BMW X3 Forum
BMW X3 Forum
      08-18-2016, 07:16 AM   #1
mac110808
Drives: X3(F25) 2.0d SE
Exclamation Help! Brake Service Reset
My brake service reset indicator on my X3 is driving me crazy! Replaced front discs and pads with Brembo units (great quality and fit) and a new Pagid brake sensor. All seems good except that the reset script has changed from red to amber and states "reset impossible". Any ideas? Possible faulty new sensor?
      08-18-2016, 12:33 PM   #2
sirk77
Drives: F25 LCI 20d
You can reset by ista/rheingold(using e-net interface).
      08-18-2016, 03:35 PM   #3
mac110808
This sounds a bit too complicated for me but thanks anyway mate.
      08-21-2016, 11:05 AM   #4
BeeMdblU
BeeMdblU's Avatar
452
Drives: F86, F25, G16
Had the same issue on my F30 after doing a full brake job, the tech said it was a faulty sensor but I'm not sure they had changed It at all.
      08-22-2016, 10:22 AM   #5
TheChoseN
Drives: X3 F25
Hi,
Always use OEM brake pad sensors. You can also put 480 Ohm resistor for test, than
you can reset brake interval by dash. Turn ignition on, close driver door! (important), press and hold button on cluster until you will show service icons, release button select front brakes and press and hold button on dash until message "Reset?" appear, than release button and press it again and hold until you will see progress bar. After that you can release button
Best regards!
xbimmers
