Elusive 30FF Issues
07-19-2016, 07:16 PM | #1 |
48
Rep 161
Elusive 30FF Issues
For quite some time now I've had an elusive case of 30FFs being thrown by my car. My buddy and I have spent a lot of time etc. trying to troubleshoot it and have not had any luck at all so far. The mods on the car are relatively light, consisting of a VFSF chargepipe w/ previously a TiAL BOV and now a SSQV V4 BOV and DCI. I've clamped, reclamped etc. all my lines etc, as well as every single vacuum line has been replaced. It's running MHD, various versions and seems to 30FF no matter what tune I run. It even 30FF'd while I was running 100% stock during some recent warranty work.
A few weeks ago we did a leakdown test and weren't able to find any apparent leaks, though we weren't able to go very high due to the pressure regulator not being very precise below 20PSI. I'll sometimes go days, and even weeks with no 30FF then they will start up again. Here's a few log pulls from a few weeks ago; we've noticed my wastegate duty cycle seems odd, along with me not reaching boost targets quickly. I DO have wastegate rattle, but the dealer swears it's within spec. We also swapped boost solenoids with my friends known-good N54, which made no impact whatsoever. Here's a few pulls I did a few weeks ago: http://datazap.me/u/rosullivan04/ful...og=0&data=4-23 http://datazap.me/u/rosullivan04/ful...=1&data=4-6-23 A recent development I noticed yesterday is that if I go above 110+MPH I am 100% guaranteed to get 30FF thrown by the DME, regardless of the throttle input. We don't think there's any leaks based upon the testing we've done, but perhaps we've missed something. This was happening with the stock charge pipe and stock diverter valves as well back when I had to return to stock for carbon cleaning (4K miles ago). At this point we are completely at a loss and am wondering if someone has any suggestions short of taking it somewhere and having them rip it apart and see what's gone wrong. Any advice anyone has that could help me track it down would be tremendously appreciated. Thank you!
2008 335I 6MT
Tune by Wedge Performance |
07-19-2016, 07:30 PM | #2 | |
654
Rep 946
07-19-2016, 07:36 PM | #3 |
48
Rep 161
I'm very concerned I'm running into the same problem too. I'm around 99,250 miles on my rig... how many do you have?
2008 335I 6MT
07-20-2016, 09:36 AM | #4 | |
4276
Rep 9,206
07-20-2016, 09:52 AM | #5 |
48
Rep 161
Hmm, neither my friend nor I have ever adjusted wastegates on N54s before; I'll have to find a FAQ on it and try that out, thank you! There's no other codes being thrown; it's literally just 30FF. Not even at 100% throttle oftentimes, just when moderately accelerating. It's so extremely random that it's been very difficult to pin down unless I do 110+MPH.
2008 335I 6MT
07-20-2016, 10:10 AM | #6 | |
4276
Rep 9,206
07-20-2016, 11:22 AM | #8 |
77
Rep 275
Drives: E61 535XI, E92 335I (Sold)
I had this problem too, my friend's shop told me while it rattled it was not leaking any boost. Swapped the turbos and no more code! It would underboost every day anytime I got on it
07-20-2016, 12:27 PM | #9 |
483
Rep 2,283
My wastegates get stuck open every now and again (107,000 miles orig turbos) and I get this code. Goes away shortly after
07-21-2016, 10:24 AM | #10 |
13
Rep 30
120k miles, got the 30FF with the tune and on long WOT pulls with stock on the highway. It's your wastegates man, adjust the rear one and good luck with the front one. I ended up spacing the actuator out with washers to make it work "right" again. I ran around like you chasing my tail trying to find leaks, and that fixed it completely.
07-21-2016, 07:46 PM | #11 |
48
Rep 161
My buddy and I are looking for a FAQ now to see what's involved to do that. I'll definitely try that if it'll buy me a few more months to save up for better replacement turbos. Thank you!!!
2008 335I 6MT
07-21-2016, 10:05 PM | #12 |
Rep 6
07-22-2016, 05:50 PM | #14 |
343
Rep 1,465
I've been chasing 30FF issues since June. Replaced just about everything like vacuum lines and boost solenoids and smoke test at the shop.
If you have 100k miles on the stock turbos, then it is safe to say, 99.9% your wastegate door is getting jammed periodically. The shop pulled the turbos and I was able to inspect that the front turbo wastegate bushing gets jammed and that's why I got boost leak. There is no way around this other than to replace the turbos. There is a bushing fix but you won't find many shops willing to do that work and for the amount of money to do it, you might as well buy a new OEM turbo for like $600. Expect to replace turbos every 100k+ miles. I got 124k miles before the front turbo bushing wore out and jammed open. Another tell-tale sign is that it will leak so much exhaust your exhaust tone gets louder. |
07-22-2016, 10:20 PM | #15 |
48
Rep 161
I'm thinking the same thing, sadly enough. I flashed 100% stock and I'm going to put stock parts back on tomorrow. Here's a lot with 100% stock flash on the DME:
http://datazap.me/u/rosullivan04/sto...=0&data=4-6-23
2008 335I 6MT
