Downpipes Question
08-04-2016, 04:26 PM | #1 |
1907
Rep 6,968
Drives: 2007 Black/Black 335i e90
Downpipes Question
I just got my new VRSF down pipes. I have an 07 BMW 335i. I am waiting on the VRSF downpipe fix before I install them.
I am a little confused about the downpipe fix. I have read you should only use it to fool emissions and that's it, and I have read it fine to use it as a daily driver so you don't blow codes etc. I don't have a tune. So, which is it? Do I have to get something like MHD flasher and just send the fix back to VRSF or what? |
08-04-2016, 04:36 PM | #2 |
3442
Rep 79,211
The DP FIX is used for 2 reasons. Defeat emissions inspection OR to use for removing the check engine light in the absence of a tune.
So it still has value with a tune because it can be used at the time of inspection. It should only be used with a tune for inspection and not daily driven with it on for long period of time as it alters AFR negatively. |
08-04-2016, 04:44 PM | #3 | |
1907
Rep 6,968
Please advise |
08-04-2016, 06:18 PM | #5 |
875
Rep 5,458
Do you plan to tune, not a lot of benefits to DP's if you don't run a tune. If you are going to tune it, several flashes code out the errors and depending on our emissions test, that may be enough - here we are allowed 1 not ready which coding out the 02 errors will set the channel to not ready which will pass here if you have no other issues. Otherwise, you would need to DPFix and to flash back to stock to get through emissions or if you run a JB4 etc, you would need dpfix.
2025 X5 Msport
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
08-04-2016, 06:31 PM | #6 |
654
Rep 946
You may be missing a very important piece of information here. Without a tune, downpipes are basically pointless. Also, in that other thread you started today, didn't you mention a JB4?
08-06-2016, 05:24 AM | #7 |
37
Rep 123
I don't want to open another thread about this...I want to get a VRSF downpipes on my 335i with MHD tune and I'm a little confused about this fix...Is only for JB4 this fix ?If I will install these downpipes I will get some codes and need to clear this errors?
08-06-2016, 07:33 AM | #8 | |
88
Rep 824
08-06-2016, 11:22 AM | #9 | |
37
Rep 123
