08-11-2016, 10:27 AM | #1 |
517
Rep 542
Auto On Headlights/LED turn signals error
Hi everyone,
I have an ///M2, but I figure I'd post here, as the sample size will be much larger... I installed a set of LED turn signal bulbs. They function fine (no flickering), and look great. However, I have noticed an unusual interaction with my headlights. I keep my headlights in the "A" position (AUTO ON, dial all the way to the left). In the morning, I have noticed that sometimes (although not consistently), the headlights stay on. I park my car in my garage, so when I first start up and drive out, my lights are on. But they sometimes don't turn off (again, NOT consistently), even in broad daylight. And when this does happen (lights fail to turn off), after several minutes of driving, a warning message appears via iDrive. I will paraphrase the message..."Warning, Lighting Malfunction, Drive with Care". All the lights continue to function normally, and when I switch to the "OFF" position, wait for a minute or two, then switch BACK to "AUTO", the headlights do indeed stay off in the daylight. I highly doubt its a dirty sensor (rear view mirror), or even a malfunctioning sensor. I assume it has something to do with the aftermarket LEDs. But from what I've read, most issues with LED's are more obvious (like flickering). Just wondering if anyone else has experienced this... Thanks for any info -c
2016 BMW M2/LBB/6MT/Exec Pkg
2009 Acura MDX-stock 2008 Acura RDX-stock 2005 Honda S2000-mostly stock 1994 Nissan 300ZX Twin Turbo-barely stock |
08-11-2016, 12:49 PM | #2 | |
2865
Rep 3,842
The error message might be caused by the LEDs not drawing the correct current, the car may think that a bulb is defective. I've never seen this error message. I was very careful to buy LEDs that draw the correct current. What type of LEDs do you have installed? |
08-11-2016, 01:36 PM | #3 | |
517
Rep 542
https://www.aliexpress.com/item/2Pcs...599737708.html I may just get another set by another manufacturer, as they are rather inexpensive, just to see what happens. -c
08-11-2016, 01:50 PM | #4 | |
2865
Rep 3,842
08-11-2016, 06:04 PM | #5 | ||
517
Rep 542
-c
