Get a load of this crap!
07-31-2016, 05:29 PM | #1 |
47
Rep 203
So was doing my tranny pan today and everything going as planned... Grab my torque wrench to torque the pan bolts in... 1st bolt going in fine real easy then I notice that it seems like its not clicking and SNAP!!!! Damn torque wrench is not working and over tightening the damn bolt..... The rest of the bolts I had to tighten by feel...
Now I'm going to have to drill and tap the snapped bolt out. Anyone ever have this happen to them? or I am the first idiot with a broken torque wrench!! It not showing any signs of leak in that area...should be ok I'm guessing |
07-31-2016, 06:30 PM | #2 |
866
Rep 5,451
Bummer, I have had that happen (not doing my trans pan) but I have had a torque wrench stop working and broke a bolt as a result, good luck drilling and extracting! You should be ok with just one bolt missing for a bit I would imagine.
2022 X3M Brooklyn Grey
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
07-31-2016, 06:42 PM | #3 |
343
Rep 1,465
torque on the oil pan and valve cover is like 6-8 ft-lbs no? Vast majority of crap torque wrenches do not operate with precision at the low of a ft-lb anyways. It's best to hand tight till it's snug and then + 90 degrees max. Then follow it up with a torque wrench. That way you know that the bolt is already 80% of the way there and the torque wrench shouldn't be cranking it down. The torque wrench is validate that the bolt is at the specified torque.
I had a harbor freight torque wrench. The 1/4" and 3/8" one. The 1/4" one is in inch-lbs so you would think it has a bit more precision. The valve cover called for 75in-lb or basically 6.5 ft-lb. I set the torque wrench to 80-inch lb and did the valve cover job. It did NOT feel tight at all. In fact, it felt snug/ok but I was worried about over-torquing and snapping the valve cover bolts anyways. 3 months later, the valve cover gasket started leaking again. I suspect it was the improper amount of torque. Even when I tried to re-torque it on the cold motor, the wrench still told me it was good at 75-80 inch lb. I need to invest in a quality torque wrench as well that operates in the 5-10 ft-lb with high precision. It's always the bolts that call for the least torque that causes oil leaks. Last edited by nukezero; 07-31-2016 at 06:49 PM.. |
TrollToll654.00 |
07-31-2016, 07:36 PM | #5 | |
47
Rep 203
Let me tell you when it snapped, I literally was like NO WTF!!!!! I used all new bolts too I saved a couple old ones in case I need to fix any. Ill throw it up next weekend and drill the snapped one out. On a positive note the transmission shifts smooth as butter again... It had a small leak for a couple months now and it was about 1.5 L low. |
08-01-2016, 07:11 AM | #7 |
2203
Rep 3,336
Drives: X5 & E90 WTCC Widebody Racecar
This happened to me this past weekend when buttoning up my oil pan gasket. Someone said it was 8nM + 1/4 turn. Could. Not. Be. More. Wrong. That was WAY too much torque. I had my drill and tap ready. But didnt need it since I was the able to use a tiny tiny flathead screwdriver and push it around to spin it out. Give that a whirl first.
08-01-2016, 09:37 AM | #8 | |
65
Rep 285
BMS DCI/M FMIC&OCC/KONI YELLOW/H&R Sport/Hotchkis Front Sway&Links/CORSA Catback/VRSF CP/TS BOV
08-01-2016, 09:44 AM | #9 |
3441
Rep 79,211
Harbor freight torque wrench is the answer... and believe me I like harbor freight when you're in a pinch but there is nothing precision about their product offerings. Most torque wrenches don't do well under a certain range unless they are specifically for low range torque applications. They usually won't go much past 30 ft lbs if they are made for low torque.
08-01-2016, 03:24 PM | #12 |
Maximus Decimus Meridius
1130
Rep 4,584
Had this happen when doing VCG, snapped the very last bolt off into the head.. Luckily I was able to tap and reverse it out and throw in a new bolt from the new VC.. Good luck..
F30 335i Melbourne Red Metallic M-Sport Package |
08-01-2016, 09:29 PM | #14 |
47
Rep 203
Update... I couldn't wait till the weekend knowing I was missing one bolt in my tranny pan lol... Anyway I started to drill but the damn bit kept running off to the side, tried different size bits but no luck... So as someone suggested above I took a tiny flat header screwed tapped it with a hammer a little and was able to turn it back out... Took a lot of patience but got the lil faker out!!
In regards to the torque wrench at that low setting it works its just you have to feel for the click as the sound if very faint... All is good now!! Time to Tune MHD V7 Wooohooo!! |
08-02-2016, 12:34 AM | #15 |
Power without control is no power at all...
15
Rep 190
I always use a beam-type torque wrench with low numbers because they are usually more accurate. Your issue with a failed clicker just gives me another reason to keep on doing it.
08-02-2016, 02:45 PM | #16 | |
255
Rep 554
Drives: 2013 335is E93 6MT
2013 335is E93 6MT | LeMans Blue/Saddle Brown
BQ Tuning MHD E60 flash | Cobb catted DPs | ETS 5" FMIC | BMS DCI | Fuel-It Stage 2 LPFP | MMP inlets/outlets | Forge DVs | N20 TMAP sensor Vibrant 1790 resonators/mid-cat delete | MPI CP | Spec Stage 3+ clutch and steel SMFW | Wavetrac LSD | M3 rear subframe and diff bushings Last edited by JasW; 08-02-2016 at 02:50 PM.. |
