09-04-2016, 01:56 PM | #1 |
104
Rep 156
Hypothesis on the naming scheme
I have seen a lot of confusion, and have even myself been confused about the naming scheme of the new BMW cars. Obviously the first number refers to the series, but in the past it is generally well known that the following 2 numbers referred to the displacement.
However, seeing as my 335i does not have a 3.5L engine, this is obviously not the case. However, after looking at a few dyno charts for the different engines, I have come up with an idea. Last night, I stumbled upon the dyno chart that the guys at Burger Motorsports posted, and using an online calculator to convert wheel horsepower to crank horsepower (a quick google search links to a UK website), I plugged in some of the numbers and got some interesting results. N55/335i: Online dyno suggests ~ 293 RWHP which translates to 352 crank. Rounded at 350, you get your 35. B58/340i: Burger - 331 RWHP translates to 397 crank horsepower on a modern automatic (with the calculator I was using). Round that to 400 and you get your 40. N20/328i: Online dyno suggests ~ 228 RWHP translated to 277 crank. Round that to 280, and you get your 28. B48/330i: BMWUSA online suggests - 248 Horsepower, which if we assume to be the wheel horsepower (since all these motors seem underrated), comes out to exactly 300 Horsepower. And that is where you get your 30. Seeing as I have only owned my BMW for about 4 weeks, and came from a Scion and a Toyota before that, I am still learning about the brand. From searching online, however, I have not yet seen any real logic behind the naming convention. Could it be, that BMW has been hiding their "true" horsepower numbers in their naming schemes for the last few years? Let me know what you think, or if I am late to the show and the naming scheme is already an established fact. Thanks! |
09-05-2016, 09:03 AM | #3 |
87
Rep 191
Drives: '17 340i X-Drive M Sport EBII
That makes a lot of sense, but if it is actually where it comes from, it'll be so much easier to figure out how much power a car really makes
09-05-2016, 12:40 PM | #6 | |
2253
Rep 3,622
Honestly I would not be surprised if someone at BMW was having fun when it came to advertising hp/performance. This all being said. Quarter mile times for the B58 suggest a number between 350 and 370 tops
BMW CCA Member #516012
2016 340i, Estoril Blue, Manual Transmission, MPE, MPBBK, HRE FF04 Instagram: @brandons340i |
09-05-2016, 02:00 PM | #7 |
3575
Rep 10,355
BMW naming, throughout their history, has been consistently inconsistent with a sprinkle of what appeared to be be consistency.
Example, even numbers weren't always coupes (ex, 3 series coupes, 507). Last two numbers didn't always denote displacement (ex 1990s 535) or power at the crank (ex E46 330 225hp vs E90 330 255hp. E90 335i vs E90 335d)
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line |
tturedraider4974.50 |
09-05-2016, 03:17 PM | #9 |
104
Rep 156
09-05-2016, 03:34 PM | #10 | |
989
Rep 2,200
1. BMW designated this particular model as 745i instead of 732i Turbo due to the theoretical assumption that the turbocharged motors have about 1.4 times more power than naturally aspirated motors. Thus, 3.2-litre (3205cc) turbocharged motor has "power equivalent" of 4.5-litre (4487cc) motor without forced induction. 2. 745i, that’s a 4.5L V8, right? Wrong! The 745i was arguably BMW’s most egregious departure from the [Series][Engine Size] nomenclature (at least until the current “Xdrive35i” or whatever they’re doing). You see, BMW decided that the turbocharged 3.2L I-6 had comparable power output to a 4.5L naturally aspirated engine (and that most owners would never look under the hood) and decided to go with the bigger number in place of the more accurate letter “T”.
____________________________________________
2015 BMW 228i in EstorilBlau II Metallic / Terra Dakota Leather - 6-speed manual, M Sport Package, Cold Weather Package, Lighting Package, Premium Package, Harman Kardon premium sound, Anti-theft alarm system, Blue Metallic Matt Accent Moldings, Aluminum Hexagon Interior Strips, Anthracite Headlining |
HighlandPete6658.50 tturedraider4974.50 |
09-05-2016, 03:46 PM | #11 |
15
Rep 81
Same thing my dealer told me so someone at least gave them that line. My 428 for instance he said is equivalent to 2.8L older engine. I pointed out it makes a lot more but whatever.
09-05-2016, 03:50 PM | #12 | |
6659
Rep 15,858
Plus we have had other anomalies, such as the E39 540i with its 4.4 litre engine. The following model E60, took on the 545i label, with the same engine size, with the more appropriate numbering. |
GaryUFM189.00 |
09-06-2016, 01:46 PM | #13 |
20
Rep 96
So with the b58 mppk - shall I change my trunk so it reads
343i ? |
Sheharyar_rr236.50 |
09-06-2016, 02:04 PM | #14 | |
1061
Rep 3,258
Drives: 2015 F36 Jet Black Sport Line
Pretty cool theory but I don't think the parasitic loss is @18%...
2015 BMW F36 428i JetBlack. Sport Line Edition
25% 3M Tint| |
09-06-2016, 04:15 PM | #15 | |
890
Rep 7,047
BMW has used the naming scheme of using series plus engine displacement by which to "name" the various models. But, even that was not consistent as a poster above pointed out. They stopped doing the series+engine displacement a while ago to much consternation by those who loved the former scheme. BMW has gone to a naming scheme where the "name" starts with the series and then the next 2 numbers represent a value of perceived performance. What does that mean? It means, if a former 328i had a certain level of 3 series performance with a 2.8 liter engine, then a new 3 series with a higher level of performance with a 2.0 liter turbo engine could easily be called a "330i". A former 330i with a naturally aspirated 3.0 engine could easily be replaced with a new 3 series with a 3.0 liter turbo that kicks the former NA 330i's butt, and it can be called a "335i", and when a higher powered 3.0 turbo engine gets put into a mid life cycle refresh, then the new one can be a "340i". See? Clear as mud, no? And that's all there is to it. Last edited by RPM90; 09-06-2016 at 04:24 PM.. |
09-06-2016, 04:20 PM | #16 |
1061
Rep 3,258
Really, the only model that makes any logical sense is the 320..3 series, 2 liter. The 335 might have had it been the 5th generation of 3 series....with a 3.0liter. Hypothesis abound!
25% 3M Tint| |
09-06-2016, 05:00 PM | #17 | ||
4975
Rep 6,241
Drives: 2018 340i M Sport
Garage List 2018 BMW 340i M Sport [9.38]
2020 BMW M340i xDrive [10.00] 2018 BMW 340i M Sport [8.00] 2006 BMW 330i Sport [4.50] 2004 BMW 330i ZHP [7.25] 2000 BMW 328i [6.00] |
www.bmwcca.org member #388003 - Use me as a referral & you could win a one day ///M Driving School!! ___________________________________________ |
09-06-2016, 06:29 PM | #18 |
104
Rep 156
09-06-2016, 07:46 PM | #19 |
Big Beaver Smile
2101
Rep 3,791
Now if BMW would just stop naming cars with 4 doors "coupes"
______________________________________________
Current- '21 430 , '19 911, 07 M6 ,'17 Jeep Wrangler, "23 Bronco OBXluxsquatch |
09-06-2016, 07:58 PM | #20 | |
271
Rep 740
09-07-2016, 10:55 AM | #21 | |
Big Beaver Smile
2101
Rep 3,791
http://www.flemingtonbmw.com/searchnew.aspx
09-07-2016, 07:38 PM | #22 |
1061
Rep 3,258
My math is fine..but yes, it is a cool coincidence.
25% 3M Tint| |
