08-02-2016, 02:46 PM | #1 |
5408
Rep 10,825
Weight check - my M4 GTS on the scale - 3553 pounds
08-02-2016, 03:34 PM | #3 | |
5408
Rep 10,825
VCP1390.00 DocWeatherington2932.50 |
08-02-2016, 03:40 PM | #4 |
1390
Rep 2,336
On the lapping on Nordschleife I would have guessed a 300+ pound difference. The sharpness of the chassis and engine liveliness really make for a lighter feel. Also the areas in which they moved the weight contributes, much lower center of gravity. That big carbon fiber skeleton behind the dash must be pretty
08-03-2016, 09:31 AM | #6 |
557
Rep 762
I am not so happy that its so porky, sport auto had One on the scale and full of gasoline it was 1591kg!! They tested GTS vs 991 GT3 and on same scale it was full of gasoline 1453kg, still GTS was only 0.4 sec slower on the ca 2+ km short hockenheim.
My GT4 is 1430kg full of gasoline, i am not that happy about GTS that porky. |
Powaup1253.00 |
08-03-2016, 09:32 AM | #7 |
557
Rep 762
08-03-2016, 09:44 AM | #8 |
Moderator
7509
Rep 19,370
Right.
But not all scales are created equally, and not all conditions around and operations of said scales are the same. From past experience, we've seen numbers all over the map from owners in threads like this. My point is that it is always nice to have another car to compare against side-by-side. |
08-03-2016, 09:55 AM | #9 | |
557
Rep 762
Agree, still sport auto put all cars on same scale always full fuel(and they also list cars options)
08-03-2016, 03:05 PM | #12 |
557
Rep 762
The advertised pork was without cage, etc as this was option(free) on all cars. Then again all 700 buyers did as I hear choose to have the free option cage. Hence they could keep pork down in ads. It was 1510kg unladen weight DIN(unladen applies to cars with standard equipment) whitout options, like no cage, fireX, 6 point belt etc, and extras also without gasoline.
According to German mag auto zeitung they tell us the 991 RS cage was lighter, 21,8kg vs GTS cage 23kg. Unladen weight EU was 1585kg inklusive 90% full gasoline, 68kg driver and 7kg For luggage. This info is in Gts limited edition book, last page(smal text) Last edited by Captain Unknown GT4; 08-03-2016 at 03:12 PM.. |
cncmastr1579.00 |
08-03-2016, 03:17 PM | #13 |
557
Rep 762
Then again a new Ford focus Rs is in sport auto test 1569kg full on gasoline. But 991 GT3 RS was in same mag, same scale 1461kg full gasoline, litium batterie, ceramic brakes and sport crono (no stereo, no navi,)
08-04-2016, 11:59 AM | #14 |
1253
Rep 3,688
Drives: 2021 Supra 3.0 (Past: 2015 M23
Full tank of gas? that would explain the weight
08-04-2016, 12:23 PM | #15 |
Master Driver
422
Rep 752
doesnt BMW provide an official weight? i presume those are gasless
"Bane" 2018 X3 |G01
"Tomato" ED 2016 M3 | B50 | ZCP | X3SW | ZDB | ZEC | ZLP | 2MK | 5DP | 6NS | "Booberry" ED 2013 335xi | Returned "Boo" CPO 2006 330xi | Sold |
jmciver1832.00 |
08-04-2016, 12:24 PM | #16 |
149
Rep 807
This weighs the same as any other M4/M3 essentially or at least my M3 was about 3580 if I remeber correctly with 6MT
Follow me on the 'gram @eurocarnation @sinisterM4
Check out my Past M3 build (SOLD) here! Check out my M4 build (CURRENT) here! Last edited by n54fanatic; 08-04-2016 at 12:33 PM.. |
08-04-2016, 12:36 PM | #17 |
3817
Rep 4,657
Drives: BMW
That's pretty heavy for a stripped out track car, no?
08-04-2016, 12:47 PM | #18 |
2736
Rep 6,734
Drives: 'E46 M3 Race Car, '23 X7
Keep in mind that the US version has standard comp package seats. The fixed back buckets on the euro cars would save a significant amount of weight. I would estimate 70 to 100 lbs
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M |
08-04-2016, 12:47 PM | #19 |
1343
Rep 3,341
Interesting... My certificate of origin has 3550 on it.
Needed CoO because I bought from Germany.
2019 Ruby GT350 - Gen 5 Whipple on corn making 855RWHP.
Sold: 2018 F80 Part Deux /DCT /YMB /Full SS /CF Trim /ZCP /ZEC w/Black 666M Sold: 2015 F80 /DCT /YMB /Full SS /CF Trim /ZEC /ZLP /HK /S&TVC- 18''///M |
08-04-2016, 01:09 PM | #20 |
89
Rep 440
http://f80.bimmerpost.com/forums/sho...hlight=weighed
2015 f80 m3 with no options except m-adaptive suspension. That means 18" wheels, 6 manual trans, etc. 3,450 pounds with 3 gallons of fuel ================================================== ================================================== ================= http://f80.bimmerpost.com/forums/sho....php?t=1003735 2015 Mineral White M3 Specs 0ZDB Driver Assistance Plus 0ZEC Executive Package 0ZLP Lighting Package 02MK M Double-clutch Transmission (DCT) 02NK M Carbon Ceramic Brakes 02VF Adaptive M Suspension 02VZ 19" Black Wheel 437 M Mix Tire Fuel: Empty (no driver) Weight: 3562lb EDIT: These are different scales being used obviously. |
08-04-2016, 01:12 PM | #21 |
156
Rep 260
So the GTS exchanges less race useful weight (padding, sound insulation, comfort etc) for more useful race weight like roll cage, water injection, chassis rigidity etc?
