M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > Active Autowerke | M2 with BC Forged Track Wheels
      07-11-2016, 04:04 PM   #1
David@ActiveAutowerke
BimmerPost Supporting Vendor
Drives: M2
Last week our BC Forged wheels came in and we had the chance to mount up our 275/35/18 Nitto NT05's and throw them on the car. We worked closely with BC to spec the perfect offsets for this car so that we could run a square wheel and tire setup. The front wheels are within a few MM of the strut and with -2.5* front camber the tire fits nicely in the fender. I don't think a larger wheel/tire combination is possible without modifying the fenders.
The wheels are BC Forged RZ39 in Matte Bronze. 18x10 et35 with a 12mm spacer up front. On our scales they came out to 19.4lbs each.
The Nitto's have a super stiff sidewall with a decently soft compound so I'm excited to get them scrubbed in and on the track. I also have to mention that with the amount of times I've had the front wheels on and off the car, the Motorsport Hardware stud conversion made life so much easier. We're running their pitch conversion stud which converts the wheel mounting threads of the stud to 14x1.5 to make the threads stronger for repeated and heavy use.
We'll be at Sebring International Raceway next weekend to put down some more laps with the updated car so I'll be able to update next week about how the car handles with the larger square tires!
I'll definitely be posting some more photos once we get the car aligned and corner balanced at it's final ride height!
Appreciate 10
neo871142.00
      07-13-2016, 04:45 PM   #2
automotiveaperture
automotiveaperture's Avatar
93
Drives: Frozen Black M3
Looks awesome, a nice subtle bronze. In for side profile shots!
      07-13-2016, 06:09 PM   #3
ashburyn54
ashburyn54's Avatar
625
Drives: f87 M2
Great looking setup guys! Glad to hear 18x10 et 23 fits up front with some meat and camber.
Would the stock strut protrude too far out compared to your coilover setup to run that?
      07-14-2016, 08:38 AM   #4
Drives: M2
Thanks!
Thank you! I'm pretty sure this setup would work with a stock strut as long as you have camber plates.
      07-14-2016, 01:43 PM   #5
clubsport
204
Drives: LBB
Those bronze wheels would look great on any of the 4 colors.
Thanks for passing along the info. You guys are awesome.
      07-14-2016, 07:15 PM   #6
dammitcubs
584
Drives: '16 M2 LBB
Yeah i would like to see these on a LBB and how good they would look.
      07-15-2016, 05:59 PM   #7
Drives: M2
Thanks for the kind words!
I think bronze is right at home on LBB
      07-15-2016, 06:00 PM   #8
Drives: M2
Update: After our corner balance and alignment we have some slight rubbing up front. With the aggressive offset and tire the tire touches a part of the tab where the bumper meets the fender. This was happening only on larger bumps or dips. We've since trimmed the tab and haven't had any issues so far. The true test will be at the track on Sunday when we put in some hot laps with the extra grip and power!
      07-16-2016, 09:37 AM   #9
Fullofdays
41
Drives: m
Have fun and be safe. Looking forward to hearing how your shakedown goes this weekend.
      07-19-2016, 01:43 PM   #10
ashburyn54
ashburyn54's Avatar
625
Drives: f87 M2
Is there room for about 5mm more poke in the rear?
      07-19-2016, 02:05 PM   #11
Drives: M2
Thank you! I put up a thread in the Engine section about our day at Sebring.
There should be, depending on how much camber you plan on running.
      07-20-2016, 04:06 AM   #12
koastal
Australia
376
Drives: F87
Those wheels look good
      07-23-2016, 07:27 AM   #13
Fullofdays
41
Drives: m
David- can you shoot a pic of the tab you trimmed in the fender well? Any issues on track otherwise? What ride height did you target? Any thing you are wanting to improve after last weekend's track event?
      07-25-2016, 02:22 PM   #14
quikM2
371
Drives: 2017 Jahre M3
More pics please!... love bronze wheels.
      07-25-2016, 03:39 PM   #15
Drives: M2
Thanks!
I put up a post-track thread in the Engine section here: http://f87.bimmerpost.com/forums/sho....php?t=1285217
We did have a couple issues as mentioned in the thread above, mainly heat related.
I'll make sure to snap a pic of the tab the next time we get the car on the lift. We set the fender just above the tire so that it wasn't tucking at all when on level ground.
There are a few more photos in the link above!
      07-29-2016, 08:48 AM   #16
CosmosMpower
CosmosMpower's Avatar
2051
Drives: F87c, GT3, MK7 GTI
Is this the same BC that makes crappy low budget coilovers?
      08-01-2016, 08:54 AM   #17
Drives: M2
BC Forged is a division of BC North America.
I'm sorry you feel that way about their suspension systems but a few years ago they were taken under new ownership here in the US and have dedicated time and research in to building a quality product. I don't want to pollute this thread with suspension talk but if you have some time take a look at their motorsports development over the past few years and you'll see what I'm talking about. They've been extremely helpful with helping us dial in an M2 kit and after comparing our stock M2 shock dynos to the M4 shock dynos they're now building us a digressive shock kit for the M2 that will hopefully be ready for testing within the next few weeks.
      08-02-2016, 04:43 PM   #18
AndrewC1989
AndrewC1989's Avatar
Drives: 2015 328d xDrive
why the 12mm spacers up front if you're rubbing?
      08-03-2016, 08:13 AM   #19
Drives: M2
We ordered the wheels in a true square setup with the same offsets all around. The rear requires a higher offset of 35 while the front requires a lower offset to clear the strut inside the fender so we use a 12mm spacer to get an effective offset of 23.
      08-10-2016, 04:52 PM   #20
BD_F22
BD_e92
Drives: 2015 m235i xDrive
Hey David,
With your experience with your wheel setup.. If I were to go with an18x9.5 ET25 on a 265/35 do you think I would rub? It's affectively the same offset as you but 10mm narrower due to width of the tire.. Also do you have any recommendations for offset if I want to run an 18x10.5 on a 295/35 rear? Thanks!
      08-11-2016, 07:48 AM   #21
Drives: M2
Originally Posted by BD_F87 View Post
Hey David,
You should* be safe with that setup up front. You'll have 5mm more clearance from the tire and an additional ~8mm from the more conservative wheel setup. Your camber settings will impact that as well.
For the rear I would say somewhere between 40 and 45. I believe IND is running 10.5 with a 295 on the rear of their car, maybe you can shoot them an email for the offsets?
      08-11-2016, 01:21 PM   #22
LBBDrew
336
Drives: 2017 LBB M2
How have the Pagid RS29's held up? How many track days (let's say 5x 20 min sessions) can you get out of them? Cheers
m2
