08-29-2016, 01:29 AM | #1 |
Rep 1
M Performance Carbon Winglets Installation Question
Hey fellow M2 owners.
I have ordered the MPerformance carbon side and front winglets. (http://ind-distribution.com/ind/bran...ar-winglet-set) They come with plastic clips. I think there's 5 clips per side. They also come with pre-applied double sided tape. On the car there is no holes for these clips to go into, but on the winglets there are 5 holes. Does fitting these require drilling into the car or is the tape sufficient? For people who've had these dealer fitted, do they use the 5 clips in addition to the double sided tape? Does anyone have a photo of the underside of the carbon winglet to show how they clip in? Thanks |
11-25-2016, 04:52 AM | #2 | |
10
Rep 36
11-25-2016, 06:26 AM | #3 |
32
Rep 132
11-25-2016, 08:02 AM | #4 |
4178
Rep 3,075
Drives: 991.2 Porsche GT3, BMW E46 M3
Garage List 1987 BMW 325is [10.00]
2004 BMW X3 [6.50] 2018 Porsche 911 GT3 [10.00] 1974 BMW 2002tii [10.00] 2004 BMW M3 [10.00] |
Follow me on IG
Garage: 2018 991.2 GT3|2013 135i|2004 M3|2004 X3|1987 325is|1987 325i|1974 2002tii |
CommitConfirm474.50 AndrewC198910910.50 |
12-29-2016, 11:42 AM | #6 |
475
Rep 549
Drives: The Bus
Garage List 2017 Ford Focus RS [0.00]
1971 Mk3 Austin Min ... [0.00] 2013 MINI R56 GP [0.00] 2013 MINI R55 Clubvan [0.00] |
12-29-2016, 11:46 AM | #7 | |
37
Rep 116
*Edit* Google translate doesn't seem to work on a .pdf, at least not on my computer. |
12-29-2016, 12:31 PM | #8 |
460
Rep 1,133
I know what you mean about drilling into your car, but if it were me I would not trust just the tape, if they provide rivets, I bet you need to use them or one day you will discover that you are missing one of those expensive winglets.
12-29-2016, 01:18 PM | #9 |
179
Rep 295
12-30-2016, 10:23 AM | #10 |
37
Rep 116
Was able to get google translate to work..but that .pdf is just awful, I didn't end up using the instructions at all. Luckily it's really straightforward, no need to mark the holes or anything. Just use all the bolts that are already on the car to initially attach it, then drill the holes, and pop up in the rivets. Except the rivets are garbage, and I found much easier and more solid push tabs at O'Reillys for a few bucks. All in all, a pretty easy install once I realized the supplied rivets just weren't going to work.
12-30-2016, 04:31 PM | #11 | |
10
Rep 36
Could you provide the push tabs link @ O´Reillys ? thnks |
12-30-2016, 05:21 PM | #12 |
37
Rep 116
12-30-2016, 05:35 PM | #13 | |
475
Rep 549
Drives: The Bus
12-31-2016, 09:12 PM | #14 |
460
Rep 1,133
Just curious, did you pull on the winglets a bit to ensure you have a solid mounting with the push tabs? At 80 MPH or so the slipstream will be pulling on them. Are they the plastic type with expanding legs when the pin is pushed in?
01-02-2017, 05:57 AM | #15 |
37
Rep 116
I did tug on them a little before driving, they felt super solid. I've already hit 120 mph with the winglets on, no issues so far. The push pins I used were the plastic type that expanded, pretty sure that's how most push pins work. The ones I used were basically the same as the ones BMW used for the OEM rear diffuser.
01-07-2017, 03:46 PM | #17 | |
71
Rep 105
01-07-2017, 03:51 PM | #18 |
37
Rep 116
01-07-2017, 03:54 PM | #19 |
71
Rep 105
01-07-2017, 04:52 PM | #20 |
37
Rep 116
I installed the winglets with tape and the pre existing bolts, then the next day I drilled the holes and put in the push tabs I bought. You really can't mess up with the drilling, only downside is you can't take it off later.
01-07-2017, 10:12 PM | #21 |
32
Rep 132
