Dinosaur procede and upgraded turbo & tmap sensor question
08-06-2016, 04:01 PM | #1 |
Rep 8
1st, I do realize the procede is "obsolete", but the car was built a few years back..BUT I'm looking for guidance anyways. Here's the scenario
Here's my setup: -2008 n54 335i -FBO no outlets or inlets -procede REV3 (yes dinosaur parts, I built her 3 years ago) lol -open flash tablet backend (procedeflash) -DCI -ETS 7" FMIC -forge DVs -Vishnu charge pipe -Vishnu/FFTEC flex fuel conversion kit w/ethanol sensor, I do run full e85 sometimes. -Vishnu/FFTEC LPFP (walbro 450) inline with OEM LPFP -AR catless downpipes -cat back -stock turbos my stock turbos are on their way out. I plan on running VTT GC LITES with VTT inlets and outlets. Let's assume I'd like to run a bit higher boost, how do I change that in the procede and what would be a "safe" number? I'm assuming if have to use a 3.5 or 4 bar TMAP sensor with BMS adapter. so is it just plug and play once I change the boost? Do I just change my target boost?? I'd appreciate any help, asides someone saying "MHD" or something similar. There's gotta be some guys on here that ran procede in the past or maybe still do run the procede. |
08-06-2016, 07:25 PM | #2 |
4ut0strd4
47
Rep 223
The only thing that comes to mind is uploading the upgraded turbo map off the site and setting boost to 20psi target. I have no idea if that map supports e85 or meth (I'll check on that) and without a custom tune you are probably limited to 20psi. I am really upset about actually running meth on my car since you basically need a piggyback unless you know how to hook up the meth kit standalone which nobody does at least in my area.. I am also definitely not running a jb4, so my only choice is MHD plus a standalone meth kit that I have no time to figure out how to make work for the most part.
08-06-2016, 07:52 PM | #3 |
4ut0strd4
47
Rep 223
So you can run methanol just have to use the correct firmware, but not e85 it looks like, unless of course you find someone that can custom tune the procede..
Here is how mine is set up and it runs great on stock turbos.
08 E92 335i Alpine White On Coral Red 6 Speed
BMS DCI+Aquamist METH Kit+MHD+VRSF+AR25 Resonators+HPF IC+AA CP+AA BOV+SSK+KWV1+Mfactory SMFW+550i/335is Clutch+BBS LM Reps+Diff Brace+M Performance Shift Knob+RB PCV+HPF OCC+NGK Mustang Dyno: 426whp/484wtq on E30/Meth/Stock Inlets+Outlets/Procede Only @ 18psi Current Estimate: 450/500 on E50 Custom EDC Tuning MHD Flash @ 21psi |
08-06-2016, 09:02 PM | #4 |
Rep 8
Thanks for the responses, but I'm all set up already to run everything I have in my list. I boost 19+ on ethanol already. My current setup all works together great. I have all the correct maps and back end flash.
But since my stock turbos are failing, I'm gonna upgrade, and if I upgrade, I was wondering if it's possible to boost..let's say..maybe 25lbs? Idk if it's even possible to go that high with the procede. I was thinking if I get the tmap sensor, that would allow me to boost more if I change the??(target boost)? I guess I'm just wanting to get the most out of upgraded turbos, while just integrating them into my current setup. |
08-06-2016, 09:30 PM | #5 |
4ut0strd4
47
Rep 223
Oh I see, I just don't think the boost scalar on the procede is set up for anything higher than 20psi, so probably not unless you find someone that can do custom tunes is what I am thinking.
08-07-2016, 07:41 AM | #6 |
133
Rep 4,764
still run procede here + meth + fuel flash. Runs great for what I do with the car. fuel flash I have is a one off Shiv created for ROM version I761S, which was by factory on my 04/2007 (not sure of full date range that ROM was used). But I don't go over 20PSI.
User settings: Firmware 111 ICUA, shows in proceed software under comms, firmware info as firmware series No. 105, firmware version info 111 05-23-12 6 MT Stage 3 Upgraded turbo map Procede User Tuning Interface Software 5.34 Map1 Map2 Max Boost 18 20 Start Boost 50 85 Start Ign Corr 60 0 Traction Thresh 100 100 Boost Response 100 100 OL Fueling 45 50 Auto Tune Agressi. 2 2 OverboostDel 20 20 CanClear 0 (off) AutoTuning Map1 1 (off) AutoTUning Map2 1 (off) Wastegate Position 80 Methanol Mode 0 (PPS) Speed Delimiter 1 (on) o2 Modifier 95 Injection Mode 34 (double value or reading of 90 will auto throw overflow code) - Aquamist flow sensor 806-428 Boost Gain Ctrl 45 Last edited by scottp999; 08-07-2016 at 07:48 AM.. |
08-08-2016, 09:32 AM | #8 |
Rep 8
this is probably a really stupid question, but id like some reassurance...
if i replaced the stock turbos with upgraded turbos and inlets and outlets, but left all my settings the same, would i feel a increase in power...assuming with my current setup i cannot go over 20lbs of boost.. basically if i bolted on the VTT GC LITES with in/outlets, would there be gains? will it be faster at 19psi on VTT vs Stock. hope thats clear enough..lol |
08-08-2016, 10:44 AM | #10 | |
Rep 8
i guess for now ill juat leave the tune the same, and upgrade the turbos and inlets/outlets thank you all! |
08-08-2016, 11:52 AM | #12 |
4ut0strd4
47
Rep 223
Yeah that should work make sure you log though! Also make sure you use the upgraded turbo map they have on the site and not any of the stock turbo maps! If you have meth you'll be able to use it, but not E85 with it like I mentioned before.
Dino811.50 |
08-08-2016, 01:38 PM | #13 | |
1933
Rep 1,532
Imagine a nice big old tractor tire. You have a bicycle pump. The tire has 19psi and I tell you to keep it there after I poke a tiny pin hole in it. You won't have to pump very much to keep 19 psi in that tire. You aren't moving a lot of air. Now if I take a 1" hole saw to the tire, and ask you to keep it at 19 psi, you'd have to pump like superman to keep it at 19 psi. You're moving a ton of air. Not only this, but with the upgraded turbos you'll be able to hold that boost all the way to redline, resulting in a dramatic increase in horsepower over stock turbos as the revs rise. Any upgraded turbo that has a larger turbine is going to (hopefully) flow more air and offer less restriction than the stock turbos. The GC manifolds flow very well and are efficient in those boost ranges. Just understand that your current fueling may be inadequate because the new 19 psi is now flowing more air (see analogy above) and you'll need a correspondingly increased amount of fuel to match it. Chris |
Dino811.50 |
08-08-2016, 03:30 PM | #14 | |
Rep 8
thanks for the explanation chris...and yea, i did kinda figure TBI or PI MAY be necessary.. i guess ill just have to log. |
