timing corrections while cruising
08-02-2016, 10:12 AM | #1 |
97
Rep 804
been having this problem for some time now which i never had before while regular city driving cruising speeds i get timing corrections on multiple cylinders anywhere from -2.7 to -8 deg. this occurs on multiple maps that i've tried / 94 pump and/or e30
tried maps with very low timing (1-3deg) and moderate timing (6-9deg) and its the same outcome no matter what. new 5770 NGK plugs in the car .... maybe these are not as good as the old 5992's ?? also get a cold start stumble/misfire in rpm ( which triggered a misfire a couple times in cylinder 4) i swapped coils around and have not had it since. currently have a 2C7B code .. Logs are clean when going WOT other than post shift corrections im stumped and dont know if i should order new coils to start any insight would be appreciated
E90 LCI M-sport/ 6AT/ LSD/ FBO+
08-02-2016, 10:22 AM | #2 |
3441
Rep 79,211
Timing corrections during normal everyday driving at light throttle are normal, you'll be spinning your wheels trying to get those to not correct.
Only corrections that matter are at WOT. Even then 1 or 2 is normal too. When was the last time you have changed coils or had a walnut blasting on the intake valves? |
08-02-2016, 10:25 AM | #3 | |
97
Rep 804
08-02-2016, 10:47 AM | #4 |
3441
Rep 79,211
08-02-2016, 10:54 AM | #5 | |
97
Rep 804
in the last 2 months the inlets were installed (downpipes removed) after the install one of the O2's were replaced as it went bad or was damaged during install and was giving me a frozen reading when monitoring the AFR through MHD
08-02-2016, 12:26 PM | #6 |
469
Rep 1,536
For some reason I get lots of minor timing corrections at around 40 load while cruising. Could be my VANOS settings in my tune doing something funky at those load levels.
Only around 1 degree correction or less though. What you are seeing (-8 deg) isn't normal AFAIK. Post up a log. |
08-02-2016, 01:16 PM | #7 |
265
Rep 1,392
jyamona
Have a single turbo and/or tired of burning up O2 sensors? Ask me about the new ADV O2 sensor retro kits!
335i 2010 e92 M-sport Mods: VM Top mount 6466, Aquamist HSF4 w/custom direct port. VRSF IC + Exhaust 335i 2009 e90 665RWHP VFF900 ST RIP . |
08-02-2016, 03:04 PM | #9 |
BimECU
193
Rep 759
I would get new coils for sure
08-02-2016, 03:49 PM | #10 | ||
3441
Rep 79,211
It might be good practice just to replace all 6 coils. Quote:
