Any relation between oil and coolant temps?
07-24-2016, 02:36 PM | #1 |
77
Rep 154
I have a Cobb AP v3 and noticed that my coolant temps seem to go as high as 220f when I first start driving around the car. However, once the oil temps gets to 230f the coolant temps drop down to 204ish. I do not have an oil cooler yet. However, it is my next mod. My cars engine was recently replaced with a motor that had 22k miles on it. New radiator, new fan, Hexon RR700 turbos, Hexon inlets, MMP outlets, VRSF fmic. I also notice that when the car has high ECT's the car is pulling timing. Is there a relationship between oil and coolant temps?
07-25-2016, 04:15 AM | #2 | |
596
Rep 1,693
Quite a few people have noticed this including myself. I've also noticed it on other cars. Cooler engine means less knock. The next XDF update should include pretty much full control over coolant temperature. |
07-25-2016, 05:51 PM | #3 |
55
Rep 84
Recently I replaced my radiator. Before this, I was monitoring my coolant temps as I knew I was 'leaking' fluid. I had to order the radiator and was driving while waiting for the replacement.
Since that time, I got the radiator replaced and because of that have been watching how the car runs. I noticed that when the outside temps exceed 100 - the car runs MUCH cooler. Literally. Normally, with AC on my car runs on average at 208F. When AC is off, the car runs between 205-225. This is when it's 80-96ish outside. However, when outside temps get into the higher 90's - 98+, the car runs on average 180-185f coolant temps. I was on a trip from Socal to Sacramento 2 weeks ago and noticed all this. I was watching my temps out of curiosity - knowing that the temps were higher than what I normally drive in for any extended period of time. Anyways, that is what I noticed when it came to coolant temps. Also, in relation to your question. I noticed that while highway driving in these extreme (to me) temps, when the coolant was 180f the oil temps were about 220-230f. I figured this was how the car keeps itself cooler in the hotter temperatures. BUT I wish that it would always run around 180 or let us tune that in or something. Anyways, hope this helps ya!
bluemonstrs' - 335i sneaky little sedan, creeping up on you with a little this and that.
07-25-2016, 08:14 PM | #4 | |
596
Rep 1,693
07-25-2016, 08:31 PM | #5 | |
291
Rep 2,189
I've heard others say when going WOT the DME tries to drop the coolant temps to <200 also. Maybe related to what you're saying.
2007 E92 335 6MT w/335is clutch FBO MHD E60 Wedge map 49k miles
07-25-2016, 09:12 PM | #6 | |
77
Rep 154
07-25-2016, 09:54 PM | #7 |
596
Rep 1,693
It is coming very soon to the public XDFs for those that flash with MHD or BBFlash. I've been running lower coolant temp targets for about 9 months. It's very unlikely that Cobb will implement this.
07-25-2016, 10:42 PM | #8 |
77
Rep 154
I ordered the cables for MHD as well. So the XDF file will allow this? Are you a beta tester?
07-26-2016, 01:39 AM | #9 |
596
Rep 1,693
I found the ambient temp thresholds for the cooler modes for IJE0S initially and passed the info on to jyamona. He has now also found the coolant temp targets for Normal, High and High+KFT modes. I believe that either him or Martial are in the process of porting the discoveries to all ROM versions before public release.
07-26-2016, 03:21 AM | #10 | |
Jedi samurai ninja turtle
619
Rep 3,021
Drives: X3 M40i 2018
The only thing I can think of is emissions? |
07-26-2016, 04:50 AM | #11 | |
596
Rep 1,693
Maybe to make rubber seals crack so they can sell more replacement parts? |
07-26-2016, 04:54 AM | #12 | ||
327
Rep 960
now this part I'm only speculating based on my limited knowledge of chemisty. combustion leads to the burning of sulfur producing sulfur dioxide this dissolved in water gives sulfuric acid. sulfuric acid in oil= lower tbn, low tbn = oil past its used by date. by removing the moisture the so2 is able to be removed through the pcv system rather then staying dissolved in the oil. coincidence that the oil temp sits just above the boiling point of water? I think not. also important which many people forget is that oil temp and coolant temp are 2 different things when i logged my coolant temp on track it sat around the high 80s even though oil temps were getting up around 130. |
07-26-2016, 06:24 AM | #13 |
898
Rep 6,285
Im sure I read that the high oil temps was due to bmw engineers wanting to minimise oil blowby, by vaporisation?
07-26-2016, 06:27 AM | #14 | |
898
Rep 6,285
Its sulphur, damn yankee spelling haha But yes correct |
titium326.50 |
07-26-2016, 09:45 AM | #15 |
77
Rep 154
Very interesting viewpoint for why the temps were kept so high. However, since these cars are getting older I am very interested in lowering both coolant and oil temps to help with the longevity of the motor and other components. I change my oil every 3000-3500 miles so if your theory is correct any benifits from the higher oil temps would be negated.
07-26-2016, 09:51 AM | #16 | |
170
Rep 1,843
On all the (very old) cars I've personally worked on, the physical thermostat determines coolant temp, sometimes aided by a thermostatically controlled electric fan. e.g. you put a 195F thermostat in, your coolant temps typically sit about 205ish and the electric fan kicks in at some point above that to help bring temps down, but the temp is not adjustable. This talk of DME coolant temp target - how is that dynamically achieved? Is the thermostat replaced by a solenoid or similar? |
07-26-2016, 10:43 AM | #17 | |
55
Rep 84
AND N8N - it would seem regardless of the 'hardware' in the car (in this case the thermostat for the radiator system), the COMPUTER system of the car (DME) can and will control the driving temperatures depending on the needs of the current situation. That is what I was noticing when the temperatures outside get above 100f. That the car actually drives cooler than normal.
07-26-2016, 11:16 AM | #18 | |
3441
Rep 79,211
My z06 has a 160 T Stat. It can't even get that low. In the summer it's about 190 and in the winter it's about 175-180. Perfect. A majority of the reasoning is emissions. |
07-26-2016, 05:06 PM | #20 | |
596
Rep 1,693
07-26-2016, 05:06 PM | #21 |
898
Rep 6,285
One thing I've noticed also is that manual cars seems to run cooler water & oil temps (Well my car does compared to others with AT) which I believe may have to do with the MT having a slightly larger rad?
07-26-2016, 05:09 PM | #22 |
596
Rep 1,693
