Wastegate rattle how prevalent?
08-07-2016, 05:58 PM | #1 |
Rep 17
Hi guys Herb from New Zealand here and yes it's my first post.
I am in the market for a 335i and while I have read up on the waste gate issue to the point where I am pretty sure I understand what the issue is and how the bushes can be replaced, new arms installed etc, what I am curious about is how prevalent the rattle is in the first place? Does it happen to every N54 once it gets to a certain mileage? The reason I ask is my local dealership said they have only done two in the past 9 years. Now NZ is a small place but we have boat loads of secondhand Japanese 335i's in country so they are a pretty easy to find vehicle over here. Also If I have my bushes replaced what's the service life? Thanks in advance. |
08-07-2016, 06:20 PM | #2 | |
654
Rep 946
08-07-2016, 09:02 PM | #4 |
28
Rep 99
I am from NZ and have brand New OEM turbos and they rattle.
Best thing to do is make the car louder and faster and it will no longer bother you
N54 E91 Msport Wagon, VRSF 7"FMIC, VRSF DPs,
BMS OCC, BMS DCI, RB PC Valve, Wavetrac LSD, MHD Wedge , ER Charge Pipe, Nuke Performance Bov, MMP Inlets, Fuel-It Stage 2 Bucketless |
Chris@VargasTurboTech1933.00 |
08-07-2016, 11:42 PM | #6 |
232
Rep 723
They all rattle! Not a question on IF, but WHEN
My new ones (OEM), with supposedly beefier wastegate arm design does not (14K on them now), but plenty of people out their whose rattle right from the first minute. If you can live with, just let it be till it stops holding boost. I replaced mine at 110K, even then they were holding boost, just rattled like rattle snake all the effin time, and really loud.
2007 335i E92 MT | MFactory LSD | Diff Brace | MHD/Wedge Tuned| BL Coils | Stg2 lpfp BoostConcepts | VRSF DPs | VRSF 7" HD FMIC | DCI | VRSF CP | BMW SSK | Billstein PSS Coilovers | M3 Control Arms | Whiteline Rear SF Inserts | SS brake lines | Z4 35is Rotors | Hawk 5.0 pads | M219s + PSS | PE Mod -SOLD
2016 M4 F82 MT |
08-08-2016, 12:29 AM | #7 |
327
Rep 960
100k no rattle. avoid 07 and earlier the wastegate design changed after that and rattle is much less prevalent. 07 and earlier is almost guaranteed. I find it hard to believe new turbos are rattling.... seems like installer error / not adjusted properly. if not I'd be asking for a refund.....
if you go off people on forums the stats will be majorly squewed people don't post when everything is all and well..... |
08-08-2016, 06:06 PM | #9 |
654
Rep 946
So from this thread so far you can conclude that:
5 people agree that they all will rattle, And 1 person has been fortunate and/or oblivious and believes everyone else is wrong. Take that for what it's worth. |
08-08-2016, 06:43 PM | #10 |
Rep 17
Oh I have taken that "for what its worth" and I will listen to any further opinions, facts, evidence, that perhaps might show itself. I am now intrigued as to what if any design changes were made to the 08 and later cars, anyone know for sure what the changes were?
08-08-2016, 07:07 PM | #11 | |
93
Rep 606
08-08-2016, 07:27 PM | #12 | |
327
Rep 960
all i said was BRAND new turbos shouldnt be rattling which they shouldn't. I simply pointed out a fact the wastegate design was changed/improved in later cars. thicker actuator arm - not sure how this specifically helps but I believe this is an indication that the internals of the wastegate are different. failure rate is definitely alot lower with the newer design. edit: just reread your original post... guess I am saying you're wrong. they don't all rattle even when new as you claim. |
08-09-2016, 02:21 AM | #13 | |
Rep 17
08-09-2016, 09:11 AM | #14 |
Guest
Rep n/a
Drives:
08-09-2016, 10:21 AM | #15 | |
Slow.
3782
Rep 7,151
Drives: Single Turbo N54 on Meth!
A local guy got brand new turbos(under warranty) and they rattled from the stealership.
08-09-2016, 01:30 PM | #16 |
Guest
Rep n/a
Drives:
08-09-2016, 05:38 PM | #18 |
654
Rep 946
Exactly. The rattle can be improved in the tune, but it is inevitable. Eventually they'll stop building boost efficiently.
08-10-2016, 04:03 PM | #19 |
Rep 17
Ok guys that's great information, but to be honest it is making me have second thoughts on buying an N54 based vehicle. The N55 based cars are quite a bit more expensive and from what I can gather not quite as responsive to upgrades, but they are more reliable. Perhaps I should just buy a cheaper 07/08 car and rebuild the wastegates. This video shows how its done and it looks within my capabilities.
08-10-2016, 07:12 PM | #21 | |
Guest
Rep n/a
Drives:
Don't get how it's easy to scoff at something like "lifetime fluid" and still not understand that a moving/mechanical/non-lubricated part has a reasonable life expectancy. |
titium326.50 ritzzzzzwik232.00 |
08-10-2016, 08:14 PM | #22 | |
Rep 17
But that raises the question how long is a reasonable life expectancy? |
