03-24-2008, 09:24 PM | #1 |
32
Rep 257
best way to 'hide' muffler....
the muffler shows quite a bit - -looks pretty cheap in a high end car...would spray painting a higher gloss silver do the trick - currently you end up seeing dark yellow welding blotches and a very ugly/ visible muffler under the quad pipes ....!
03-24-2008, 09:26 PM | #2 |
13
Rep 170
if it was a dark car liek black or jerez you could paint it the color of the car or simply black and get it done...but first of all sedan owners have to figure out how to hide those ugly rear lights of theirs...ugliest lights ever
2002 Laguna Seca Blue M3
03-24-2008, 09:29 PM | #3 |
33
Rep 596
Do NOT paint it the color of the car. Ever see those $5 mako paint jobs where they forget to cover up the exhaust when they spray the car? Good lord ... please do not bastardize the M that way.
Best way to hide it is to go aftermarket. Maybe a stock sounding and looking exhaust will come out |
03-24-2008, 09:32 PM | #4 |
17
Rep 128
Drives: Alpine White 2008 M3
1) Do not paint it. Fire hazard.
2) Do not paint it. It will discolor. 3) Do not paint it. It will shorten the life of the muffler due to increased heat. 4) Do not cover it - heat needs to be dissapated. Covers will prevent that and heat up other areas not shielded for the new heat load. |
03-24-2008, 10:13 PM | #8 |
609
Rep 10,407
Looks good. I especially like the flat black solution to further hide and address certain visibility concerns. I am noticing that most aftermarket solutions for the E9X M3 are dual canisters, whereas stock is a single canister. My concerns about all of these dual canister configuraitons is the drastic change in the shape of things right in and around the rear diffuser and differentialm area. The design of the cars underbody, area around the differential and diffuser all seem to be key ingredients in providing proper cooling air for the differential. So here is the key question. Has Remus done any analysis or testing on the air flow or cooling to insure this large design change does not affect either differential cooling or other aerodynamic issues?
03-24-2008, 10:24 PM | #9 |
O! So Sour!!
552
Rep 15,615
Drives: Fast 240z / Slow M3
Either get new mufflers or a rear diffuser.
03-24-2008, 10:36 PM | #10 |
26
Rep 62
2010 BMW 335D
2006 YAMAHA R6 2004 Acura TL Aspec (Sold) 2003 BMW E46M3 (Sold) |
03-25-2008, 07:04 AM | #13 |
45
Rep 528
that is so true. hihi true jap style rear light cluster
03-25-2008, 11:22 AM | #14 |
29
Rep 626
^ I think that was a bad install, a company like remus is going to make sure its products fit correctly. They are manufacturers for some of the top tuners they have to get it right.
03-25-2008, 11:25 AM | #15 |
29
Rep 626
check out this thread http://www.m3post.com/forums/showthread.php?t=122438
03-25-2008, 11:28 AM | #16 |
33
Rep 791
Wow, I had never seen that install picture before, looks awful!
Our exhaust comes with adjustable hangers, that installation shop must have done something wrong. Swamp2 : I will contact REMUS Austria about this as it is a very technical question. |
03-25-2008, 07:31 PM | #17 |
33
Rep 596
Maybe they're on backwards. Haha. Hopefully the bumper isn't melted on that one.
03-25-2008, 07:51 PM | #18 |
609
Rep 10,407
03-25-2008, 08:59 PM | #19 | |
374
Rep 8,033
On a similar note, I have much more of a concern about lowering the car. I wish BMW would somehow release info on what the flow and cooling implications of that might be. They have obviously studied that carefully before deciding on a ride height. The thing rides higher than a 335 coupe, so clearance and everyday drivability are not the reasons behind that decision.
03-25-2008, 09:02 PM | #20 |
32
Rep 257
painting the front end of muffler black...
...ie. only spray paint heat-resistant black paint behind the exhaust where muffle is currently visible......that should not lead to overheating ...or is it major NO NO.....
03-26-2008, 10:36 AM | #21 |
33
Rep 791
Swamp2:
According to REMUS Austria, the exhaust design allows for more cooling of the differential as tested in their R&D department. The tests results cannot be shown to the public. Furthermore, the canisters are packed with heat resistant insulation wool to prevent overheating the differential. They did not test aerodynamics because REMUS does not have a wind tunnel. |
