FS/FT: 2006 330xi SGM 6MT - Prem, Sport, Nav, Cold Weather (will trade for auto E90)
07-25-2016, 05:53 PM | #1 |
Rep 39
Hey All, I am looking to sell or trade my 2006 330xi. I am the second owner of this car, and have had it since May 2009. Sad to let it go, but a baby on the way means I need something that the wife will have an easier time driving. She isn't making me go too far, though. I'm looking to upgrade to a slightly newer E90 335i xDrive with an automatic trans. It currently sits at just under 93k miles and is in great shape. Some curb rash on driver side front wheel which I will replace with OEM prior to sale. I am looking to get $10,500 for it, or trade it toward something a little newer and I will add cash. Here are some of the options: 6MT Sport Premium Nav Cold Weather Logic7 Sound Oil is changed every 7,500 miles. I upgraded to Koni Sport shocks at 87k from TC Kline when my stock right rear went bad. TC Kline modifies the rear ones to put the rebound adjuster on top so that they don't have to be removed to adjust rebound. Only other mods are 35% tint and M-Sport Shift Knob. Here's an exterior shot for now, will share more if you want to. You can text at 724-882-4938 if you have any other questions. Thanks for looking! |
07-26-2016, 12:09 PM | #2 |
SRS BZN
14
Rep 159
Hello! Have a couple questions on the car.
Do you have maintenance records? Have the head bolts been replaced on this car? Has any of the cooling system been overhauled? Thanks!
07-26-2016, 01:28 PM | #3 | |
Rep 39
~75k miles - New water pump, thermostat, and hoses ~82k miles - Replaced oil filter housing gasket and valve cover gasket including all hardware, also replaced serpentine belt, pulleys and tensioner At some point the heater blower motor went bad. That was replaced, probably around 65k. Also did a new battery around that time. When I replaced the shocks and struts, I also did thrust arm bushings, tie rod ends, and ball joints. The car rides and runs great and shouldn't have any major maintenance issues to speak of. I do think it'll need plugs and wires at some point in the future, as those haven't been replaced under my watch. |
