Classifieds Section > Sponsors Classifieds > getBMWparts.com | Dinan F87 M2 Lightweight Anti-Roll Bar Set + FREE Shipping!!!
      07-18-2016, 03:19 PM   #1
Evan@Tischer
BimmerPost Supporting Vendor
Evan@Tischer's Avatar
3246
Drives: Online Parts Sales
Almost all street cars come from the manufacturer with an anti-roll bar as it is a common part of modern suspension systems. However they are designed to be overly soft for maximum comfort. An anti-roll bar does exactly what it says by reducing body roll in all situations. Every Dinan tuned anti-roll bar is built and tuned specifically for each BMW chassis. Lowering the amount of body roll keeps your BMW more level than stock (while still allowing just enough body roll) to improve mechanical grip. This improvement gives the driver a much more planted and confident feeling in every corner.
Front Anti-Roll Bar:
Add a 32mm Lightweight Tubular Adjustable Front Anti-Roll Bar to reduce body roll, improve grip and stability while saving weight at the same time. This anti-roll bar is adjustable from 57% to 103% stiffer than the stock bar. This 4 hole bar can be mounted in 7 different positions with supplied adjustable end links.
Benefits:
  • Less Body Roll
  • More Mechanical Grip
  • More Stable At Limit
  • Large 32mm size (stock bar is 24.7mm)
  • 4 hole bar with 7 possible positions on the bar w/ supplied adjustable end links.
  • Tubular (Hollow) Construction
Includes: Lightweight Tubular Adjustable Front Anti-Roll Bar, Adjustable End Links, Urethane Bushings, Heavy Duty Brackets w/ Grease Fittings.
Rear Anti-Roll Bar:
Add a 24mm Lightweight Tubular Adjustable Rear Anti-Roll Bar to reduce body roll, improve grip and stability while saving weight at the same time.This anti-roll bar is adjustable from 0% to 13% stiffer than the stock bar. This 3 hole bar can be mounted in 3 different positions with stock BMW end links.
Benefits:
  • Less Body Roll
  • Large 24mm size (stock bar is 22.9mm)
  • 3 hole bar with 3 possible positions on bar
  • Only tubular anti-roll bar with a large range of adjustment on the market
Includes: Lightweight Tubular Adjustable Rear Anti-Roll Bar, Urethane Bushings, Heavy Duty Brackets w/ Grease Fittings.
Shop Dinan Performance Parts Here!!! PM for special forum pricing!!!
Evan Winstead · Internet Parts Director
Contact Us | Facebook | Twitter | New: Shop Porsche & Audi parts!
      10-13-2016, 12:13 PM   #2
Evan@Tischer
3246
PM for special forum pricing + FREE US Ground Shipping on all Dinan Performance Parts!!
      03-08-2017, 03:45 PM   #3
Evan@Tischer
3246
      10-02-2017, 10:56 AM   #4
Evan@Tischer
3246
Tags
dinan, getbmwparts, roll bar, sway bars, tischer
Search this Thread:
Advanced Search
m2
