Unboxing of the on3 Performance turbo kit
08-03-2016, 05:00 PM | #1 |
245
Rep 1,236
Hey guys I just wanted to throw some pictures up of the on3 turbo kit since there is basically nothing online about what they can bring to the table. The parts seem quality and well made. The welds look purty and not sloppy at all. I did decide to not get the intercooler with the kit because I already have an aftermarket one on my car. Here is the link for the kit:
http://www.on3performance.com/shop/b...-turbo-system/ Here is the parts list for the kit: Billet Plugs Factory Water Ports Billet Plugs For Factory Oil Supply Ports Billet Plugs For Turbo Water Drain Billet Plugs For Factory Turbo Oil Drain Custom Billet Oil Supply Fitting for New On 3 GT Series Turbo Custom Turbo Oil Restrictor Fitting Custom Billet Turbo Oil Drain (Into Engine Block) On 3 Performance 2pc SCH 10 304 Stainless Steel Turbo Manifold On 3 Performance Massive 7? Core Air To Air Intercooler 3? 304ss 16 gauge Tig Welded Downpipe On 3 Performance 55mm GT30 Turbocharger (Journal Bearing) *Upgrades Available (I got the gt35 Dual BB kit On 3 Performance SS Custom Cast Turbo Exhaust Housing On 3 Performance Oil Feed System On 3 Performance Oil Drain System Billet Machined Custom Turbo Fittings On 3 6061 Aluminum 2.5? Charge Pipe On 3 6061 Alumnum 3.0? Throttle Body Charge Pipe 5 ply Silicone Coupler Kit Stainless Steel T-Bolt Clamp Kit On 3 50mm Blow Off Valve Kit On 3 44mm Wastegate Kit Custom Billet Aluminum Power Steering Overflow Tank Instructions and Support From The On 3 Performance Staff Billet Plugs Factory Water Ports Billet Plugs For Factory Oil Supply Ports Billet Plugs For Turbo Water Drain Billet Plugs For Factory Turbo Oil Drain Custom Billet Oil Supply Fitting for New On 3 GT Series Turbo Custom Turbo Oil Restrictor Fitting Custom Billet Turbo Oil Drain (Into Engine Block) I'm still deciding if I want to install the kit because I have medical bills to pay for but seeing the kit makes me really want to drop it off at the shop for install tomorrow. FYI someone made just north of 530whp with their 61mm turbo on pump gas the other day. I can't wait to see what this kit is capable of with pump+Meth, and also on a pure e85 tune.
2007 e90 335i: Single Turbo 700whp (Sold)
2009 e82 135i: Jb4 Only (Sold) 2010 e92 M3: Macht Schnell Intake, AA Pulley, IPE F1 Full Exhaust, 100% e85, RK Tunes Custom Tune (400whp) |
08-03-2016, 09:02 PM | #4 | |
245
Rep 1,236
vitan9.00 |
08-03-2016, 09:20 PM | #5 |
75
Rep 168
great post. I just wish they would get into making turbo-less twin scroll kits. They would move like hot cakes and most likely put JpWorkz out of business.
08-03-2016, 10:32 PM | #8 | |
Rep 71
08-04-2016, 07:23 AM | #9 | |
Macgyver
208
Rep 942
GTX3076R , ADV, JB4, FMIC, BOV, 17"APEX, 255/40/17 SQ, 6-SPD Manual
08-04-2016, 10:56 AM | #12 |
72
Rep 385
On the turbo pic looks like they sanded or grinded the nut down thats a huuuuge no no!!!!
1BADM370.50 Turbo_power4ever93.00 |
08-04-2016, 11:18 AM | #13 |
Guest
Rep n/a
Drives:
The practice itself isn't that unheard of when it comes to VSR balancing, I just found it interesting that there's hardly anything holding it together now...I'm obviously no expert though.
08-04-2016, 06:24 PM | #14 |
92
Rep 322
08-04-2016, 10:20 PM | #18 | |
75
Rep 168
///Mposter208.00 |
08-05-2016, 03:18 AM | #20 |
261
Rep 1,093
It's a $300 turbo and $300 wastegates. A pair of Tial 44 wastegates alone cost $100+ more than those combined. I think they should offer it with the junk and the good stuff. Why should one have to eat that $600 if they aren't going to use parts. Take that $600 off which brings it to $2100 then add Tial WGs and basic Precision turbo for $1700. That brings the cost to $3800 which is still good. Just not as good as it looks with the eBay grade turbos. For example DOC racing is $6000 ($5000 if they are still on promotional cost) but they use a $1750 BB turbo and $700 Tial wastegates. At the promotional price it would be $3150 with a $300 turbo and $300 WGs JP kit with journal bearing precision is like $3500. Subtract the difference in turbo and WG cost and the JP is actually several hundred cheaper if you can obtain it reliably.
