KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK! |
03-30-2008, 02:08 AM | #1 |
162
Rep 621
Drives: 18’c63s,15’macanturbo,14’ 991s
comes w/ runflats ?
I was just wondering if the new m3 came with runflats. My CA told me today that it did. I am from canada so i dont know if our m3 did come with runflats. In the brochure it says there is a runflat indicator so does that mean there is runflats?
lebreeze |
03-30-2008, 02:24 AM | #3 |
Your Mom
13
Rep 234
CA's are stupid.
Mine said that the car did not come with a spare cause the car had runflats. Um talk about not knowing what he is selling. I clearly corrected him and made him feel stupid. |
03-30-2008, 03:17 AM | #5 |
24
Rep 404
The M3 does not come with runflat tyres. It does have a tyre pressure monitoring system. I've had my tyre pressure monitor indicate a puncture three times in four months, when, in fact, there wasn't one. IMHO, what's happening is that the system alerts you when your current tyre pressure drops beyond a certain percentage of the pressure you "set" the tyres at.
In actual fact the system is not measuring tyre pressure at all, but tyre rotation speed, if I'm not mistaken. |
03-30-2008, 04:17 AM | #6 |
30
Rep 955
The E92 M3 has Direct TPMS, an easy way to tell is by the solid metal valve stems
I believe all 07 and newer BMWs have Direct TPMS Older cars had Indirect TPMS which measures the air pressure indirectly by monitoring individual wheel speeds and other signals available in the vehicle |
03-30-2008, 04:30 AM | #7 | |
1280
Rep 6,304
in europe, my car for sure, doesn't have anything in the wheels, the tmps is in ABS unit i think, just measuring circumference of the wheels and the difference between, and if its alarming.. you get an alarm.
F30.F11.E86.E90.E90.E36 |
03-30-2008, 04:36 AM | #8 |
61
Rep 924
Drives: Ford Falcon Ute, Ducati 1198S
There is a bit of wrong info here.
The E92 M3 comes with either FTM (Flat Tyre Monitoring) or TPM (Tyre Pressure Monitoring). In Australia we have FTM which as has been mentioned above simply measures change in wheel diameter through a change in wheel RPMs. You need to reset this each time you change the pressure in the tyres, the car does a short reinitialisation over a few metres and uses this wheel diameter to detect any change if a tyre deflated. TPM is standard in the USA as it is mandatory in all new cars over there, and has been since September 2007.
BMW E92 M3 6MT, G-Power SKII supercharged, custom exhaust with 100 cell cats and Remus Sport mufflers, Brembo 380mm BBK, BMW Performance steering wheel, LUX H8 angel eyes, CF CSL boot, Hamann CF diffuser, Vorsteiner CF lip, CF grilles, CF gills, CF bonnet vents, BMW Performance stripes, RAC RG63 wheels, Eibach lowering springs, camber modifications.
03-30-2008, 07:26 AM | #10 |
Moderator
7506
Rep 19,370
Anyone know why they chose to put a TPMS button on the dash for the M3, vs. having it only available via iDrive (or the dash computer for non-iDrive) in the normal 3 series? Is it just because they had an extra button with the DTC button gone, or is there something special about the M3 TPMS that makes the button necessary?
03-30-2008, 07:41 AM | #11 |
61
Rep 924
Well I check pressures weekly I suppose...No false alarms. In reality you only need to reset it if one tyre gets seriously deflated, but good practise to reset each time you check pressures.
03-30-2008, 08:02 AM | #12 | |
812
Rep 7,888
I beleive the Canadian cars come with the FTM not the TPM.I know 100% that my wifes 335 w 19's came with FTM and I am thankfull for that as I did not have to bother with sensors on her snow tire package and as I have a track setup coming for the M at least I do not have to bother with the sensors. |
03-30-2008, 10:14 AM | #13 |
124
Rep 4,145
No runflats for the M3. The other 3 series come with runflats standard. I believe all new cars must have a tire pressure monitoring system of some kind by federal regulation. I do not know details of this regulation. Maybe with runflats you do not need the pressure monitoring.
2017 F80 YMB.
03-30-2008, 10:26 AM | #14 | |
Moderator
7506
Rep 19,370
Many (most?) regions of the world only require the simpler FTMS, which BMW actually prefers for it simplicity. |
03-31-2008, 05:31 PM | #17 |
Rep 10
Yes Lebreeze, the CANADIAN M3 does indeed come with Michelin Pilot Sport run flats. The 2008 Canadian M3 has FTM (flat tire monitor), which is described in the manual as a system which detects pressure loss by comparing the rotation speeds of the four tires while the car is moving. The flat tire will change it's rolling circumference, thus resulting in a different rpm than the other three.
03-31-2008, 08:34 PM | #18 |
162
Rep 621
now i am confused. Why would only canadian m3 come with runflats????????????
03-31-2008, 09:17 PM | #19 |
Commander-In-Chief
2070
Rep 8,898
I can only assume he's being sarcastic? Michelin Pilot Sports or PS2s do not come in a runflat version, and if they did, it would mean very different suspension settings.
Greg Lake Oswego, Oregon, USA 2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450 Last edited by GregW / Oregon; 03-31-2008 at 09:34 PM.. |
03-31-2008, 09:29 PM | #20 | |
23
Rep 325
