Throwing codes! Need help
07-26-2016, 12:45 PM | #1 |
12
Rep 97
So first off a little info on the car. It's an 2009 e92 335i 6MT. Current setup is a JB4 with a backend flash, BMS intakes, VRSF down pipes and an e30 mix.
So now to the problem. Yesterday while doing some spirited driving I heard a loud bang. Was close to home so I drove back real easy with the car lacking power, surging and the dreaded half engine light. I pulled 2 codes and got a 3100 and a 2ABC. After doing a little research I learned that my charge pipe had came of the throttle body. I removed the charge pipe and after a visual inspection, it looked in tact. So I cleaned the throttle body surface and reattached the charge pipe. I went on to clear the codes and reset the adaptations. When I turned the car on it started surging again and even turned off a few times. It started idling but now the same codes keep coming back. What else can I do? |
07-26-2016, 02:45 PM | #2 |
164
Rep 2,875
What do those codes say exactly? Also, did you make sure that the charge pipe is fitted tight and correct?
How did you install the charge pipe? With the C-Clip out or in prior to install?
'08 AW E90 335i PROcede V5 | BMS DCI | RR DPs | ETS FMIC | FORGE DVs | Stett CP | Vanguard | PSS10 |
07-26-2016, 11:33 PM | #3 |
87
Rep 559
Starting to notice a lot of people having this issue now I'm experiencing the same.
Replaced plugs Checked charge pipe Redid vacuum lines. Tested with another MAF Then decided to remove the tune ( fixed the prob but the car sucks now slowwwwwwwww ) Other things I've heard that can cause an issue Boost solenoids. --- havnt been able to test that theory yet tho |
