BMW X3 Forum
BMW X3 Forum
      08-31-2016, 01:34 PM   #1
Kugaman1
18
Drives: X3 m sport plus
Permanent live in front fusebox
Hi all,
Im trying to fit a power magic pro for my dashcam.
It needs to be in the front fuse box.
Ive found a live circuit which powers off as soon as you turn off the car.
However, Im struggling to find a permanent live.....almost all of the fuses stay live for around 30mins after the car is turned off.
Problem is, how on earth do I find a front fuse that stays live all the time? Not sure how Im going to do it other than weeks of trial and error.......
Unless anyone on here knows which front fuses offer a permanent live?
Thanks in advance.
Polo088161610.00
      08-31-2016, 05:08 PM   #2
02420X3
63
Drives: 2011 X3 35i
Some who are looking for a permanently live connection use the power wire for the OBD-II socket.
      09-01-2016, 12:43 AM   #3
Kugaman1
18
Thanks buddy, will give that a go tomorrow!
      09-01-2016, 02:43 AM   #4
Crassus
United Kingdom
229
Drives: 19' G20 X3 20i & 19' M140i
Don't waste your time on the front fusebox. Use the one in the boot.
      09-01-2016, 04:56 AM   #5
PerryGunn
Idiot-in-chief
PerryGunn's Avatar
31
Drives: around: in: circles:
You should be able to tap into a permanently live wire anywhere in the car that you can find one (you can use an in-line fuse)
I've got notes on BMW wiring that say
Ignition Switch
position 0 - off
position I - accessory
position II - on
position III - start
In general:
(test first with a multimeter just in case it's different for your model)
Ground
- Brown
Unfused wires
- a solid red wire is always live
- a solid green wire is live in positions II and III
- a solid violet wire is live in positions I, II and III
Fused wires
- a red wire with a stripe of any colour, is always live
- a green wire with a stripe of any colour is live in positions II and III
- a violet wire with a stripe of any colour is live in positions I, II and III
X3 F25 LCI 30d M Sport
Alpina Roadster S
      09-01-2016, 02:21 PM   #6
Kugaman1
18
Thanks for the replies all...
I really need to run everything from the fuse box if at all possible.
Im going to try the OBD port tomorrow.
Thanks for the wiring info Perrygunn.....I will look at that tomorrow when trying the OBD port!
      09-05-2016, 05:59 PM   #7
A5PIN
Drives: 2012 X3 (F25) 3.0d M Sport
Originally Posted by Kugaman1 View Post
Hi all,
Thanks in advance.
Hi which location did you use for the switched live? I'm also wanting to install a dashcam but dont wont it live after the vehicle is stopped.
thanks
      09-07-2016, 02:35 AM   #8
Kugaman1
18
Hi mate, I used fuse 31 as an ignition live.
I think its for the seat heating.
      09-14-2016, 02:48 PM   #9
F30ed
71
Drives: F30 328i, X3 35M
terminal 30 and 30B in FEM should stay live all the time. I will check the location once I get home. What is exactly year/model is your car?
      09-15-2016, 01:36 AM   #10
Kugaman1
18
Its a 2016 model.
I used the OBD port fuse and it looks to have done the job!
Thanks anyway from a very cold, foggy Northern Scotland....
xbimmers
