Today is a very sad day engine problem/ limp mode
08-02-2016, 10:38 PM | #1 |
26
Rep 352
Hello Everyone,
I have 2007 bmw 335i Mods - cobb custom tune, aquamist meth kit, raceland downpipes, upgraded intercooler, ultimate racing dual intake, cut mufflers, cp charge pipe with hks bov, catch can, walbro 450 lpfp I think my car too a big shit. limp mode no boost. I look at my car soo many codes Codes p2aaf p2ded p2aae p30ff p2c7e p2c6a p2c7b new code i have never seen before p30cf Waste Problems p3100 limp mode. I think my waste gates are done but i don't know. I was thinking of buy http://www.ebay.com/itm/121909180837?rmvSB=true and http://www.ebay.ca/itm/BMW-335I-135I...-/111856454441 What do you think? Am i wrong on my solution? |
08-02-2016, 10:53 PM | #2 |
9
Rep 71
Drives: 2007 n54 335i and 2006 n52 325
P30ff on the 07 = turbos shot ??. I'd look into upgrading your turbos when your in there change all other stuff that's ither old or needs replacing.
08-02-2016, 11:02 PM | #3 |
26
Rep 352
08-03-2016, 05:21 PM | #4 | |
9
Rep 71
08-04-2016, 04:06 PM | #5 |
26
Rep 352
I am not a specialist. but i am a specialist for vq35 motors. I am too lazy to make a single turbo kit and plus The bmw is my dd. I don't want to play around too much with this car. I just bought new stock turbos they were cheap. I can't justify spending $5000 on my dd. if it was for my other car np.
T_revor8088.50 |
08-15-2016, 11:31 AM | #6 |
26
Rep 352
Here is a funny thing. I left my car for 3 days and then it start to boost to 15 psi. After just crusing it for a bit the half engine light came on.
p30cf Waste Problems p3100 limp mode. Are my turbo really gone? |
davidwarren187.00 |
08-19-2016, 07:06 AM | #11 |
111
Rep 408
little mightypump vacuum pump/bleeder - check amazon. search "bad boost solenoid"
specialist26.00 |
08-19-2016, 07:32 AM | #12 |
133
Rep 4,764
I got 30ff a few years ago, and also had after market inter-cooler. I was worried about all the places to check, started with the easiest which was with the clamps to the inter-cooler. To my surprise, they had loosened over time. I tightened them, 30ff gone, and never came back. We all know some codes unchecked can cause other codes. The point just being, start with the cheapest things you can eliminate as the possible root cause first. I would have looked at vacuum canisters, diverter valves, and every connection on that charge-air track next, once tested good, moved on to waste gates. There is an old post by member sniz that you can search for for a homemade pressure test that helps you be able to listen for leaks if needed. good luck.
Jaronbwall284.50 geek57.00 |
08-19-2016, 01:38 PM | #13 | |
111
Rep 408
You should start with the vacuum lines all along the top of the engine and near the OFH - they're typical culprits and often you can even see fraying. Just replace the lines you can see. 3.5mm hose at amazon is as cheap as the vacuum pump |
specialist26.00 |
08-19-2016, 08:25 PM | #14 |
26
Rep 352
more bad news i think one of my injectors went. The code i got was p2e36. injector 6 controller. I thought it was spark plugs so i changed them. no change then i swaped coil packs no change. I put a temp lazer pointer on that injector 6 it was 10 degrees colder then the other ones. So i think i am safe to say to chnage that injector. My luck. I also bought a vaccum pump i put 15 psi in the top of the canisters with the car off it held 15 psi no drop off then i release the presure after 30 sec.
I am now going to home depot to buy a 2.5 pcv cap to make a boost tester. I hope i will catch a break soon Last edited by specialist; 08-19-2016 at 09:33 PM.. |
08-19-2016, 09:57 PM | #15 | |
352
Rep 2,050
These n54s can trigger 30ffs even with the smallest leak. I wouldn't jump to conclusions right away. Test for leaks. Replace injector and let us know
'10 e92 N54
DCI intakes, ER chargepipe, TIAL BOV, VRSF 5in FMIC, BMS Downpipes COBB e30 |
08-19-2016, 10:07 PM | #16 |
26
Rep 352
ok i will check for the leak tomorrow and get a new injector i hope i will be able to find on tomorrow
Also the car is not smoking Last edited by specialist; 08-20-2016 at 10:53 AM.. |
08-20-2016, 05:45 PM | #17 |
26
Rep 352
Well I got used injectors today with 60km on them so better then mine. I also bought new o ring clip and o ring at the bottom of injector just need to tool. Going to see where to guy that tool now
08-21-2016, 12:25 PM | #18 | |
Ballin' out of control.
520
Rep 1,289
http://www.e90post.com/forums/showpo...9&postcount=35
Alpina B3 Flash/BMS OCC/ER CP/ETS 5/HKS BOV/M3 Control Arms
specialist26.00 |
08-21-2016, 08:56 PM | #19 |
26
Rep 352
1)https://www.ecstuning.com/b-genuine-...l/83300495756/
2)https://www.amazon.com/BMW-Injector-...HQBNMPC1ZJV5HP 3)https://www.fcpeuro.com/products/bmw...ol-83300495761 This will allow me to slip it on but i have no way of squeezing the seal What should i get? |
08-21-2016, 10:22 PM | #20 | |
520
Rep 1,289
I have #1 and a slide hammer like the one from #2. The only thing you would appear to be missing (with #2) is the specialized cutters to remove the old seal. That's not a big deal.
specialist26.00 |
08-28-2016, 11:11 PM | #22 |
26
Rep 352
injectors are in now coding problems
I got my cable loaded the software, launched INPA and the Battery/ing lights are both black but when I try to read codes I get: ApiCheckJobStatus: Error #95 SYS-0005: OBJECT FILE NOT FOUND API job error or no such result ! I have reloaded 5 times after then i want to look for boost leaks |
