BMW X3 Forum
BMW X3 Forum
      08-25-2016, 01:34 AM   #1
Tjalle
183
Drives: X4 35i
Run Flats - it's strength also it's weakness.
I visited X1 threads and stumbled on a discussion re. RFT:s.
According to a person working for Continental AG, they are considered: "Money Makers used by suckers only" (and those forced by BMW ).
Reason is that STD tyres have a thin layer of steelreinforcement in sidewall, which enables the tyre to flex when a pothole.
RFT:s have - for obvious reasons - a strong layer of steelreinforcements, which will flex only 20% of STD, causing - often - the wall to crack.
This is something I seem to recall from X3 threads.
Also discussed here is that the solution, by many, seem to be "instant fix kit" with slime/gunk/sealent, compressor and "mending kit"- regardless if RFT or STD.
Obviously slime/mending kit does not work if major crack, but that seem to be rare on STD tyres
      08-25-2016, 09:07 AM   #2
mge92
SPEED RACER
mge92's Avatar
United Kingdom
375
Drives: BMW X5 M50d BMW M2 CS
Not necessarily. It makes sense what you said but since changing over to non-runflats I have only had blowouts and major cracks. When I had runflats, I would get the occasional nail but never a blowout which allowed me to always allowed me to continue driving.
2019 BMW X5 M50d Artic Grey | 2020 BMW M2 CS Misano Blue
Incoming - Ginetta G56 GT Academy | Incoming - BMW X5M Comp Oxford Green
RIP - 2020 Mini JCW GP Racing Grey | RIP - 2013 X3 xDrive28i Carbon Black
      08-25-2016, 11:19 AM   #3
Tjalle
183
Drives: X4 35i
Shit happens. I hope we will have more input.
      08-25-2016, 03:48 PM   #4
Pinewood
Pinewood's Avatar
United Kingdom
45
Drives: BMW X3 30d M sport LCI
My experience has been 2 punctures in 6 months of owning the X3. I have never had a time whereby I suffered more than 1 puncture in a year (in 33 years of driving).
The cause is open to debate, but for me the rft's increase the occurance.
On another forum many moons ago, several owners experienced cracked rims on 18" alloys with rft's
The problem was resolved by moving to non rft's
2014 X3 30d Lci M Sport in Black Sapphire. Pro Nav, Black Leather,Adaptive Xenons, Extended Storage, Lighting Package, 19" Staggered (622M) summer wheels, 17" style 304 winter alloys
      08-25-2016, 08:30 PM   #5
poiuytre111
17
Drives: 2014 X3 sdrive 1.8 & E81 120D
Yes I have a friend with a 630i convertible who has changed 2x wheels due to cracks and this effect is often commented as being due to the wheels not being strong enough for the extra shock loading transmitted through stiffer RFT sidewalls from UK potholes. BMW paid for both wheels after haggling. I half expected the same issue to arise with my 2007 E81 but it hasn't.
      08-26-2016, 12:26 AM   #6
Tjalle
183
Drives: X4 35i
So, possibly, not only increased risk for punctures, but also damaged rims - which makes sense.
      10-28-2016, 06:26 PM   #7
Pinewood
Pinewood's Avatar
United Kingdom
45
I double checked the issue of warranty with BMW dealer only today. Advised I wanted to change my staggered summer set of tyres from Pirelli P zero's rft to Pirelli rosso's non rft and he said there is no issue with that, as long as I changed all 4 together.
He said many of his customers change over after the OE tyres have worn away.
      10-29-2016, 05:45 AM   #8
poiuytre111
17
Although I have had no "flat tyres" as such in my 7 years using run flats, I have had several tyres develop bulges, necessitating replacement once spotted. I had suspected that this was happening more often than with normal tyres and the comments above explain why this might be. One more reason not to like RFT.
      10-29-2016, 06:25 AM   #9
MichiganMike
Drives: 2016 X3 xDrive 35i
2020 X3 M40i  [0.00]
2016 BMW X3 35i  [0.00]
"A recent study by J.D. Power found that people were replacing their run-flat tires an average of 6,000 miles sooner than owners using standard tires. Opinions differ on why this is, but one theory is that tiremakers put a soft tread compound on a run-flat tire to counter the hard ride. A side effect of the softer compound is a shorter tread life."
The J.D. Power study found that "customers with vehicles equipped with run-flat tires are nearly twice as likely as those with vehicles equipped with standard tires to have to replace a tire due to a flat or blowout."
"Run-flat tires are more expensive to replace. A 205/55R16 run-flat tire at a local shop in Santa Monica, California, costs $239. The standard tire equivalent costs about $174, a $65 difference per tire. Also, many run-flat tires cannot be repaired and often need to be replaced in pairs."
http://www.edmunds.com/driving-tips/...-a-primer.html
In short, run-flat tires typically cost about 40% more and must be replaced perhaps 20% sooner than conventional tires. Run-flat tires sound like a boon for the tire industry.
      10-30-2016, 04:08 AM   #10
plymjack
Nuclear Chief of the Watch
plymjack's Avatar
United Kingdom
120
Drives: X3 (F25) 2.0D, i3 BEV
If your looking to save money then dont buy a BMW ..
Runflats do what they say and can help in many situations - as does the gunk n pump option to repair tyres too.
I have had to replace a tyre due to damage on average once a year for the last 30 years and runflats have made no difference to that, they would have helped on the 4 or five times I had to change a tyre at the road side - which would be very hard to do on a car the size of the X3.
So its just a case of balance - are RFTs worth the extra cost and reduced performance - probably.
BMW i3 (BEV) 2014. . Capparis White. . Park Assist, Comfort Access, Enhanced USB
BMW X3 (F25) xDrive20d SE 2017. . . . Oyster Leather . . 8 Speed Servotronic. .RFTs. . Electric Seats
Canon 70D 500mm, 85mm, 40mm, 24mm
Sony QX10 & GoPro Hero 3
      10-30-2016, 04:47 AM   #11
Tjalle
183
Drives: X4 35i
What pisses me off is that in Germany, RFT:s are a no-cost option, while in Sweden RFT:s are mandatory - unless you haggle with dealer.
My history is 4 tyres in 40 years
For me - after two years with lowered vehicle and RFT:s - I will go to "STD" tyres - Michelin Super Sport, when current 20" Pirelli P Zeros are done.
      10-30-2016, 07:09 AM   #12
Pinewood
Pinewood's Avatar
United Kingdom
45
My main issue with RFT's is the ride quality and noise they generate over imperfect road surfaces (which is most of the UK). When I had a 5 series, the change over to normal tyres improved things immensely.
I'm hoping for similar improvements with the X3 come spring 2017
      10-30-2016, 08:25 AM   #13
pokerface
pokerface's Avatar
432
Drives: F25 X3 N20 / F80 ZCP
I would rather my wife and kids be able to soldier on with RFTs than be stranded somewhere waiting for a tow. Ride has improved on rfts from the first generation (e90)
      10-30-2016, 11:39 AM   #14
Pinewood
Pinewood's Avatar
United Kingdom
45
Yes that is true, but not to my tastes. I find tyres are such a personal choice depending on who drives and the types of journeys undertaken. Interesting that the "M" derivatives in the UK do not come with rft's but us lesser mortals are forced to use them.
      10-30-2016, 11:44 AM   #15
Tjalle
183
Drives: X4 35i
Yes, the X4 M40i comes with non-RFT Michelin Pilot Super Sport - even in Sweden, which is what I will buy when current tyres are done with.
      10-30-2016, 02:05 PM   #16
Pinewood
Pinewood's Avatar
United Kingdom
45
I do hear good things about the Michelin pilot supersports. Will take a look as my heart was set on the Pirelli Rosso's that Peter_R has fitted to his steed.
      10-31-2016, 02:40 AM   #17
Tjalle
183
Drives: X4 35i
Pinewood, I seem to recall that you have 19" - I believe Michelin PSS are made only in 20" and 21". Michelin has adapted the X4 M40i 20" tyres together with BMW M Performance. I believe my lowered vehicle has about the same handling performance as M40i and I already have the rims.
I.e. unless you are very sensitive and can afford both rims and tyres, I would suggest to copy Peter.
Another alternative is Hankook Ventus S1 evo, which in tests last year by Auto Bild with Super Sport Tyres, got best verdict for driving/braking in the wet, which rumours say is not uncommon in the UK .
      10-31-2016, 03:59 AM   #18
Bimar
Bimar's Avatar
800
Drives: Bmw X
hope next generation X3/4 have no Run-Flats or at least you can opt out and also have a spare wheel option like the X5/6.
      10-31-2016, 05:38 AM   #19
Pinewood
Pinewood's Avatar
United Kingdom
45
correct - i have 19" staggered setup - Peter_R is my motoring guru :-)
      10-31-2016, 03:53 PM   #20
Peter_R
Air Vice Marshall
Peter_R's Avatar
United Kingdom
256
Drives: X1 LCI xDrive 2.0i M Sport
@Pinewood
Whilst you are under warranty and also if you take out the extended (Mondial) warranty I would suggest you use the BMW * rated tyres. The NON RUN FLAT ones (Pirelli's) are star rated. This would prevent any embarrassing suggestions/questions by BMW in the unlikely event of you getting drive train problems.
As you may have noted in a previous thread, BMW recommended and even wanted to quote me a price for the non run flat Pirellis I eventually fitted.
2007 BMW 325d M Sport remapped (E91).
2012 BMW 320d Sport (F31).
2013 BMW X3 xDrive 30d M Sport (F25).
2020 BMW X1 xDrive 2.0i MSport (F48).
2022 MB EQB 300 4MATIC AMG Line Premium
      10-31-2016, 07:44 PM   #21
brissim
86
Drives: X3 30d (2011 F25) - now sold
I take heart from the fact that the current model F48 X1 (launched only a year or so ago) has a space under the boot floor suitable for a spare tyre - albeit a space saver spare. Not sure about the soon-to-be-released X2 but I hope there is a trend developing here. Its all about choice.
Tony
      12-04-2016, 12:39 PM   #22
JRJ17
Drives: X3 Msport 2.0D
Hello, I've recently took delivery of a new X3 MSport 2016 and its a fantastic car, however it has 20 inch wheels with Pirelli P zero run flat tyres (which I've never had before) and you can feel every imperfection in the road. Whilst I appreciate it has sports suspension the ride quality is not great as you feel every bump. I'm considering changing to non flats, will this improve the ride?
Please let me know if you have had a similar experience and the non run flats helped? Along with a tyre repair kit.
Thanks
xbimmers
