08-07-2016, 10:20 PM | #1 |
651
Rep 4,323
How bad are these plugs?
63k-I'm unsure what N55 plugs look like after that long?
CURRENT: 2017 RS3 (miss you guys)
SOLD: 2012 335i Mineral Gray M Performance Exhaust/Brakes/Suspension/LSD|Bav Stage 1/AMP||ER CP/IC/DP/OC | Dinan CAI/N55 PWG BIG TURBO|BMWF30.com |
08-08-2016, 12:47 AM | #2 |
793
Rep 1,628
They look great from what I can see...I can't zoom in on your pic, but it looks like you could have gone longer without a change. Did you notice anything after changing your spark plugs, i.e improved performance?
M4 in MG | 6 MT
oceanview207.00 |
08-08-2016, 08:14 AM | #3 |
1838
Rep 6,991
Drives: 15 F80 M3, 22 G01 X3 30i
Yep - neither too rich or too lean (even brownish color to the ceramic insulator around the electrode). With your mods, it's probably not a bad idea to do the change at that mileage.
FYI - I still don't have 21K miles on my F30 yet. You still liking life in Jersey?
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
08-08-2016, 10:19 PM | #4 |
Dejan
1753
Rep 4,197
Drives: 2018 Audi S3
Garage List 2013 BMW 335i [10.00]
2015 BMW 228i M Spo ... [0.00] 2013 Ford Focus (DD) [0.00] 2001 Alfa Romeo 156 [0.00] |
Ha funny, you and I are pretty much the same mods and tuners, and I just pulled my plugs today after ordering the BMS plug tool. They pretty much look like yours from what I can tell, and I am at 50,450 miles. The only thing I noticed is the prong on the bottom is starting to form away from the electrode and not straight.
I get low mph, low rpm bucking and jerking very light once in a while. Time for S55 plugs. Doing turbo swap Thursday with cryptocar. Well thats the plan anyway...
FBO-PS1 and stuff
08-08-2016, 10:38 PM | #5 | |
498
Rep 902
Drives: 13' F30 385xi VNV Speed Custom
Garage List 2013 Mercedes SL63 ... [0.00]
2010 VW Tiguan 2.0 ... [0.00] 2015 Tesla P85D [0.00] 2014 Mercedes S63 AMG [0.00] 2007 Mercedes GL450 [0.00] 1967 Ford Mustang [0.00] 2013 BMW F30 335xi [0.00] |
13' 335xi, ACF Tuned, ACF Stage 3 Turbo Kit (67mm),PDU PI, ACF Stage 4 LPFP, M-Perf Brakes, AEM CM10 Meth/Nitro, CG DR-1 + VS-1 3.5" Turboback, AFe S2 CAI+Ram Scoop, ER Chargepipe, Wagner EVOII Comp. FMIC, Stop-Tech SS Brake Lines, BMS Sport Oil Cooler Valve+Spacers F10mm R15mm, 19" Bridgestone Potenzas, KW EDC Coilovers, CF Seibon Hood + CSL trunk. Track:Pagid Race Pads, Stop-Tech Custom Pads Front+Rear Racing Tow Hooks
08-09-2016, 12:06 AM | #6 | ||
Dejan
1753
Rep 4,197
FBO-PS1 and stuff
08-09-2016, 08:40 AM | #7 | ||
651
Rep 4,323
Yeah the mileage seemed to be too far for waiting on the BMW maintenance light to go off (cheap bastards). Quote:
So yeah def not putting S55 plugs in it seems! I'm only pushing 16psi between 3000-redline, what are you gapped at?
08-09-2016, 09:39 AM | #8 | |||
498
Rep 902
08-09-2016, 10:40 AM | #9 | |
1838
Rep 6,991
Not surprising that your electrodes are beginning to wear down a little, but S55 plugs are probably not any stouter than N55s, just maybe a different heat range. I'd think stock would work fine again if gapped properly. Of course, that depends a lot on how many miles you've driven with your present mods.
08-10-2016, 10:07 AM | #10 |
3441
Rep 79,211
Most reason for changing of plugs on these cars is the gap increases over time. You could attempt to re-gap stock plugs but with 63K miles I think it's a fair time to change them anyway. Nothing makes a car run better then fresh plugs, especially if it's been a while.
cryptocar498.00 |
08-10-2016, 02:23 PM | #11 | |
BimmerPost Supporting Vendor
4922
Rep 115,999
20-30K is a good change interval. On the S55 they swapped my plugs after 20K which I was suprised. Mike |
08-26-2016, 08:46 PM | #12 | |
1658
Rep 4,897
Regular swapping them is just good for everything (car and your sanity). |
08-27-2016, 11:08 PM | #13 | |
IG @bmwF9xG80
3813
Rep 7,593
Luminous went with NGK N20 this time, way better heat range than S55 R32DBP also got some NGK N20 now as well replacing his S55 plugs cryptocar see Terry's latest update he is now recommending to avoid S55 plugs and get NGK N20 especially on upgraded turbos.
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
08-28-2016, 02:15 PM | #14 | |
498
Rep 902
The plugs we should be using though, which don't seem to be available at some of the major online retailers are these flex fuel plugs for the N20/6. I'm gonna call and talk to my parts guy and see if I can get some of these for myself. http://www.realoem.com/bmw/enUS/part...&q=12120042724 Edit: found them on TMS for $95 for a pack of 4 but that's pretty expensive, gonna keep looking.
FSociety3812.50 |
