Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Rear O2 Sensor Wires
      08-08-2016, 05:04 PM   #1
ferocity02
Drives: 2013 135is
I changed my rear O2 sensors awhile ago and am wondering if I swapped the sensors on accident. I am getting the following codes:
2C6D "lambda probe behind catalytic converter, aging"
2C73 "lambda probe behind catalytic converter, signal"
I checked the wiring and pins at the DME and it looks good. The sensors seem responsive in INPA. I do not have DPFix installed. I do have DP's but these are not the typical DP codes.
Anyone know which sensor plugs into which DP?
Thanks!
2013 135is DCT Carbon Black Metallic
      06-07-2018, 04:24 PM   #2
Franzein
Franzein's Avatar
23
Drives: E90
Ever figure out the 2c73 code I would like to know thanks a lot
      05-16-2019, 09:28 PM   #3
matreyia
36
Drives: 335i Convertible Montego Blue
Rear sensors only go on one way. Can't mix them if you tried. N54 335i.
