2Addicts
2Addicts
2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum Regional Forums USA - California ▀▄ eas | BMW Coding & Personalization - $95 "ALL YOU CAN EAT" Special!
      08-03-2016, 06:54 PM   #1
chris @ eas
274
Drives: BMW
european auto source is proud to be your #1 Southern California coding facility!
Whether its a simple Check Engine lamp or are looking for full retrofit coding - we are your one-stop facility for your programming needs.
Why should you choose eas as your SoCal coding facility?
- Over 10+ years experience in module coding
- Fully Equipped with Autologic Diagnostic Scanner/Programmer
- Autologic Optical Interface (OPS Diagnostic Head)
- Proper Voltage Stabilization maintained with Fronius ACCTIVA Professional Flash (70 Amp)
- Non-biased programming facility, with no fear of warranty rejection.
The Autologic diagnostic tool for BMW vehicles is without doubt the most comprehensive tool to be made available to independent BMW specialists. Autologic BMW is unique in offering full dealer-level fault code read and re-set, full component activation, electronic control unit procedures, clearing and setting of adaptation values, full coverage of (ECU) control unitscoding, full programming capability including engine control modules and transmission control modules, adjustment of engine idle, real-time reading of all dynamic data, procedure for engine and immobilizer alignment, procedure for trial substitution of control units and procedure for the fitting of BMW accessories.
The Autologic Optical Interface has been designed to program the CCC-A control units on BMW. Connecting directly to the fibre optic MOST bus, the Autologic Optical Interface is able to communicate with CCC-A, CCC-BO, CCC-ASK, CCC-ANT, ULF TCU and MASK ECUs. The Autologic Optical Interface significantly reduces the time to program these control units and further increases the reliability and recoverability of flash updating these control units.
Power Stabilization
Intelligent battery charging systems are very important given the technology of BMWs. We use the Fronius ACCTIVA Series with Active Inverter technology, the only all-round charger which Autologic recommends.
Detailed Explanation of features
When completed, a complete demonstration of all features are given so you are 100% familiar with your new options.
Why do you not perform remote coding?
A number of precautionary steps are taken in order to ensure your BMW is safe during the coding process, which cannot be verified remotely. Your pride and joy and its well-being is important to us!
Coding/Individualization (options may vary by model/build configuration) - $95, unlimited options
- Remove Seatbelt Chime/Reminder
- Disable iDrive Legal Disclaimer
- Close Windows with FOB
- Fuel Stop Suggestion in Route Guidance
- Close Windows with Comfort Access (CA)
- Disable Rear Camera Legal Disclaimer
- Digital Speedometer on BC Stalk
- Add WeatherBand Radio
- Fog Lights + HighBeams
- Disable Side Camera Legal Disclaimer
- Always Remember Air Recirc. on startup
- Allow Top Camera View at all speeds
- 1-Touch Window Up while Doors Open
- Disable Night Vision Legal Disclaimer
- Always Remember AC OFF on startup
- Allow Side Camera View at all speeds
- Auto Start/Stop (remembers last option)
- Amber Corner Delete
- Fold Mirrors with door lock (AUTO)
- Fuel Reserve Warning (6 liter)
- Auto Start/Stop default to OFF
- Fold Mirrors with Comfort Access (CA)
- Fold Mirrors with FOB (2-Step)
- Add TPMS Tire Temp/Pressure Data
- DVDinMotion
- Change DVD Region Code
- Windshield Wiper Return
- Remove Speed Correction Factor
- Set HighBeam Assistant to AutoOn
- Change BT ringtone to personal tone
- Unlock Doors when ignition OFF
- Start vehicle without brake pedal
- Enable Video file import (NBT)
- Fog Lamp on when turning (signal)
- Door Handle LED on when in reverse
- Illuminate foglamps with Welcome Lights
- Unlock door when engine is OFF
- Pass mirror dips when in reverse (curb)
- Change iDrive startup animation (NBT)
- Turn off iDrive when door is opened
- Add slider in iDrive for ambient light
- Specify soft-touch blinker count (1-9)
- Enable Video playback from USB (NBT)
- Increase Angel Eye Brightness
- High-Beam Auto Assistant Default ON
- Enable Timestamp for Call Log (NBT)
- Disable Headlight Washer Jets
- Change NAV voice (British/US) (NBT)
- Enable Speech Input for Email & SMS (NBT)
- Enable Text in Office while Driving (NBT)
- Disable Audible Chirp when locking (NBT)
- GPS Current Location to NAV menu
Phone:
You can reach us directly by calling 866.669.0705
Hours of Operations:
Monday - Friday from 9AM to 5PM PST
Saturday - 9AM to 2PM PST
Sunday - Closed
Retail Location/ Installation Center:
Come check out our 8000 square foot facility in Anaheim, CA. We install everything we sell.
Contact Info:
Phone: 866.669.0705 x26
Email: chris@europeanautosource.com
Website: http://www.europeanautosource.com
Feel free to contact me via PM, email, or phone if you have any questions.
Appreciate 2
      12-27-2016, 06:30 PM   #2
chris @ eas
274
Drives: BMW
Coding Slots available for immediate booking
PM for details and availability
      12-29-2016, 06:27 PM   #3
chris @ eas
274
Drives: BMW
Coding Slots available and ready for immediate booking
PM to book your appointment!
      01-02-2017, 06:38 PM   #4
chris @ eas
274
Drives: BMW
Coding slots open and ready for immediate booking!
PM for details.
      01-03-2017, 07:00 PM   #5
chris @ eas
274
Drives: BMW
Coding slots available for immediate booking,
PM for details!
      01-11-2017, 06:54 PM   #6
chris @ eas
274
Drives: BMW
Coding slots available for this week!
Make sure you stop by this saturday for our Dyno / Coding event!
      03-24-2017, 06:01 PM   #7
chris @ eas
274
Drives: BMW
Coding slots open and available for immediate booking!
      03-27-2017, 06:56 PM   #8
chris @ eas
274
Drives: BMW
PM for details!
      03-28-2017, 06:13 PM   #9
chris @ eas
274
Drives: BMW
Coding slots available for immediate booking!
      03-30-2017, 06:58 PM   #10
chris @ eas
274
Drives: BMW
All PM's replied to!
Coding slots still available.
PM to schedule!
      04-03-2017, 11:33 AM   #11
chris @ eas
274
Drives: BMW
Coding Slots available for immediate booking!
PM to get your car coded today!
      04-04-2017, 04:00 PM   #12
chris @ eas
274
Drives: BMW
Coding slot still available for this week!
      04-06-2017, 06:56 PM   #13
chris @ eas
274
Drives: BMW
PM to get your car coded!
      04-07-2017, 06:05 PM   #14
chris @ eas
274
Drives: BMW
PM today to schedule your coding appointment!
      04-10-2017, 05:36 PM   #15
chris @ eas
274
Drives: BMW
All PM's Replied to!
PM today to get your vehicle coded!
      04-12-2017, 06:34 PM   #16
chris @ eas
274
Drives: BMW
Coding slots available!
PM to schedule an appointment!
      04-14-2017, 06:06 PM   #17
chris @ eas
274
Drives: BMW
PM to book your coding appointment today!
      04-17-2017, 05:58 PM   #18
chris @ eas
274
Drives: BMW
PM to reserve your slot today!
      04-19-2017, 06:01 PM   #19
chris @ eas
274
Drives: BMW
Coding slots still available for immediate booking!
      04-24-2017, 06:23 PM   #20
chris @ eas
274
Drives: BMW
      05-02-2017, 02:04 PM   #21
chris @ eas
274
Drives: BMW
      09-27-2017, 01:24 PM   #22
chris @ eas
274
Drives: BMW
Open slots for coding sessions are available for immediate booking!
Please shoot a PM to book your coding session with us.
2addicts
