08-01-2016, 11:29 AM | #1 |
383
Rep 862
Ohlins Road & Track Coilovers // TAG Motorsports
The owner of this Silverstone M4 did not want to lower his car in his pursuit of improved handling. A lot of coilover options on the market are designed around the assumption that owners will want to decrease ride height, this means that they often cannot be set close to factory ride height or that they would not feel right if set that high. The Ohlins Road & Track is designed so that ride height can be set near stock if desired and they work beautifully well in this configuration. In this case, the owner also chose not to change the front to rear rake that is present on the factory suspension setup so this really is the ultimate OEM+ setup in our opinion: factory suspension geometry with full travel and plenty of ground clearance but with significantly firmer springs and much better damping! The easily-accessible compression/rebound adjustment knobs gave us the ability to fine tune firmness to the customer's taste more quickly than is possible with other coilover designs. What do you think? Contact us with any questions or if you would like to discuss the many suspension upgrade options we have for your M3 or M4 today! |
08-01-2016, 12:04 PM | #2 |
1860
Rep 2,104
Did this have a 'missing nut', as was mentioned in another thread? And you guys had to scrounge up a nut or something?
Also, it looks like the customer is running OEM size tires. If one were to move the rear tires to the front, and get 295/35's in the rear, do you think that would require spacers? I believe another person reported some issues, and required spacers for wider tires. Thanks! |
08-01-2016, 12:58 PM | #3 |
237
Rep 258
Thanks for featuring my car, Neema and Gabe. I'm embarrassed it was so filthy, especially the wheels, when I dropped it off.
Yes, RocketBoots , I'm running stock tire sizes. I'll be staying at stock ride height even after I decide on new wheels. All of the hardware was included. I checked before I dropped it off at TAG. I wanted a slightly aggressive street setup over stock as I may only track my car once, at which time I can dial it up. Impressions after 3 days: - Flatter on turns and hard braking. Turn in is sharper. - The rear doesn't wiggle-wobble under hard acceleration. It hooks up in a straight line and flat, a hard acceleration in the middle of a turn = no wallowing. - Rebound and compression are improved as I can feel the backside of bumps - no float. I believe I am in the lower 1/3 of the stiffness scale for adjustment of this set and the improvement over stock is obvious. I will go a couple of clicks stiffer for a test this week. The car is comfortable and handling to my preference. - I have active sound coded out and I can hear slightly more road noise with this setup. Not an issue just an observation with the radio off. Gabe, Neema, Sean, and Alex at TAG are great. They spent a lot of time with me talking suspension, wheels, exhausts, and tunes...I recommend them and will return. |
08-01-2016, 02:30 PM | #4 |
1860
Rep 2,104
haha, I didn't even notice the wheels... but now that you mention it, they ARE filthy
Thanks for the feedback. Didn't realize that was your car I saw your review. Good to hear yours wasn't missing any nuts or bolts. |
WoohooSoCal237.00 |
08-01-2016, 03:14 PM | #5 |
383
Rep 862
To clarify, the top nut is re-used from factory as the instructions indicate. I'm not sure why the other car on this forum had issues with the nut not fitting but the factory top nut went back onto this car without any issues.
08-24-2016, 09:07 PM | #10 | |
543
Rep 1,338
Drives: Round n' Round
Rear spring perche look the same about 3/8" left how is this plenty of room to go lower? |
08-24-2016, 11:56 PM | #11 | ||
6579
Rep 5,304
That being said, it does look like the shock will go down into the collar about an inch more... give or take. The rear is your typical BMW coilover perch. It doesn't look like it'll go down much further. It's also possible that the pictures were taken before adjusting ride height. |
08-25-2016, 05:02 AM | #12 | |
*_*
808
Rep 3,160
I hope so, but regardless, both collars show the car is almost at its lowest setting. It would be great if I was wrong and there's significant room to drop the car on these amazing coilovers.
08-25-2016, 03:35 PM | #13 |
383
Rep 862
If your primary goal is to lower your car, other kits on the market can go lower. This option is best for people who want a moderate drop or who want to stay close to stock but who are looking for improved agility, stability, body control, etc. The Road & Track does an incredible job of soaking up bumps, this is partly because it retains good suspension travel, partly because it maintains very good suspension geometry, and partly because of Ohlins' very nice dampers.
There is room to go lower than what you see here but not as low as some of the other popular options. The recommended ride height is about 1/2" below factory height and there is some room to go higher or lower than recommended as with all coilovers. |
ddk632585.00 |
08-25-2016, 04:51 PM | #14 |
Barge driver
8647
Rep 12,421
I think it's the perfect set up for those that want the benefits of a coilover setup whilst still maintaining OEM style clearance, the side on picture looks very OEM+
730d/Z4C
08-31-2016, 07:37 PM | #15 |
731
Rep 901
02-19-2017, 03:34 PM | #17 |
Chief Senior Executive Managing VP of Orange Sales
585
Rep 2,581
This is awesome! Coming from motorcycles, I have 100% trust in Ohlins suspension over anything else. Nice to see there are good options out there without sacrificing daily-drivability of the car.
02-19-2017, 10:08 PM | #18 |
1232
Rep 1,969
i had ohlins dfv's on my evo x - they were too stiff for street use, but in the hills/canyons the dampening at speed was spot on
i'd love to drive an f80 with a set of these anyone looking at these with main priority of lowering is in the wrong thread |
06-22-2017, 10:56 AM | #22 |
51
Rep 179
I currently have the road and track coilovers on my GTI, and they're great for the street. If you're looking to track more regularly you'd probably want a more aggressive setup.
The down side is that they require periodic rebuilds. I believe Ohlins states every 15k miles, which is a total pain in the ass, and unrealistic for a street car. Is that the case with this setup too? PS: The rebuild is $200 per corner. |
