Question about passing emissions with DP Fix
07-18-2016, 03:45 PM | #1 |
68
Rep 743
Drives: FBO 335i
I have the BMS dp fix installed on my car with catless downpipes. I've driven around 40 miles and the cel disappeared and I was wondering if that's enough to pass emissions (obd test). I took off my Cobb tune so it's on the stock tune, however when I scanned my car for codes with the Cobb, I still get an error code for p29f4 and p29f5 which are the codes I failed for previously. Should I drive around some more or put my Cobb tune back but to map 0?
07-19-2016, 12:31 AM | #2 |
2685
Rep 4,202
Drives: '11 335is | '16 Macan Turbo
Read through my thread, I went through this issue (w/o a dp fix) a few months ago. Jeff@TGS posted how to reset the drive cycle and it worked awesome for me! Too bad with Cobb it doesnt show the 'ready' states like MHD but still do that drive cycle then check out your codes again.
http://www.e90post.com/forums/showthread.php?t=1260475
'11 335is BSM MT "BMW Performance Editon" | '16 Porsche Macan Turbo
GruppeM CF Intake | AR Resonated DP | ER CP | Turbosmart RacePort BOV | Cobb FMIC | RB Inlets | RB External Mishi/Turner OCC | Michelin PS4 | BMW Performance Springs/Bilstein B8 + Dinan & M3 bits | BMW Brembo BBK | BMW Performance CF Spoiler | BMW Performance CF Lip | BMW Performance Alcantara | PS Designs GTS Armrest | AG H6-40 | Rear Seat Delete |
07-20-2016, 11:56 AM | #3 | |
232
Rep 723
Sweet!..So just flash map 0, and follow the drive cycle reset procedure? I'm also allowed 1 "not ready"
2007 335i E92 MT | MFactory LSD | Diff Brace | MHD/Wedge Tuned| BL Coils | Stg2 lpfp BoostConcepts | VRSF DPs | VRSF 7" HD FMIC | DCI | VRSF CP | BMW SSK | Billstein PSS Coilovers | M3 Control Arms | Whiteline Rear SF Inserts | SS brake lines | Z4 35is Rotors | Hawk 5.0 pads | M219s + PSS | PE Mod -SOLD
2016 M4 F82 MT |
07-20-2016, 12:42 PM | #4 | |
Guest
Rep n/a
Drives:
Flashing back to stock without a dp fix will prob cause a CEL = instant fail. |
07-20-2016, 01:54 PM | #5 | ||
232
Rep 723
btw I though map 0 on mhd isn't stock, and still supresses catless dp codes. regardless, the procedure should still remain the same.
2016 M4 F82 MT |
07-20-2016, 06:59 PM | #6 | ||
2685
Rep 4,202
To answer, yes...I flashed to stage 0 which still suppressed the CEL for the dp's, but the drive cycle then reset the catalysts to show complete...the o2 sensors were the ones showing 'not ready' for me
07-22-2016, 12:19 PM | #7 |
BimmerPost Supporting Vendor
1334
Rep 1,701
Drives: Slot Machines.. Keep Taking $
MHD Stage 0 map is stock and does not suppress any cells.
