08-01-2016, 10:58 AM | #2 |
Wallander
158
Rep 169
Depends on what you want from the system and how much money you want to spend - if you just want thumping bass with no overall sound improvement simply build a bass box in the trunk. But if want good quality sounds with better bass then the established thinking is all in this thread.
Which basically involves the following: Disconnect Center Speaker. Swap out front doors with Etons/Focal/BAVsound Swap out rear deck with JL's Move fader to the back 3-4 notches Play around with Treble/Bass to your personal liking If then you still want more bass maybe add the Bavsound Ghost Subwoofer / Bimmertech Amp If you just want to spend money just order the complete BAVsound system or have custom install with a local sound shop.
M2 / Range Rover
Gone but not forgotten: Porsche 911 cab / S4 cab / M6 / E60 M5 V10 / E46 M3 CSL / E46 M3 SMG (x2) |
08-01-2016, 12:39 PM | #3 | |
56
Rep 169
1. Swap out front speakers with Etons B100W https://www.amazon.com/Eton-10-Way-C...ilpage_o00_s00 2. Swap out rear deck speakers with JL Audio Evolution 4" Coaxial Speakers https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 3. Add the Technic ASD bypass harness https://technicpnp.com/product/asd-bypass-harness/ contact technic and make sure right one... http://technicpnp.com/contact.html# 4. BMW weather stripping on front door Part numbers 51487300493 $14.78 51487300693 $14.78 part is called a Sealing Side Pan 5. Ebay BMW OEM Speaker Connector Harness Pigtail http://www.ebay.com/itm/BMW-OEM-Spea...-/161420349903 Hopefully this is a good start as recommended by member selmeralto, I'll also ask him in his post... |
Detailers Domain1992.00 |
08-01-2016, 12:48 PM | #4 | |
56
Rep 169
Original Part numbers 51487300493 $14.78 51487300693 $14.78 New Find... Driver side: 51-48-7-300-693 Price: $23.63 Passenger side: 51-48-7-300-694 Price: $22.96 |
08-01-2016, 02:21 PM | #5 | |
1753
Rep 2,942
Three additional points: - All the pigtails do is make installation easier; they're not necessary at all. - A lot of what selmeralto did, including the Eton component/JL Audio speaker combo, was based on my advice. He's done an amazing job of making his own sound (pun intended) decisions and documenting all of it. - Realize that the OEM underseat drivers are not subwoofers in the true sense of the word. They are low-mid drivers that stop functioning well below about 80 Hz. This has been tested by another member recently in the 2 Series forums. If you want true gut-jiggling subs, a box in the trunk with its own amplifier is likely your only option.
--Life is a journey made more exciting with a fast car.--
--Helmets are for closers.-- <<Current: "Blackened" '18 NBM Porsche 718 Cayman ... Gone (but not forgotten): "Blackened" MG '15 228i M Sport w/aFe filter/scoop, Hertz drivers, P3Cars multigauge, other goodies>> |
08-01-2016, 02:28 PM | #6 | |
56
Rep 169
Viffermike1753.00 |
08-04-2016, 02:55 PM | #8 | |
56
Rep 169
1. Swap out front speakers with Etons B100W https://www.amazon.com/Eton-10-Way-C...ilpage_o00_s00 2. Swap out rear deck speakers with JL Audio Evolution 4" Coaxial Speakers https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 3. Add the Technic ASD bypass harness https://technicpnp.com/product/asd-bypass-harness/ contact technic and make sure right one... http://technicpnp.com/contact.html# 4. BMW weather stripping on front door Driver side: 51-48-7-300-693 Price: $23.63 Passenger side: 51-48-7-300-694 Price: $22.96 About $14 each plus shipping 5. Ebay BMW OEM Speaker Connector Harness Pigtail http://www.ebay.com/itm/BMW-OEM-Spea...-/161420349903 and if not good enough, will add subwoofer and amp after... |
Viffermike1753.00 Fabb228.50 |
04-10-2021, 09:56 PM | #9 |
New BMW owner
325
Rep 842
Are there a new links to these speakers? Seems they are no longer available. 5 yrs later....
https://www.crutchfield.com/p_136C24...o-C2-400X.html is this the one for the rear?
2018 BMW M2 LCI BM3 Stage 2 + MPE + FTP charge pipe + MST V2 Inlet + TurboSmart DV + CSF FMIC + AA Hi-flow Downpipe + Turner Rear Shifter Bushing + Wiechers Strut Brace + Bilstein B16 PSS10 + Apex VS-5RS
04-23-2021, 08:14 AM | #10 | |
1916
Rep 2,134
Etons are a pain to come by in the states, and I'm interested in swapping out the fronts because my fader is set towards the front. Personally, I wouldn't sweat too much about the rears and rather spend more time deciding on the front drivers. |
04-23-2021, 09:55 AM | #11 |
New BMW owner
325
Rep 842
I ordered my Etons @ Madisons.
04-26-2021, 09:35 AM | #12 |
1916
Rep 2,134
04-26-2021, 09:38 AM | #13 | |
1916
Rep 2,134
Speaker level input from the sub channel works just fine. https://rockfordfosgate.com/products/details/p300-10/ |
04-26-2021, 10:40 AM | #14 | |
New BMW owner
325
Rep 842
I believe it’s this one. You would have to email them.
04-26-2021, 11:54 AM | #15 | |
1916
Rep 2,134
