Sodium in oil
07-11-2016, 09:04 AM | #1 |
M3 Haha
11
Rep 43
Drives: 07 E90 335i
Sodium in oil
Recently sent a sample in to Blackstone and everything came back alright except for sodium. Lots of sodium. 216 ppm. There is no oil in my coolant reservoir and I don't think the pressure differential would allow coolant to seep into the block the other way around, but I'm no engineer. I know my turbos are completely shot - I get smoke every once in a while from under the hood on the turbo side every once in a while after running the car hard and I have REALLY high oil consumption. Is it possible for the seals on the turbos to be shot and have coolant get into the oil return line? Or am I just deluding myself? I really don't want the head gasket to have gone bad. The car has never overheated while in my possession. N54 with 118k miles.
07-11-2016, 09:36 AM | #3 |
261
Rep 1,093
Smoke occasionally on the turbo side near the rear is usually a valve cover leak. Turbos leak inside the turbine housing and out the exhaust. Large oil consumption on the other hand is usually indicative of a more severe leak.
07-11-2016, 09:59 AM | #4 | |
77
Rep 275
Drives: E61 535XI, E92 335I (Sold)
Could also be your oil filter housing gasket, my oil and coolant were completely mixed on my car. Literally like 50/50 and I was totally worried. Turned out just to be the OFHG, check your coolant tank and look for oil and pull the plugs to check if the cylinders are shiny, then check OFHG |
07-11-2016, 12:53 PM | #5 | |
M3 Haha
11
Rep 43
Drives: 07 E90 335i
07-11-2016, 01:57 PM | #7 |
77
Rep 275
Possibly, did your mechanic clean out the system or did he just change the gasket? I had to flush out my coolant and oil systems many many times because they were both so badly mixed.
07-11-2016, 02:01 PM | #8 |
M3 Haha
11
Rep 43
Drives: 07 E90 335i
07-11-2016, 02:03 PM | #9 |
M3 Haha
11
Rep 43
Drives: 07 E90 335i
I don't think he flushed either one. Could be wrong. Just changed the oil once as far as I know
