Inline thermostat options
07-13-2016, 11:18 AM | #1 |
111
Rep 408
Hi guys. Oil cooler retrofit. Using an oil filter housing adapter plate and inline thermostat. Looking for options for an inline thermostat. So far I've read that Earl's t-stat o-rings don't always fit so great. The Improved Racing one looks great, particularly cause I don't want to open until 215deg (180deg won't get me close enough to operating temp on my daily driver commute 90 percent of the time). It's a bit pricier though. Any other options?
07-14-2016, 08:25 AM | #4 |
111
Rep 408
07-14-2016, 09:43 AM | #6 |
111
Rep 408
Right this is exactly the reason for my thread -
A.) What temp does fully open at 185 through a 25-row narrow cooler yield in daily driving, and is it hot enough, and B.) Am I correct that the 185 will be better when beating the shit out of the car on track, cause it's just allowing the opportunity to cool down sooner? |
07-14-2016, 02:47 PM | #7 | |
30
Rep 216
B.) On the track, the thermostat will likely be open all the time so it doesn't even matter if you start the cool down sooner because your oil cooler might not even be able to dissipate the heat. The improved racing thermostat is designed such that there's always partial flow of the oil. I personally use the 215F from Improved Racing and with the ER sports oil cooler (which is 3.5 times the core size of stock), I'm seeing about 220F on DD of 30 minutes. |
07-14-2016, 03:07 PM | #8 | |
111
Rep 408
07-14-2016, 04:58 PM | #9 |
30
Rep 216
08-12-2016, 01:56 PM | #10 |
65
Rep 91
I run a 25 row setrab, at the end of an autocross session which is 6 runs with about 3-5 minutes between each on a 1.2mile course I will get up to 240*. That's in 85* weather
2009 335I 6AT Coupe -TFT inlets -VTT Outlets - Stett Stage 2 Oil cooler - ETS 7" blck ano Intercooler - Turbosmart Raceport BOV - BMS occ - mishimoto occ - Custom Pnp Trans Cooler - Rb pcv bypass - Stoptech 355mm bbk - m performance rear bbk - Diffs online 3 clutch lsd - BC forged 2 piece wheels - Hankook ventus Rs-3 - M3 control arms - Dinan camber plates - Redline and Motul fluids
FamilyManTrackSedan111.00 |
