Stack jb4 with Cobb ap
08-08-2016, 01:14 PM | #1 |
Rep 53
I had a Cobb v3 ap and wanted to stack jb4 on top of it for methanol but I can't seem to get them to work along with each other. Running ots stage2+fmic aggressive on Cobb and have the jb4 on map 5 auto tune and my engine just stutters and stalls, anyone have any suggestions? I've tried looking for a backend flash but the only one I found for Cobb was the single turbo map
08-08-2016, 01:35 PM | #3 | |
Rep 53
08-08-2016, 01:48 PM | #4 | |
2134
Rep 3,554
Yes you would need a BT cable and the *********** software to do the backend flash or MHD and cable. |
08-08-2016, 03:00 PM | #5 |
146
Rep 1,201
You shouldn't be running that map with a JB4 on map 5. If you had read up on it, you'd see that the back-end flashes are what you should pair up with the JB4 as a non-advanced user. Go read the JB4 threads on the other forum to see how you're supposed to run JB4 stacked. There's a few menu options to set.
And if your car is running bad on map 0; then you installed the JB4 wrong. And I'm not certain if back-end flashes support Cobb anymore. It's old and deprecated now.
'08 E90 w/ just boltons
'09 Z4 sDrive35i w/ just boltons Last edited by Sered; 08-08-2016 at 03:15 PM.. |
fuuuudom2.50 |
08-08-2016, 03:04 PM | #6 | |
Rep 53
08-09-2016, 12:17 AM | #9 |
Rep 53
Update: turns out the jb4 g5 I have is the ISO version so map 0 isn't truly a bypass map. So I can't run the two together while the jb4 is still installed. Just going to uninstall and sell the AP since I liked the jb4 more anyways. Thanks for the help!
08-09-2016, 06:56 AM | #10 |
146
Rep 1,201
Not sure I understand that. Putting the JB4 in map 0 disables the JB4. Map 4 is the bypass map.
'09 Z4 sDrive35i w/ just boltons |
08-09-2016, 09:00 AM | #11 | |
Rep 53
08-09-2016, 09:03 AM | #12 |
261
Rep 1,093
You can easily stack the two. It's no different than stacking it with any flash. JB4 does not know or care if you're DME is flashed by MHD, Cobb or BMW. You just need to read up on the latest JB4 settings (and be on the latest firmware). You don't have an off the shelf BEF like for MHD and BB but if your happy with the Cobb tune and just want the jb4 for meth no changes are needed to the flash. Just set the JB4 settings properly so that it only controls boost (like all BEF set ups). The JB4 has to control boost for meth reference so you can't simply use the jb4 in full bypass. Just leave the Cobb tune as is and tune the boost curve with the JB4 which is probably the easiest thing to do since it's ISO and you just plug numbers in (vs load based like a flash).
08-09-2016, 09:38 AM | #13 | |
Rep 53
08-09-2016, 03:34 PM | #14 |
127
Rep 865
Drives: BMW X3 35i, Porsche Macan S
Just ditch the Cobb and get MHD for JB4 back-end flash.
MOTIV 750 ST | MOTIV PI | 100% E85 | Fuel-it Stage 4 LPFP | MOTIV Boost Box + MHD Protune | Quaife | Öhlins | Brembo | Akrapovic
08-09-2016, 04:36 PM | #16 |
BimmerPost Supporting Vendor
24199
Rep 190,807
When stacking use backend flash not the OTS maps
csu872134.00 |
08-09-2016, 04:39 PM | #17 | |
Rep 53
08-09-2016, 07:36 PM | #18 |
127
Rep 865
It will not affect Alpina flash. Go over to N54tech and read MHD sticky to answer your questions.
08-11-2016, 07:10 AM | #19 | |
146
Rep 1,201
Those will be difficult to find. The Cobb is obsolete and no longer supported as far as I know. You don't need a BT cable to flash via MHD.
08-12-2016, 02:18 PM | #20 | |
Rep 53
08-12-2016, 05:38 PM | #21 |
24199
Rep 190,807
Post on N54tech.com or contact Terry for these maps ... Not sure if he still supports Cobb
08-13-2016, 10:46 AM | #22 |
65
Rep 554
Drives: E92 335i 6MT
I have some older IJE0S cobb BEF files for E85, Terry stopped supporting them when MHD came out though.
