Moderately i drove carefully and dropped it off. This is the first major issue we have had with it, Short of a reprogram here or there. I figured that those buffs out there who are keeping track would like to know the issue and fix. Ill keep you posted as we begin to determine what it wrong with the vehicle and why it happened in the first place.
Enjoying an E89 Z4, F30 320i and Fiat Abarth //
E85 Z4 (sold), E82 128i (sold), Fiat Pop 500 (sold) Last edited by rking117; 09-06-2016 at 09:20 AM.. |
09-06-2016, 10:54 AM | #4 |
118
Rep 1,668
yep
E85 Z4 (sold), E82 128i (sold), Fiat Pop 500 (sold) |
09-06-2016, 11:03 AM | #5 |
137
Rep 310
I had a drive trail malfuntion the other day. Car is a 14 F32 with 45k Miles. Although my symptoms were much more forgiving than yours (car didnt die) it still let me drive.
I took it to the dealer and they said that my thermostat broke causing the computer to just give random messages. Didnt exactly buy it... But they said they would fix everything under warranty. |
09-06-2016, 03:40 PM | #6 |
155
Rep 272
I've been through many 'Drivetrain Malfunction' errors with my F30(Probably 20+). Many of them have also resulted in the car getting in the state where the shifter won't respond and it takes a few minutes before the car starts back up. I don't remember the message but it did this as a safety measure for some but not all some Drivetrain Malfunction errors. Sometimes the error would result in a 'cont driving possible' state.
09-06-2016, 04:20 PM | #7 | |
2413
Rep 4,451
Drives: '23 X1 28i xDrive
Odd that the same problem can manifest itself in different ways. |
09-07-2016, 03:11 AM | #8 | |
355
Rep 1,986
This was my 2nd in 65 days. Last time they said it was the fuel pump. Can't wait to hear the excuse this time. However, my car has always been drivable after warning. |
09-08-2016, 08:49 AM | #9 |
118
Rep 1,668
ok got my first insight as to the problem. The SA said the is some voltage regulator that went bad on it. I will know more about the part when i pick it up after it is fixed i suppose. That is if when they replace it they don't find anything else. I will post back once i get more info
09-08-2016, 08:53 AM | #10 | |
118
Rep 1,668
Have you ever had this issue diagnosed and if so what did they find? When was the last time you had one?
09-08-2016, 08:58 AM | #11 | |
118
Rep 1,668
09-08-2016, 09:34 AM | #12 | |
155
Rep 272
09-09-2016, 08:34 AM | #13 | |
355
Rep 1,986
09-09-2016, 12:09 PM | #15 | |
525
Rep 1,232
09-15-2016, 03:44 AM | #16 |
355
Rep 1,986
Replaced my fuel pump 60 days ago, claiming it was cause.
Just got it back claiming they claim it was a faulty intake vanos solenoid valve. FC 1136021200 DIAG CODE D1130_B0000000_03_001 Part # 11-36-8-605-123 Your results may vary. We'll see how long this works. |
