Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Mechanical Help Please!!!!
      07-22-2016, 09:21 AM   #1
mgoldade
Drives: 2011 328i x-drive sedan
Ok, I own a 2011 328i x-Drive sedan. Overall, the car is fantastic! I have had to replace the right front wheel bearing, which is apparently an issue with these cars.
Now, I need to troubleshoot 2 other problems. I'm hoping others in this forum may be able to provide their experience & knowledge...
1) On gradual acceleration, when I reach about 1900rpm, the engine stutters. If it keep it at that rpm, it keeps doing it. Once I pass 2000rpm, it's gone. It's not noticeable on hard acceleration. The car is not showing any engine warning lights when it happens either.
2) When the car is parked and I put it into reverse, the tach needle starts bouncing between 1000rpm and 2000rpm with my foot off both the brake and gas. You can hear the engine increase and decrease. You can feel the car lurching in reverse. It doesn't do this in drive.
I've worked on all my domestic cars for years, but haven't done any work on my 328 except brakes. These two issues have me totally confused.
Is anyone else experiencing these issues, or has experienced them in the past? Does anyone know what the cause of these would be?
Any help and assistance is greatly appreciated!
Mark
      07-22-2016, 09:34 AM   #2
Greyfox
Greyfox's Avatar
1208
Drives: 2007 328xi E91 - 330k+ (miles)
How many miles are on the car?
      07-22-2016, 09:36 AM   #3
mgoldade
Approx 83000km (which I believe is 50000mi). I have kept up with regular maintenance and take really good care of my car.
      07-22-2016, 10:11 AM   #4
Greyfox
Greyfox's Avatar
1208
You are going to need to get a computer or diagnostics reader plugged into it and see what codes are being reported.
      07-22-2016, 10:17 AM   #5
mgoldade
Ok, I have an OBDII reader. I'll plug it in and see if any codes are pulled. I didn't think codes would show unless you were getting a warning light?
      07-22-2016, 11:11 AM   #6
seepete753
seepete753's Avatar
Drives: 2015 Tanzanite F80 M3
There are shadow codes that appear when you use a diagnostic tool but do not show up on the dash.
Example: I had to replace my Low pressure fuel sensor recently because I read my codes with my Cobb tune but had no indicator on my dash.
Current Car: 2015 Tanzanite F80 M3 w/ Cohiba Brown Interior
Past Cars: Le Mans Blue 2010 e92 335i M-Sport 6MT // Cobb // BMW Performance Exhaust // AFE DCI Stage 2 // ER CP // Gloss Black BMW Performance Spoiler Rep // BMW Performance Black Grills // 19" Black Avant Garde m359s // TGS HPB LED Interior Kit
      07-22-2016, 11:42 AM   #7
patents
164
Drives: 2008 328i
An OBDII reader won't tell you much. There are FAR more detailed and specific diagnostic codes the car can store, but the codes are specific to BMW and you need a code reader than can read the BMW codes. OBDII codes are common across all makes and only cover generic, general things.
For example: You may have a BMW code that will tell you that the cooling fan on your in-dash navigation unit is not operating. OBDII will not tell you that.
And it's true that not all codes will illuminate a warning light.
      07-22-2016, 11:53 AM   #8
mgoldade
Yeah, no codes using OBDII
      07-22-2016, 01:07 PM   #9
BlindWolf187
48
Drives: 2008 E92 335xi 6MT
There are also non-OBD standard codes that only show up with readers programmed to read BMWs. You will need a specialized BMW code scanner. There are other units with that capability too (I think the Cobb accesport can do it, the Carly app can supposedly do it).
2008 335xi 6MT Coupe - Monaco Blue on Saddle Brown | fully optioned
      07-22-2016, 01:17 PM   #10
Greyfox
Greyfox's Avatar
1208
or buy a bmw obd cable and go to the Coding board and get hooked up with the software.
      07-22-2016, 05:42 PM   #11
mgoldade
Ok, so I guess I'll have no choice but to take it to the dealer...
Has anyone else experienced these issues with their E90 though? If you have, what was the issue? What was the problem?
      07-22-2016, 08:44 PM   #12
Greyfox
Greyfox's Avatar
1208
I had an issue very infrequently where if I was in heavy stop and go traffic and decelerated to around 30 mph and then went to accelerate I would get a studder. Knock on wood, I changed my transmission and transfer case fluids and haven't seen the issue since. But that was around 160k miles with the transmission being changed once before. Probably will change the transmission a third time before fall.
      07-26-2016, 08:20 AM   #13
mgoldade
Appt booked for Tuesday to have it fixed. I'll let you know what the issue was after it's back home. And not a minute too soon as my a/c just died too...
Thank god for warranty!
      08-03-2016, 09:00 AM   #14
mgoldade
So, it is still in the shop, but they have contacted me to let me know the engine "shudder" is actually the left front axle slipping. They are ordering a new axle. The A/C leak is still giving them issues (can't pinpoint the location of the leak).
I find it odd that the axle would only cause a slip at certain rpm, so I'll update in this later...
      08-03-2016, 09:39 AM   #15
Greyfox
Greyfox's Avatar
1208
Axle slipping? As in slipping on the splines?
      08-08-2016, 09:38 AM   #16
mgoldade
Yeah, The splines on the inner left front CV Axle are shredded apparently. It caused a reverberation (shaking) between 1600-1900rpm. New CV Axle in. Now they are trying to find the damn A/C leak... fml...
      08-08-2016, 02:27 PM   #17
Volasko
Volasko's Avatar
705
Drives: 06 330i E90, 18 530xe G30
Was the bearing you replaced the same side as the destroyed axle spline? Sounds like whomever did the work destroyed your spline trying to reinstall!
      08-08-2016, 03:33 PM   #18
mgoldade
No, the bearing was right front.
      08-19-2016, 10:14 AM   #19
mgoldade
Ok, vehicle is back, and repaired. Here is the breakdown.
The vibration on accel between 1600-1900rpm turned out to be due to the L/F CV Axle. The splines on the axle that go into the transmission were worn down. This caused a reverberation at this rpm. All the computer sensors in the car then tried to compensate and it felt like a transmission or injector issue. Since the CV Axle was replaced, the vibration is gone and no matter how hard I try, I cannot duplicate it.
      12-07-2016, 05:48 AM   #20
mgoldade
So, I had my car parked since it was last in the shop as I'm military and was away. I came back and still dealing with the same issue of the brutal vibration / stutter between 1600-2000rpm on acceleration. Only now it's doing it on decel.
So it was not the CV Axle. Furthermore, the garage told me it could be the software upgrade. They wanted me to flash all the modules (trans, fwm, etc). I decided against that until I did more research, as the software upgrade is not covered under warranty.
I'm chatting with an older civilian NavCan employee the other day, and he has an M4 and an X5. I ask him if he's ever experienced the same issue and he tells me he has. He describes it to a T. I ask him what the cause was and he tells me it's the nylon worm gear in the transfer case.
I call up the garage and ask them about it and they immediately acknowledge not thinking of that, and say that is most likely the issue. Bring it in...
So, here we go, let's find out if this solves the problem...
      12-07-2016, 06:07 AM   #21
frenchi
frenchi's Avatar
France
89
Drives: F30 340i M Performance
transfer case actuator in your car doesn't have a nylon gear...only metal ones
I got a similar problem with my car and after replacing a lot of parts i think that front differential is the problem.Car is booked for both front bearings and both front axles but i am almost sure that will not resolve my problem. Do you have some drone humming noise on highway speed ? Did you try to remove the power supply socket to the transfer case and test drive ?
      12-07-2016, 07:18 AM   #22
Pierce330
Pierce330's Avatar
34
Drives: E90 328 xDrive
Strange, I have only heard about this occurring on the E53 X5. Are you the original owner of the car? Also, are there any quality indy shops in North Bay? With your mileage, you would be looking at water pump and thermostat shortly.
E46 330i (Sold)
E90 328i (Sold)
E90 325i (Sold)
E90 328i xDrive
