MHD stage 2 stats and requirements
07-15-2016, 06:21 PM | #1 |
57
Rep 552
So after much deliberation, I finally removed my Cobb, and run the MHD flash stage 2. Took it for a spin, and noticed alot more power running through the gears. I have dps and intercooler upgraded but I'm only running stock twins, and fuel pump is stock also.
I am a bit concerned as I am hitting 20psi. There is alot of talk out there as to what is safe - it seems like as the years go by, the "safe limit" for the stockers also increases. I'm just wondering whether 20psi is what the stage 2 MHD is targeting? I have searched but cannot find what kind of boost levels I am supposed to be expecting. Furthermore, I am not too experienced with opening up a flash tune file and searching that way.... Also - I have read that the stock sensor detects up to 21.5psi of boost before you start going into unknown territory - can someone confirm this? I'd rather hope that the ceiling is not at 20psi, cos that could mean I am flying blind. |
07-15-2016, 08:30 PM | #2 |
39
Rep 348
I've been saying this forever. 20 psi is way to much for any daily driven car especially stock turbos. Somehow everyone has jumped on this MHD cheap flash bandwagon. Seen more local cars blow up from these tunes then all the other tuners combined. It's all risk and reward. There is a reason that jb4 maps and Cobb etc don't target more then 17ish psi. Just know a daily driven cAr at that boost level will only last so long.... My .02c
07-16-2016, 08:31 AM | #4 | |
25
Rep 74
Drives: 2008 335i Coupe 6-speed
am I missing anything?
'08 E92 335i 6MT Coupe SGM | MHD Stage 2 93oct | Cp-E CP | AA BOV | DCI | VRSF DP | VRSF 5" Stepped FMIC | Apex Arc-8 | Cyba Air Scoops | Failing HPFP....
07-16-2016, 09:26 AM | #5 |
57
Rep 552
Yeah I know someone was going to mention logs. I plan to. Though I do have a gauge t'ed into my vacuum lines so I can always check after a pull what the max boost reached was. And that's how I saw 20psi.
07-16-2016, 09:38 AM | #6 | |
57
Rep 552
07-16-2016, 09:51 AM | #7 | |
220
Rep 695
07-16-2016, 10:16 AM | #8 | |
184
Rep 2,841
Boost spikes are normal during gear changes. Your boost gauge is probably giving you the peak reading only. You need a datalog to see what boost is doing across the entire rpm range. Most of the stage 2 tunes will target 17-18 psi at low rpm and then taper boost down to 15-16 psi as redline approaches. A transient spike up to 20 psi is very possible and of no concern. My stage 2 tune hits 17 psi when I shift around 5500 rpms and I see a spike of 19 psi post-shift....which quickly corrects itself. |
nicky dj344.50 |
07-16-2016, 10:39 AM | #9 |
55
Rep 96
07-17-2016, 06:03 AM | #10 |
122
Rep 397
Boost is only 1 element to consider. When you log, you'll see timing, AFRs and trims (among other stuff) which help to determine how well you're car is working with the tune that's loaded.
07-18-2016, 11:23 PM | #11 | |
261
Rep 1,093
Point is because a tune kisses 20psi for a few hundred rpm in the turbos efficiency range does not automatically make it dangerous or overworked. 10 times out of 10 IF an OTS stage 2 tune is hitting 20psi that's all its doing. You can easily have a "peak" 16psi tune that is far more dangerous than a tune that peaks at 20psi. |
8
OlliD28.50 |
01-30-2020, 10:02 AM | #12 |
Rep 5
Mhd Stage 2+
Hello, so I have a 335i 2007 n54 sedan, and I just finished tuning to stage 2+ after stage 2, this is because I really didn't feel any difference in stage 2, and in stage 2+ I still barely feel a difference ; I have bov , charge pipe , down pipes , intakes. I feel like it's supposed to have more power . Do you guys feel a major difference ?
01-30-2020, 01:24 PM | #13 |
449
Rep 823
Welcome to the site!
Feelings are very subjective. To continue the theme of this [ancient] thread, you need to record some logs and see how the car is responding. Posting that information enables others on this site with far more knowledge to help you troubleshoot and evaluate. |
