08-08-2016, 10:22 AM | #1 |
1390
Rep 2,336
Dyno Results: Baseline and with Active Autowerke mid pipe
Featured on BIMMERPOST.com |
9
schnell325889.50 DLSJ5500.50 M3 Adjuster7904.50 Yellowflash21369.50 M3CLESS23.00 dkhm31880.50 Seagull287.50 Powaup1253.00 INDVDL///M810.50 |
08-08-2016, 12:10 PM | #4 | |
1390
Rep 2,336
Thanks guys. Let's just be clear that my Dyno Dynamics is corrected to show more or so what a Dynojet would read. I will post up the uncorrected(heartbreak) numbers shortly. So if you understand how the dynos function the 490 run was really more reflective of BHP. I know many have varying opinions on this but this is how I see it. That said this is spot on to BMW M's claimed 493bhp. The torque is what impressed me! It is certainly over the rated #. As a note my car got about .2km of break in. From The Welt showroom to outside parking lot. Then the engine was driven quite hard. I avoided hard acceleration on turns and did not spin tyres for first 1500km to seat the differential properly. In a straight line on Autobahn it was balls out though
08-09-2016, 12:22 PM | #9 |
1941
Rep 1,552
Awesome!
2020 M2 CS, 2018 M3 CS, 2016 M4 GTS, 2013 M3 LRP, 2011 1M, 2011 M3 GTRS3, 2004 M3, 2002 M3, 2000 M Coupe, 2002 M5, 1997 M3, 1988 M3, 2022 STO, 2020 Urus, 2022 TRX, 2022 392, 2021 SVJ, 2018 Performante, 2013 Gallardo 550-2, 2012 Gallardo STS, 2018 R8 RWS, 2012 R8, 2017 G550 4X4^2, 2015 GT3, 2015 Continental GT3R, 1971 Bronco
08-09-2016, 12:58 PM | #10 |
1390
Rep 2,336
No. The lock rings are secured for lowest setting and maintains corner balance. When you go back to higher setting just go past the high point and install c clip, then bring the spring collar up to c clip. Balanced at the high point as well. I do not feel I will go back to high setting. It puts a lot of pre load on springs and the handling is compromised. The car is very balanced in lower position. Also, the front drops a bit more than rear so you are not looking up into the sky. Viewing is proper in lower setting.
Ahmed Jimmy86.50 Day Laborer1747.00 |
08-09-2016, 01:00 PM | #11 |
1390
Rep 2,336
08-09-2016, 02:42 PM | #12 | |
557
Rep 762
Thats nice to hear. So if I am at small flat track I just lower it down, then up again for Nurburgring wich need street setting? All this whitout alignment etc. I like that, very easy then as I would think I am happy whit BMW factory setting( street For Nur and track setting For flat modern track)
08-09-2016, 02:52 PM | #13 | |
1390
Rep 2,336
You can make the call on Nur setting. I did the BTG with it in street setting. I would like to try it in track setting.
08-09-2016, 05:05 PM | #15 |
1153
Rep 1,523
Take out the c-clips and lower it to the race setting. That's 15mm front and 7mm rear lower than the street setting. But leave you dampers rebound and compression alone in the street setting.
08-09-2016, 05:12 PM | #16 |
867
Rep 1,758
Drives: 30Jahre M5 plus a few more M's
Garage List 2022 BMW M5 CS [0.00]
2020 BMW M340i Xdrive [0.00] 2019 BMW M2 Competi ... [0.00] 2003 BMW DINAN S3 M5 [0.00] 2017 BMW 30 Jahre M3 [0.00] 2016 BMW M4 GTS [0.00] 2015 BMW 30 Jahre M5 [0.00] 1995 BMW M3 [0.00] |
Sorry for a potentially stupid question but how easy is to to change the ride height? Do it on the fly at the track or in your garage? Do you need to jack the car up at all? How long does it take?
Thanks in advance.
Current non-BMW's
20 Jeep Grand Cherokee 03 Cooper S (Maxi Tuned 50bhp) 60 Impala (43k orig mi) 15 Turbo S (Kobb tune and Kline exhaust) |
08-09-2016, 05:23 PM | #17 |
1390
Rep 2,336
Barry, no stupid questions, only stupid answers You will need some mechanical know how to do rear. The inner lower control arm bolts have to come out and the shock bolts as well. Not difficult, but would not be easy laying on your back. With a hoist it should be 1 hour max.
08-09-2016, 08:27 PM | #18 |
867
Rep 1,758
Thx appreciate the not stupid answer!
Looks like I'm going to need to get it lowered at the dealer and leave it like that. Don't know why this is taking so long for us here......the wait is painful now that they've started dribbling out.... How about extending the front lip?
Current non-BMW's
08-09-2016, 08:49 PM | #19 | |
1153
Rep 1,523
08-09-2016, 08:50 PM | #20 | |
21115
Rep 20,741
Drives: 2021 911 turbo
Can you elaborate on the drawback of having more "pre-load" on the springs? I figure, that regardless of the pre-load on the fully extended suspension, once the weight of the car rests on the springs, the springs will compress by the same total amount regardless of initial pre-load. The spring rate remains constant, hence a given load put on the spring should result in the same displacement. Am I missing something? Is it a concern with limited suspension extension travel?
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 08-09-2016 at 09:14 PM.. |
08-09-2016, 08:54 PM | #21 |
104
Rep 302
Drives: BMW M3
Great numbers!
Follow me on IG JonSnowM3
F80 M3 2016 F30 335i M Sport 2014 F30 328i M Sport 2012 Mini Cooper S MC40 Edition 2004 Mini Cooper S 2006 |
VCP1390.00 |
08-09-2016, 09:48 PM | #22 | ||
1390
Rep 2,336
