08-14-2016, 10:42 AM | #1 |
92
Rep 223
Bird S***
I stupidly parked under a tree that I could hear and see was full of Starlings.
Yes, I know but even I can't think why I chose not to move but whats done is done. Came back to car next day and front near side of bonnet and bumper was plastered in s***, soaked it and washed it off when I got home that evening and it looked fine. Washed and polished car today and the S*** I can only assume in those few hours has "burnt" the lacquer and as much as I try I cannot get it out. I've tried taking a photo to show you but all you can see is the reflection of the sky but when standing next to car there must be 25+ stains(?) Help me please, what can I do, who do I go to, is there a way out of this. Cars Black Sapphire Metallic. Thanks in advance for any advice, Mark.
2015 F32 435d xDrive MSport, Stripes!! + some goodies
08-14-2016, 10:57 AM | #2 |
10996
Rep 32,881
Some decent compound and either a lot of elbow grease or a machine polisher will get it out.
http://www.halfords.com/motoring/car...compound-450ml http://www.halfords.com/motoring/car...t-car-polisher |
08-14-2016, 11:04 AM | #3 | |
Beemer Heaven
462
Rep 2,941
Drives: BMW M4 Competition
Garage List 2018 BMW F82 M4 Comp [0.00]
2017 BMW F30 330d M ... [0.00] 2014 BMW F30 330d M ... [0.00] 2009 BMW E90 330d M ... [0.00] 2006 BMW E90 330d M ... [0.00] 2002 BMW E46 325i S ... [0.00] |
Take it to a good Bodyshop or detailed and they can heat up the area and that sort of resets the laquer. Once cooled, it will just need a quick top polish and job done.
Scott
2018 BMW M4 Competition 2019 Mini Countryman Cooper S : 2008 Mini Cooper |
08-14-2016, 11:19 AM | #5 | |
396
Rep 1,235
Found a lot of swirls on doors after taking the car to a local cheap hand car wash a few weeks ago, but the combination of Meguiars UC and cordless polisher restored Black Sapphire paint to the factory condition. Very easy job to do and it is enjoyable. |
teaston10995.50 tmdals0213210.50 |
08-14-2016, 11:42 AM | #6 | ||
10996
Rep 32,881
tmdals0213210.50 |
08-14-2016, 12:27 PM | #7 |
92
Rep 223
Ok thanks, I'll give it a go.
Just a couple of questions though. Is this compound like T-Cut? If I go careful with the electric polisher, is there any chance I can cut right through paintwork or is the compound not abrasive enough for that. I assume I'll have to put a coat of wax on afterwards, should I buy extra pads for the polisher and use that as I've only ever polished a car by hand. Thanks again. P.S. For £50 ish I'm happy to give it a go, never know I might find it therapeutic like a few of you do but if I'm not too sure I'll go the detailer route.
08-14-2016, 12:51 PM | #8 |
680
Rep 2,444
Drives: 2018 630iGT sport
It will machine polish out.
I have not idea what the other guy above is on about. You machine polish to remove marks, it doesn't add any (well, not unless you're a conplete donkey with a DA!) Where are you based? Want me to do it for you? |
08-14-2016, 01:18 PM | #9 |
3105
Rep 7,032
Drives: 335xd Msport +
Had simillar on my BSM F30 after going on hols to find two large lumps of shite on my car.
Left a burn mark on the roof. Someone on here suggested Meguairs Scratch X. Did the job Found it helped to put a yellow crayon Mark # around the damaged area as it was very easy to loose aim and end up working on the wrong area.
08-14-2016, 01:37 PM | #10 | |
92
Rep 223
08-14-2016, 01:59 PM | #11 |
150
Rep 403
Bird shit is evil. A seagull crapped on the bonnet of my metallic black cayenne when I still owned it. Was literally on bonnet for no more than 1 hr I know that because I was in short stay parking and wiped it off with some cloths and water I had in boot.
That time was enough for it to permanently burn into lacquer I called on services of detailer I use and he sorted it. Took a couple of hours and some hard work with a few compounds and a DA. |
08-14-2016, 02:17 PM | #12 |
773
Rep 1,643
Drives: 2020 Audi SQ7 & 2019 AM DB11
Location: The Democratic Peoples Republic Of South East England
You only need to heat the area and the etching will absorb itself. Check out you tube for a how too.
ukbeemerboy462.00 |
08-14-2016, 02:43 PM | #13 |
741
Rep 2,511
If there is a suitable amount of protection on the car it may just be etched into the wax. I'm always amazed by the amount of imperfections I can remove from my well waxed car by claying alone.
If you go down the DA route I would steer clear of the cheap Halfords one suggested. My dad had this to use on his boat... Fine for buffing up gel-coat but I'd prefer something better on a car. That 'fluffy' pad will cut quite hard. I use a similar microfibre pad to polish very hard glass! I polished my car and my wife's with a DoDo Juice Buff Dady Pro using their lowest cut Supernatural Finishing Pad with their lowest cut compound Supernatural Micro Prime. Flawless results with little risk of paint damage.
Driving i4 M50 (G26)
Previous 340i Touring MSport (F31) |
08-14-2016, 03:33 PM | #14 |
Beemer Heaven
462
Rep 2,941
Thank you
Scott
08-14-2016, 03:59 PM | #15 |
10996
Rep 32,881
That's if it is etched into the lacquer. As said above it could just be etched into the current wax/sealant, in which case you'd want to remove the coatings before doing the heating method anyway!
08-14-2016, 04:05 PM | #16 |
492
Rep 1,503
Agree, I tried to cut out a mark left by bird muck and it wouldn't completely come out. I had to let the sun harden the paint again before attempting to remove the mark it left so going straight in with a polisher is not a good idea.
08-14-2016, 04:18 PM | #17 |
10996
Rep 32,881
Sun harden the paint?! Why would the paint be soft?? Even if it was how would heat harden it? Have you been smoking crack?
08-14-2016, 04:28 PM | #18 | |
3105
Rep 7,032
Sounds strange but have to agree. When mine got done attacked it a few days after and the stain came out . Not sure if it's sun hardening the paint or oxidising etc the stain allowing easier removal
08-14-2016, 04:29 PM | #19 |
492
Rep 1,503
The bird muck had made the paint / clear coat soft, it would mark very easily and therefore not polish out. The heat from the sun seemed to make the paint hard again and I was able to polish it out. No crack smoked here but I'd check what's in your pipe if I was you. Been spraying classic cars to concurs standard for years so i have a little experience with paint. I'm not totally up to date on modern car paint but the heat or time did something that allowed me to get the finish back.
08-14-2016, 04:32 PM | #20 | |
10996
Rep 32,881
08-15-2016, 02:12 AM | #22 |
194
Rep 478
