08-15-2016, 11:09 PM | #1 |
31
Rep 146
Fender rolling/pull for fit agressive offset wheels
Has anyone done it on the M235i?
Do you guys have pictures of the procedure? I'd like to fit a 19x9.5" ET39 wheels on the back and 19x8.5" ET35 on the front just need to see how hard would this process be. |
08-16-2016, 11:09 AM | #2 |
330
Rep 1,084
I've rolled my front fenders. No experience with rears. It's really easy to simply fold the fender lip flat on the inside. Have a paintless dent repair guy do it to make sure it comes out perfect.
rwalker@rwalker.com (I really dislike Private Messaging)
08-16-2016, 12:10 PM | #3 |
451
Rep 845
Had mine done in the front too. Make sure you get someone good to do it -- if they press the front inner lip too hard, you might end up with paint cracking. However, you can fold it a fair bit and get a good amount of clearance without any chance of damage (and no outward appearance changes). It's a good mod if you want to squeeze 255s in the front of the car.
08-16-2016, 01:26 PM | #4 |
715
Rep 1,541
No need to do the rear as it's already flat from the factory (unless you want to pull it also).
Had my front done to prep for my coilover/square setup. Just make sure you go to someone that has experience with it. Luckily you don't need to cut the fender liner on our cars like I've had to do with my previous cars.That's because our fender tabs are way up in the wheel well. This also means you don't have to worry about the fender getting dimpled/waved by the tabs when rolling it. The roll will cause the fender to be pulled very slightly because of the pressure applied with rolling. Most people will never even notice it.
