08-11-2016, 01:04 PM | #1 |
132
Rep 556
Small chip in Laminated Anthracite Wood Trim
I have a small chip right under the iDrive controller. Scratch-X won't help this one. Any suggestions ?
Thanks
2016 428i X Drive. Mineral Gray Metallic. Born 2/2016, Munich Factory.
Member BMW CCA Since 2008 Last edited by NYF32DRIVER; 08-11-2016 at 02:37 PM.. |
08-11-2016, 03:01 PM | #2 | |
4061
Rep 4,983
<b>2023 M5C SRG|Aragon || 2018 Macan GTS</b>
2019 F90 Comp MBB|Black (sold) 2018 F80 ZCP TB|SS (sold) 2015 F30 335 AW|CR (sold) 2015 F31 MG|CR (sold) 2011 E90 JB|Oyster (sold) |
08-12-2016, 07:45 AM | #3 |
132
Rep 556
Not an option. It's a small chip. Looking for ideas about repairing.
Member BMW CCA Since 2008 |
08-12-2016, 07:55 AM | #4 | |
4061
Rep 4,983
Is the chip deep? Does it go through the clearcoat? If the wood trim itself below the clearcoat is damaged, I'm not sure how to repair that, and would recommend a vinyl wrap or a new trim piece all together. If it isn't too deep, you could remove the panel and polish it down to smooth it out some.
08-12-2016, 08:01 AM | #5 |
714
Rep 1,329
I've not tried it, but my initial thought would be to fill with clearcoat touchup paint then wet sand, polish and buff???
Not sure the materials are compatible though.
2002 325i sport - sold 2009 135i M sport - sold
2009 550i M sport - sold 2005 M3 6MT Jet Black w/Cinnamon 2016 F30 320i ZSP 2003 E46 325it ZSP 5MT |
08-12-2016, 08:03 AM | #6 |
8245
Rep 16,088
08-13-2016, 10:06 PM | #7 |
508
Rep 2,981
Drives: 2013 BMW F30 EBII
That should work depending how deep the scratch is. I would fill the scratch with clear until the filled area is slightly above the surface of the scratch...then wet sand with 600, then 1000, then 1500, then possibly 2000 grit paper...polish and hope there is no haze...
Drives: 2011 Porsche 958, 1965 Chevy C10, 1988 Porsche 944 Sold:2010 e90 Montego Blue, 2013 F30 EBII, 2013 Tangerine Scream Ford Focus ST, 2006 Mini R50,2004 VW Touareg, 2012 Camaro Convertible, 2008 Porsche 911 Convertible, 2007 Corvette, 2004 BMW e64 convertible, 2000 Dodge Dakota, 1999 Ford F150, 1999 Porsche Boxster, 1999 Ferrari Modena, 1992 BMW e36, 1990 Nissan 240sx, 1979 Celica, 1974 Mustang II
My Build Thread |
08-14-2016, 08:43 AM | #8 |
8245
Rep 16,088
08-14-2016, 09:34 AM | #9 | |
508
Rep 2,981
My Build Thread |
08-14-2016, 09:47 AM | #10 |
8245
Rep 16,088
I've not done trim, but on pesky little scratches in the paint I've found Trizact 3000 and 5000 work so well that rubbing by hand with Menzerna 2000 and 3500 make for an invisible repair with minimum effort. I use an airbrush to fill the scratch with clear coat, waiting a day for it to fully cure. The sanding and rubbing out takes maybe 15 minutes start to finish.
08-14-2016, 12:59 PM | #11 | |
508
Rep 2,981
My Build Thread |
08-15-2016, 06:08 AM | #12 |
714
Rep 1,329
I like those 3M wet sanding pads too. They are so fine the effort of polish and buff is significantly reduced.
Only other tip is to let the clear dry completely. If it is still soft, a dip will be visible instead of getting a flat result. Real deep fills will take a long time to dry.
08-15-2016, 08:42 AM | #13 |
253
Rep 1,003
Drives: 16 340i, 15 X3d, 91 318i
Don't bother with trying to wet sand on an interior trim piece, that's a recipe for disaster if you get it wrong or if you make a big mess inside the car - dust, grit, etc.
Since you're looking at somehow filling the chip, take a look at Langka and Dr. Colorchip. With the blob eliminator you can smooth over the touch-up paint (clear or color) very easily. I just started out giving Langka a shot and it is very forgiving to work with, and doesn't take much effort at all. |
08-15-2016, 10:03 AM | #14 | |
508
Rep 2,981
My Build Thread |
08-15-2016, 10:22 AM | #15 |
8245
Rep 16,088
