Valve cover/downpipe swap now codes
08-04-2016, 07:03 PM | #1 |
N54 Whisperer
20
Rep 71
Hey guys,
I installed some VRSF downpipes but wasn't happy with the sound or smell and my car was doing the normal few puffs of white smoke when stopping so I decided to switch back to stock DPs. While I was waiting on the downpipes to arrive I also ordered a new valve cover kit and new oil cap to fix a leak. After the switch back to stock and with the new valve cover I'm having some weird issues that I can't figure out so any help would be appreciated. First there is a burning plasticy/rubbery/oily smell coming from the passenger side, no smoke though. It's not strong and it might stop after driving more than a few miles but it's notable. Might be oil that dripped or something but it starts well before the exhaust would be hot, almost right after turning the car on. Second, I drove to a local car meet to see some friends and noticed some activity I hadn't seen before on my MHD gauges. Whenever I let off the gas the AFR would spike on bank two but stay relatively low on bank one. This relates to the codes I'm seeing in the next part. I also didn't ever really get into boost, I was keeping it under 2k View post on imgur.com Then, when I was testing it out a bit more on the way home I got some codes: View post on imgur.com View post on imgur.com Overall the car felt NA and wouldn't build boost at all in low RPM but would get to 4 - 6 PSI in first/second at higher RPM When I did the valve cover I replaced the vacuum lines from brake boost line to the vacuum canisters on both sides of the hard line because they were cracked I'm thinking it's a boost solenoid which explains the boosting issues and 30FF but not the O2 sensor codes. I did damage one of the O2 sensors when I was uninstalling the downpipes (small dent from socket) so maybe it's a combination of the two? Could a bad pre-cat O2 sensor lead to a code on both the pre and post cat sensor for that bank? The car was running perfect until now, so it seems weird the solenoid would go out unless I hit it when doing the valve cover Edit: rear? boost solenoid is making a loud buzzing sound which makes this process easier. Also, after running the car yesterday I forgot to mention there is a water bubbling/boiling noise coming from the turbo side of the car. I have changed the ofhg and ochg within the last 1000 miles. I did the electronic bleed on the cooling system and a ton of bubbles would be heard coming up to the tank Any help or ideas on how to proceed would be appreciated! Jeff Last edited by fordbaxter; 08-04-2016 at 07:15 PM.. |
08-05-2016, 03:13 PM | #3 | |
N54 Whisperer
20
Rep 71
Car is an 08 with 55k miles and I'll probably go ahead and replace the two boost solenoids and replace the O2 sensor I know I dented to see if that fixes the problem. I did double check the 02 sensors being on the correct side, grey for the rear pipe black for the front pipe Jeff |
08-05-2016, 03:57 PM | #4 | |
197
Rep 1,070
For what it's worth, when I swapped solenoids, one buzzed like a duck call.. Fixed my boost issue and I immediately ordered the second and installed it proactively about two days later. Very, very easy job.
JWebb335xi
MHD / Wedge / 93 Octane/ xHP / FMIC / Inlets / Catted DPs / CP / DVs |
fordbaxter19.50 |
